Samsung Syncmaster 930B - screen going off and on
  • jay333
    • Oct 2011
    • 6
    My monitor screen blinks off for a second or two every 10-15 seconds or so. Before purchasing a new monitor I decided to browse the internet for possible causes - after reading a variety of information including info on badcaps it seemed to me that it was probably a bad capacitor or two. I have opened up the monitor now and removed the board with the capacitors. However, the capacitors are not showing any visible signs of problem. The tops of them are all nice and flat, the capacitors are straight with no bulging anywhere nor are they leaking anything. They look pretty much perfect. Is it likely that my screen problem is something else - should I be checking something different.
    I am by no means an expert on these things so any assistance or direction that anyone could provide me would be greatly appreciated. Thank you!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 930B - screen going off and on
    This could be bad ccfls or bad ccfl return wiring. See
    http://s807.photobucket.com/albums/y...klight%20lamp/
    It could also be bad caps or a bad inverter transformer. See
    https://www.badcaps.net/forum/showpo...21&postcount=2
    --- begin sig file ---
    --- end sig file ---
    • jay333
      • Oct 2011
      • 6
      Thank you for this great information. It is most helpful. I have read through everything carefully and after further watching of my problem I believe I am correct to say that it isn't the '2 second to black' issue. I didn't realized this before but my green power light goes off when the monitor flashes off. So, every 6 seconds the screen flashes off and on again for probably less than a second. When it does the green power light also goes off (and comes back on again).
      As noted earlier I have taken the monitor apart only to find that the capacitors look absolutely perfect (as does everything else). I'm hoping that the fact the power light is also going off/on provides a more definite reason for the problem.
      As always, any direction that can be provided is greatly appreciated. Thank you.
      • retiredcaps
        • Apr 2010
        • 9271
        Mabye check the soldering? If anything looks dodgy, you may want to reflow it.
        Also, it would help if you post pictures in the "preferred" format as described in the guide above (see misc suggestion #1).
        • jay333
          • Oct 2011
          • 6
          I took the monitor apart again and took some pictures. I took a number of photos (front and back of the main board where the capacitors are) and also a front/back picture of the other board in the monitor (where the power and monitor plug into). I am certainly no expert but everything looks quite good to me. And, the capacitors look perfect. Again, the screen goes off for a split second every 6 seconds (when it does the power light goes off as well). Any assistance/advice greatly appreciated. Thank you!
          • retiredcaps
            • Apr 2010
            • 9271
            1) Read this thread by our fellow Canadian, smason.
            https://www.badcaps.net/forum/showthread.php?p=163015
            2) Your board also uses Samxon GF caps.
            Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300. (Refer back to #1).
            3) There are some solder joints that have ring cracks. I circled the most obvious in red. I would touch up all the dodgy looking joints. If the problem persists, then you can try replacing the caps with something like Panasonic FR or FM series.
            • jay333
              • Oct 2011
              • 6
              Thank you so much for your assistance. Can you give me some direction on how to best touch up the joints. I read somewhere where you can reflow such joints by putting the whole board in the oven - doesn't sound like a good idea to me! Should i just reheat each joint with a soldering gun (until it softens) or do i add solder? Thanks.
              • retiredcaps
                • Apr 2010
                • 9271
                1) You can reheat each joint until it goes into liquid state and then remove your solder gun/iron.
                2) You can remove the old solder completely and add new solder.
                3) You can reheat each joint and add a bit of new solder.
                I have done all 3 at various points and I don't have a preference, but some would suggest #2 is the most reliable.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I completely forgot to ask for DC voltage measurements on CN603. If you have a multimeter, measure all the pins on CN603 with respect to ground (say a ground screw).
                  List all the pins and what it says on the legend. Measure each pin multiple times as the lcd goes on/off.
                  • jay333
                    • Oct 2011
                    • 6
                    OK, I have redone many joints on the board. I have also just replaced the capacitors. Unfortunately, the screen still goes off for a split second every 6 seconds (and the power light goes off as well). Any other suggestions that I could look at? Is the fact that the power light also goes off any sort of a clue?
                    • Rtech
                      • Jul 2010
                      • 1095
                      As soon as I see one of these little sub pcb's mounted on the top of a PSU/Inverter,I cringe and approach the 'fault' in a different manner,as these regularly fail, as they carry the Backlight drivers etc. To fault find them is usually not feasible,and to replace them in total...no chance,so I do not change caps as a first immediate action,until I am certain that this PCB sems OK,that means measuring voltages(as suggested by retired caps),ensuring the BL On signal is functional,and removing the power to the sub pcb if possible,and then see if the power lamp stays on.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        The power light is indeed a clue. It would appear the processor on the signal card may be momentarily turning off the power led and inverter. Jay333 has already mentioned checking the BL_ON (or equivalent) signal.
                        Excuse me if you have already done so, but you should also be examining the power line (5V?) to the signal card, the outputs of the LDO regulators on the signal card, and even the reset controller (if any) on the signal card. Don't forget the input signal itself - you may want to make sure it is a plain vanilla 640 x 480 @ 60hz
                        PlainBill
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          I did ask for voltage readings back in post #9 (3 minutes after I answered the reflow question), but perhaps the OP didn't see the message?
                          All the suggestions by Rtech and PlainBill were next on the list of things to examine. It looks like 2 voltage regulators on the signal card. One is -33 and the other is -18.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Originally posted by Rtech
                            As soon as I see one of these little sub pcb's mounted on the top of a PSU/Inverter,I cringe.
                            This is the only case that I remember participating in that had something bad on those little sub pcbs. Luckily we were able to help the OP get it fixed. It too was a Samsung.
                            https://www.badcaps.net/forum/showthread.php?t=10493
                            • Rtech
                              • Jul 2010
                              • 1095
                              Out of qty 10 I have seen,4 of them have been faulty,and not all Samsung.....now you may see why I 'cringe'
                              • jsog
                                • Feb 2011
                                • 220
                                The one Samsung 931B I've worked on had a very similar power supply. That one had a bad inverter transformer.
                                • jay333
                                  • Oct 2011
                                  • 6
                                  How do i go about measuring the voltages on CN603? What is CN603?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Instructions given in post #9. CN603 is the pcb designation on you board. It is the connector.
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
                                    • Chrissygizmo
                                      samsung galaxy ao2s very temperamental after screen replaced
                                      by Chrissygizmo
                                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                      Ive eventually managed to get it on and working but it's very temperamental...
                                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                      05-26-2024, 12:05 AM
                                    • JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                      by JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                      Please help. Thanks in advance!
                                      08-12-2025, 11:45 AM
                                    • Kiberge
                                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                                      by Kiberge
                                      HI guys!
                                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                      04-22-2024, 11:28 AM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
