Help!!! Working on a Dell E171FP LCD
  • ComputerGeek
    • Oct 2011
    • 262
    Hey Guys,
    I just signed up great to have help here. I need help working on A Dell E171FP LCD. It turns on and the backlight lights up however it is a very pink color. And after about two seconds it flickers, and changes to the normal color of the monitor, and one second after than it it just goes black. However, the green light still stays on and if I put a flashlight on the screen and you still can see windows desktop, so the actual panel is still staying on. I have a few pictures of the inverter board below. The power supply looks fine, however I can take pictures upon request. So what should I start testing.
    OH, two red HV caps read
    2A154J
    H2810S
    And the green one reads,
    220uF
    25V
    Nothing looks burnt or bulged, well with the exemption of the clear plastic covering for the inverter board, but I think that's from heat.
    Also, Sorry the pictures aren't the greatest my real camera is broken right now.
    Thanks!
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Help!!! Working on a Dell E171FP LCD
    If the images is a pink/red color that means one or more of backlights CCFL tubes are worn out and need to be replaced.
    • ComputerGeek
      • Oct 2011
      • 262
      But why does it change to its normal color after a 2 seconds. If the HV line was weak wouldn't it cause the backlight to be discolored?
      • PlainBill
        • Feb 2009
        • 7034
        There are two sources of light involved. In normal operation the gas inside the CCFL generates UV light, which activates phosphors on the inside of the tube, which produces the color you see. An old tube produces a red glow inside the tube which initially overrides the glow from the phosphors.
        Shovenose is correct, the initial pink tint is due to a failing CCFL.
        PlainBill
        • ComputerGeek
          • Oct 2011
          • 262
          Ok does anyone know where I can get a set of ccfl lamps? I am not sure of who is a reputable source for this type of thing.
          Also, is this thing even worth fixing, What is this thing worth for resale provided it works?
          • retiredcaps
            • Apr 2010
            • 9271
            Ccflwarehouse.com has good feedback from forum members, but the cost of new ccfls + shipping for a 17 inch monitor will likely be uneconomical to fix. Also, be aware that replacing ccfls is a very delicate and fragile operation. The aforementioned have a tutorial on their website on the steps necessary to replace just bare lamps. Alternatively, you can buy them "pre" assembled/harnessed.
            If you get another dead monitor for free, you can transplant the entire ccfl assembly or just the ccfl lamps. That is what I do instead of buying new ccfls.
            In addition, if I'm patient on watch my local kijiji, I can get a newer working 20 inch or larger widescreen monitor for $20 to $40.
            --- begin sig file ---
            --- end sig file ---
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • OntarioTL
              Dell 5410 greyed out BT
              by OntarioTL
              Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
              If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
              Dell Lattitude 5410
              Service Tag...
              Yesterday, 01:28 PM
            • lalle-
              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
              by lalle-
              Hello!
              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
              08-11-2024, 02:01 PM
            • federalhouse
              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
              by federalhouse
              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
              **Background:**
              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
              **What I've Tried So Far:**
              1. I accessed
              08-01-2024, 07:03 PM
