Lcd CTX X962A dont turn on
  • vaneno
    • Oct 2011
    • 7
    Hello people. This ist my first post here. My english ist not good, so im sorry and try to make it good.
    Im trying to repair a CTX X962A lcd monitor. Its a 19". The monitor make a fast flash led when i plug in to power.
    After diassemble, i have a 5.2V and 14.1V on secondary. And on a single view i can see bad caps like other models, or damage componet.
    I try to disconect all backlight circuit (the board have 6 brigdets to this zone) but havent effect on this.
    Follow this link [URL="https://www.badcaps.net/forum/showthread.php?t=10682"[/URL] i read that "0Z9910GN's VREF should be fixed at +5v" and my 0Z9910GN have 0.5v on vref. but all time i have 14.1V .
    Any ideas or help? thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Lcd CTX X962A dont turn on
    Your english is fine, better than most who post here.
    "2 seconds to black" is what it sounds like you are describing. If yes, see
    2 seconds to black can be
    a) bad caps
    b) bad inverter transformer
    c) bad ccfl and/or ccfl wiring
    More details about 2 seconds to black can be found in posts #13 and #14 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    It would also help if you post pictures following the instructions as per misc suggestion 1 (in the same URL above)
    --- begin sig file ---
    --- end sig file ---
    • vaneno
      • Oct 2011
      • 7
      Thanks for your help.
      I read on this thread interesting info. Next days i post photos and results on this boar.
      • vaneno
        • Oct 2011
        • 7
        Hello again.
        I attach the pictures of board.
        On power board, after some checks i can't find something worng. I replace 4 caps to test but nonthings happend, so i decide to change and put the original again. I try to remove bridgets to inverter circuit. (i open 5 wires on left of big cap 100uF - 450V). This isolate the inverter zone.
        The 5 wires are:
        1 for Vcc (14vcc)
        2 for GND
        1 for "on/off"
        1 for "brightness"
        I only have 14 Vcc and 0v on "brightness" and "on/off" . I supposse than the scan board turn on the inverter with a continuos ttl signal, and manage brightness with a variable voltage between 0v-3.3v . Its this correct?
        I also remove the audio-amp (tda7496lk) with similar method in my test whit no result.
        Led and buttons in power board connects direct to scan board trought pins-conector. It also have 5.2v to main power of the scan board.
        In this point, i think that the fails its on scan board. And on scan board i change 4 caps (100uF-16v). No results.
        I check 2 voltage regulators, labeled as U101 and U102. Its a AS1117L-33 and AS1117L-18 respectively. The U101 outputs 3.3V , and the U102 output 1.2V , so i understand that maybe here its my problem.
        Next days i try to change this componet and continue with this thread.
        • retiredcaps
          • Apr 2010
          • 9271
          The logic board turns the monitor on/off by changing the voltage between 0 and something larger than 3.0V.
          U102 should read 1.8V DC output so you are correct that U102 is bad. The suffix -18 tells you the correct output.
          • vaneno
            • Oct 2011
            • 7
            Solved
            Finally, after ten minutes searching on my old-damage hardware i take an AS1117L-18 from a damage livebox-router (other manufacturer).
            After change i test again and now i have 1.8V.
            ...and this is my results :
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • RdeveLabs
              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
              by RdeveLabs
              To all the members here...
              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
              05-05-2025, 04:59 AM
            • robante15
              Acer Aspire 4520 won't turn on after reboot
              by robante15
              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
              If I remove the...
              04-06-2024, 06:50 PM
            • masoksian
              Dell latitude e7470 not turn on .power buton on off and Run Power problem
              by masoksian
              I am dealing with the problem of turning on and off my Dell e7470 notebook.
              The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
              The system does not turn on, there is no post.
              I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
              The problem continues in the same way.
              I tried to turn on the Fn key, nothing came to the screen....
              02-15-2025, 12:08 PM
            • dqtech
              lenovo x240 nm-a091 wont turn on
              by dqtech
              i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
              board number VIUX1 NM-A091 REV:1.0...
              02-07-2024, 01:57 AM
