Dell 1703 FPS Board # 79044120 Dead no life #2
    • Jul 2011
    • 6069
    This the same board as the other post how ever this one has more problem with it
    • Jul 2011
    • 6069
    Re: Dell 1703 FPS Board # 79044120 Dead no life #2
    Need to what is the real value R858
    One R858 is open which is next to U850
    Also every thing work but only if you have two power supplies one 12 volt and one that 4.5 volts then you see it work
    • PlainBill
      • Feb 2009
      • 7034
      What are the color bands on the resistor?
      PlainBill
        • Jul 2011
        • 6069
        This a SOP chip and I can not read the numbers
        I made a mistake in model # it is not E1703 it is a E1706
        How ever I have both models
          • Jul 2011
          • 6069
          The only way that I will know for sure what the value of this resister is IF i can get one of these board to work ONE note I do not have any CLF tube that good for these two monitor at this time I do have two other screen that do have good CLF tubes
          Like said in the other post I know this board has more problem I may just use this one for parts IF I do this I will cut the inverter board part off the main part of the board and use it to test CLF tube
            • Jul 2011
            • 6069
            I WILL use this one for parts IF I do this I will cut the inverter board part off the main part of the board and use it to test CLF tube
            It' getting cut apart SOON
            • AdrenalinTL
              Dead Dell Board
              by AdrenalinTL
              Hi Guys,
              Back again with more learning to do. I would like to start fresh and not confuse myself by looking through different posts.
              I have a Cedar Intel Board that is dead. 13269-1 - Seen a few dead boards here on here.
              So pls bear with me and let me know if what I am doing is half right as a starting point.
              Pin 1 through to Pin 3 measures 19.68V
              Pin 4 measures 0.17V
              Pins 5-7 measure 0
              This below component as well as the area around it worry me though. Almost looks like it was removed and replaced skew?...
              06-25-2024, 02:59 AM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • k370
              Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
              by k370
              I have a NM-A321 board that is dead, with no power at all.
              When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
              With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
              • +3VALW
              • +5VAUX
              • 1.2VSUS_PWRGD
              • 3VALW_PGD
              • 1.05VAUX_PWRGD
              Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
              The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
              09-23-2024, 11:57 AM
            • Garret Matt.
              DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
              by Garret Matt.
              I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
              Thank you in advance for any assistance you can render.
              Inductor In question. Buzzes like...
              06-20-2025, 01:21 PM
