Dead Dell Board
  • AdrenalinTL
    • Apr 2024
    • 57
    • test
    Dead Dell Board
    Hi Guys,
    Back again with more learning to do. I would like to start fresh and not confuse myself by looking through different posts.
    I have a Cedar Intel Board that is dead. 13269-1 - Seen a few dead boards here on here.
    So pls bear with me and let me know if what I am doing is half right as a starting point.
Name:	Dell 13269-1 Ver 1.jpg
    Pin 1 through to Pin 3 measures 19.68V
    Pin 4 measures 0.17V
    Pins 5-7 measure 0
    This below component as well as the area around it worry me though. Almost looks like it was removed and replaced skew? I used a hot air station to clean it as best I could. Result below.
Name:	Dell 13269-1 Ver 2.jpg
    Yeah so again, I am very new to this and just want to find my way around some practical solutions instead of just buying new boards.
    Thanks for the help.
  • mon2
    • 14239
    Post a higher grade pics for inspection. Also from each angle of the component to view each SMD pad.
    Flux the part well and use the hot air tool in a circular motion from the top side. Low air pressure but high heat. Protect the coincell battery by removing it and placing kapton tape to prevent the plastic holder and other nearby parts from melting from the hot air tool. Eventually, this QFN packaged part will swim into place. Inspect each solder pad for shorts and there are any, remove the shorts but fluxing the area and removing the excess solder with desoldering braid.
    • AdrenalinTL
      • Apr 2024
      • 57
      • test
      Yeah did all that. Some pins just look like they have corrosion on still.
      Best pics I can get.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Do you have any voltage on PL4501/4502? The 4th pin in dc jack is the PS_ID and should be 3.3V but that requires that you must have voltage on PL4501/4502.
        The ic which is corroded is not relevant for booting-you can even remove it for the time being as thats the audio IC.
        • AdrenalinTL
          • Apr 2024
          • 57
          • test
          cool
          yeah 0 voltage on 4501 and 0,56 on PL4502.
          Guessing that's not right.
          • AdrenalinTL
            • Apr 2024
            • 57
            • test
            Alrighty then.
            Obviously one or both PL4501 and/or PL4502 are faulty.
            Few questions:
            * Where does one buy a replacement? AliExpress has a few 2R2s but they have no codes after that. Any will do?
            2R2 full code is 2R2 547 E86. 3R3 full code is 3R3 545 R51. Obviously these mean something but google searching gives me few and far between answers. From google I can now ascertain these are inductors for Power.
            * Presume one just solders these off and on again?
            * Can 1 be faulty and the other not? e.g. Can the 5V feed the 3V one? None of them appear to be cracked or anything like that.
            • reformatt
              • Feb 2020
              • 1413
              PL4501/4502 are inductors, very unlikely to be faulty. They should measure low ohms on a meter. An inductor coil would only ever be faulty if it has shorted turns or is open circuit, something very unlikely in a buck converter like this one. If you have no voltages on the output of these coils, it's generally either because you have a short on the output, or the converter isn't being enabled.
              To troubleshoot these kinds of things, you need a methodical approach to troubleshooting. On pg 98 of the 13269-1 schematic, you have a power sequence diagram. The negative numbers on it list the sequence of voltages/enables before the power button is pressed. For example, to get 3D3V_S5 and 5V_S5 (-2) you need S5_Enable (-3) from the EC. But for the EC to be working, you need to the LDO voltage 3D3V_AUX_S5 (-4) from PU4503. For that to be working, you first need DCBATOUT (-5) to be present.
              In a nutshell, if a voltage you expect is missing, you first check that rail for a short circuit to ground (with board unpowered), or check whether that voltage is being enabled, and work your way back.
              • AdrenalinTL
                • Apr 2024
                • 57
                • test
                OK thanks. Will have a poke around and see what I can figure out.
                learning
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Resistance to GND on pin3/13 of PU4503
                  Resistance to GND on PL4501/4502
                  During measurements, no power attached. If you just removed the adapter,wait for a minute and then proceed to do the measurements.
                  • AdrenalinTL
                    • Apr 2024
                    • 57
                    • test
                    During measurements, no power attached. If you just removed the adapter wait for a minute and then proceed to do the measurements.
                    pin 3 - 0
                    pin 13 - 0
                    PL4501 - 0
                    PL4502 - 2.71
                    • reformatt
                      • Feb 2020
                      • 1413
                      Pin 3/13 are the +3V and +5V LDO outputs of PU4503. These are 0 ohms to ground? PL4501 (+5V_PWR) is 0 ohms to ground? PL4502 (+3V_PWR) is 2.71 what? Ohms, Kohms, Mohms?
                      • AdrenalinTL
                        • Apr 2024
                        • 57
                        • test
                        pin 3 - 0 ohm
                        pin 13 - 0 ohm
                        PL4501 - 0 ohm
                        PL4502 - 2.71 ohm
                        No power attached.
                        Pretty sure I did it right. The pins on PU4503 are pretty small but after testing them I kept the ground on the same place and then tried another component and it did measure ... I did it 3 times as well. Measured PL4501 and 4502 quite a few times as well because as you said before, it's unlikely that they are faulty.
                        I will let you know what exact ohms and test again this evening if I have time. Work just has me flooded right now hence the delays in responding.
                        • reformatt
                          • Feb 2020
                          • 1413
                          In my experience, multiple shorts on different rails generally means something catastrophic happened on this board. A voltage overload on a rail (like getting 19V on a 3V rail because of a high side MOSFET short), there's often multiple components that will fail. Some boards just aren't economical to repair in that event.
                          You will have to start removing components (or use voltage injection/thermal camera) to remove the shorts on those rails.
                          • AdrenalinTL
                            • Apr 2024
                            • 57
                            • test
                            Thanks,
                            Yeah I was going to use this as a test board to learn about the various schematics and things but it looks like it either had water damage, or like you said someone shorted it with a dodgy charger or similar. Wouldn't put it past the guy I actually got it from.
                            Will perhaps scrap it and use another board as a test. I don't have the machines for voltage injection etc.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • k370
                              Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                              by k370
                              I have a NM-A321 board that is dead, with no power at all.
                              When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                              With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                              • +3VALW
                              • +5VAUX
                              • 1.2VSUS_PWRGD
                              • 3VALW_PGD
                              • 1.05VAUX_PWRGD
                              Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                              The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                              09-23-2024, 11:57 AM
                            • Garret Matt.
                              DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                              by Garret Matt.
                              I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                              Thank you in advance for any assistance you can render.
                              Inductor In question. Buzzes like...
                              06-20-2025, 01:21 PM
                            • master3112
                              by master3112
                              07-29-2025, 01:55 PM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
