Moved-Viewsonic VG2021m Blue flashing PLED no image
  • Medlock
    USN Salmon 573
    • Sep 2011
    • 26
    Re: Moved-Viewsonic VG2021m Blue flashing PLED no image
    I finally found the schematics...I have seen some references to eprom reset
    for other models but not for 2021.
    Your submission could not be processed because a security token was missing.
    could not upload them!
    • Medlock
      USN Salmon 573
      • Sep 2011
      • 26
      Converted from PDF tp JPG
      • Medlock
        USN Salmon 573
        • Sep 2011
        • 26
        Hi Folks,
        Well i tried every concievable combo of button pushing and holding with the power unplugged then holding and plugging etc etc...no change..not surprised, if it were that easy I would have contemplated shooting myself in the foot...
        • PlainBill
          • Feb 2009
          • 7034
          Originally posted by Medlock
          Hi Folks,
          If you have good SMT desoldering skills (or ChipQuik), remove U7. That SHOULD be the chip that stores the settings data. If the monitor works, you have isolated the problem.
          PlainBill
          • Medlock
            USN Salmon 573
            • Sep 2011
            • 26
            Hmmmm
            Well I could go that route however a few reasons will keep me from that.
            1. I can jumper pin 1 and pin 4 (Ill have to verify which pin(s))
            and clear it. I really dont think its that simple of a problem.
            2. I have now invested 35$ in a new invt/power board, 15$ in caps,
            13$ in a new chipquick set up, and couple of bucks for regulators.
            The new signal board only cost 30 bucks and its local.
            My fault as I started shotgunning before I came here but I really was
            convinced this was a power board problem and with the buldging caps
            as evidence I was confident that it was damaged.
            3 If i had ANYTHING that showed life in this rig I would be happy.
            I have a PLED that is on immediatly.
            I don't need to even touch the power button.
            That to me sounds like a short.
            Also As I have stated U4 on the sig board is over heating and voltages are once again becoming irratic,
            that too sounds like a short.
            The inver/pwr board won't even give me backlights for even a second.
            That sounds to me like it is not recieving the proper signal voltage for power up.
            I am trying to figure out which pin of the 16 (or where ever)
            is the one where this signal is supposed to be.
            My schematic reading is crappy,
            I'm blind in one eye and can't see out the of the other..Ha!
            and this was always my sore spot during my illustrious career in the service.
            Anywho if I could be sure this is only a vid signal PCB problem I would just go and get it,
            but I dont want to throw any more major parts at it
            unless I can be 'reasonably' sure thats what the problem is.
            I am having fun diagnosing and conversing with knowledgable people
            and getting the ole brain matter stimulated, however I would like to get back to my art/video work soon.
            As are many folks I'm so broke I can barely pay attention
            so buying a new lcd is not possible.(not till tax refund time anyway)
            so if you folks can enlighten me as to which pin and the voltage the inv/pwr
            pcb is looking for I would appreciate it...
            or if you think I am way off target and could point me in a better direction
            that too would be appreciated.
            Good evening to ya
            Joe
            • PlainBill
              • Feb 2009
              • 7034
              OK, good luck.
              PlainBill
              • alexanna
                • Mar 2010
                • 1346
                #27
                Like you suggest I think you have a short causing the U4 to heat up and causing unstable voltages,The new logic/signal board would probably be your best bet.
                On the 16 pin connector bottom row the ENA pin voltage will go high when back lights are requested,You had called it EVA.
                Do you have any schematics of the inverter/PS supply?It may tell us what voltage to expect to see.
                • PlainBill
                  • Feb 2009
                  • 7034
                  It's on the first page of the schematic Medlock provided. CN4, pin 15 on the signal card is the inverter On/Off control line. It's pulled high through a 10K resistor tied to the 3.3V rail on the signal card, and pulled to ground by a FET, Q2. Brightness has a similar arrangement.
                  PlainBill
                  • Medlock
                    USN Salmon 573
                    • Sep 2011
                    • 26
                    #29
                    Morning everyone
                    ok today I briefly jumped U6's 3.2 volts to the EVA (thats the actual letters) pin and tada BACKLIGHTS!
                    So I am going to go ahead and get the board. I traced the short to the main chip on the signal PCB. I think I lost the PCB to the power annomaly we had recently, where we didn't lose power completely but we had a low voltage situation for about 2 hours. I had run around the house turning off all he surge protectors but forgot that the monitor was on a separate one all to itself.
                    I will return to update and to hopefully close out this thread. Thank you all for your help and I will be sure to come back if I need any help with other things. Also I will spread the word to others.
                    I have a samsung 46" LCD TV that went kuput last month. This model like many others from samsung was on a recall for....bad caps. Fixed for free. If this is something that you all were not aware of, I'll start a thread with the makes and models involved.
                    Thanks again and I will type ya soon.
                    Joe
                    PS i have a new 12m033 power inverter for sale ....LOL!
                    • Medlock
                      USN Salmon 573
                      • Sep 2011
                      • 26
                      #30
                      Hiya Gang
                      a quick question while I wait for my board, due here today.
                      While working with the other power board and old signal board, (still trying to narrow down the short), I blew (or it blew) the 5 volt rail fuse on the pwr/invr pcb. I followed Alexannas link for the regulators and tried like heck to search that fuse package. I could not find it. Can you give some data on that SMD please. Its the one right off the 5v rail at the 16 pin connector marked with a 'W'.
                      PS would like to add the PDF service manuals here but I keep getting a Security Token error.
                      • Rtech
                        • Jul 2010
                        • 1095
                        #31
                        A 'W' signifys 4Amp.
                        • alexanna
                          • Mar 2010
                          • 1346
                          #32
                          Check this one out. don't pay attention to the F in the illustration.
                          http://search.digikey.com/scripts/Dk...206F400-2CT-ND
                          • Medlock
                            USN Salmon 573
                            • Sep 2011
                            • 26
                            #33
                            Thanks for that info I ordered a few of them just to be sure.
                            So the video board arrived and the monitor is back in service.
                            However if by chance anyone who reads this and decides to order a signal
                            board, make sure you check all reference numbers not just the PCB hash
                            numbers.
                            For instance:
                            A190A2-A02-H-S1 Fits many different LCD models but not yours in particular.
                            There are other reference numbers on the board which will I dentify your
                            model. THis one is on a sticker that has a barcode on it with the numbers
                            19A2LSH000 this number identifys your particular model number.
                            This is important when dealing with plug n play type LCD's. It can send the
                            wrong info to the video adapter. Such as refresh and resolution maximums.
                            Also the Model number to a lesser extent.
                            Beats me to why they would use the same exact part numbers on the PCB's
                            Makes more sense to have individual numbers per model. Gets confusing when
                            the description of the part says it fits many more models than shown.
                            The prices vary also, thats where I got caught. One was 29$ and the other 35$. So of course I ordered the cheaper. BURNED myself. The guys where I
                            purchased it were cool about it and are going to exchange it for me.
                            However many places won't do that for a 'tinkerer' and not a legitimit service
                            tech.
                            All in all it was educational and will be sure to check Caps and check here for
                            info as other things come my way.
                            PS still cant upload the entire service manual in PDF form.
                            End Thread------
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Think about it. Some firm buys 'unstuffed' pc boards that will be 'stuffed' with components to make signal cards. They supply signal cards that can be used to make monitors with anywhere from a 3 x 4 17" LCD panel to a 9 x 16 23" panel. An audio amplifier is optional. VGA is standard, a DVI connector is an extra cost option. They can support a wide range of LCD panels with varying resolutions.
                              Why on earth would they want to stock dozens of raw boards when they can stock only one? In particular, support of different panels and resolutions is handled in firmware. It may even be possible to load a base firmware on all finished boards and handle the customization at test!
                              PlainBill
                              • Medlock
                                USN Salmon 573
                                • Sep 2011
                                • 26
                                #35
                                Right I get that part, but why not use the 'sticker' part number when selling these boards rather than the PCB part number alone and then just refer in the description what monitors they may fit.
                                Or in this case list just one monitor with a note that it may work on many others. Thier Catalog showed upteen listings of the same PCB part number
                                with the same picture and different prices.
                                In the manufactoring of it, what your saying makes perfect sense, but at the resale level, it leads to confusion. No where was there a reference to
                                the barcode number, just a list or a single reference to a model number.
                                It may well have been just this particular reseller that catalogs this way, I
                                made mention of the fact they don't list a version or barcode number
                                anywhere in the description. Also the OSD buttons were not working correctly. Number one was 2 and up and down were reversed etc etc,
                                Anyway it worked out, a learning experience all the way to the end.
                                Have a good evening
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Have a good evening
                                  Welcome to the real world. I have worked for a number of companies, and I swear they go out of their way to make the numbering systems chaotic.
                                  Perhaps the most outrageous was IBM. Of course, every PC board had the part number of the bare board. There was also an assembly number. And there was a FRU number - which in theory was a number which was used to order a replacement board - which might have completely different numbers than the failed board. To further drive everyone insane, in development each product was assigned a name. For example, a particular SCSI controller was a 'Spock'. But it wasn't used in the 'Enterprise' family of computers.
                                  PlainBill
                                  There is one primary reason the resellers use the board number - you can be sure all boards will have that number.
                                  • Medlock
                                    USN Salmon 573
                                    • Sep 2011
                                    • 26
                                    #37
                                    I guess this will be my final post.
                                    Its been a few days and the monitor is working flawlessly.
                                    I really like viewsonic products and before this one gave me
                                    trouble it was well into its lifespan. I would have gotten away
                                    with just the cap repair and the signal board. I ended up with a 'new'
                                    power/inverter. I went with my repaired Pwr/invtr because it has the
                                    superior components. Its output at the 12 and 5v rails were stronger
                                    than the new. 11.87 / 4.93 vs 11.98 / 5.04, not allot, but if I had to
                                    just look at the stats....
                                    Anyway thanks for the help, it was well worth the money and time spent.
                                    • commanderkeen
                                      • New Zealand
                                      #38
                                      Have you tried to download these schematics at http://www.eserviceinfo.com/download...c_VG2021m.html
                                      ive found the first 2 files work but the last one was corrupt.
                                      • learnmore
                                        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                        by learnmore
                                        Hello Community!
                                        CASE DETAILS
                                        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                        Tried inserting firmware on USB and left it in for a few hours, but no change
                                        03-03-2024, 09:49 AM
                                      • Focus2005
                                        HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                        by Focus2005
                                        Hello everyone.
                                        I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                        05-01-2025, 05:41 AM
                                      • STKR123
                                        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                        by STKR123
                                        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                        I wonder if re-flashing the BIOS might be of any use here.
                                        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                        11-03-2024, 06:58 AM
                                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-12-2024, 02:20 PM
                                      • Jaime Morillo
                                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                        by Jaime Morillo
                                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                        The TV was stuck on the logo and I couldn't access the update menu.
                                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                        The image result was good, but the image is inverted.
                                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                        08-18-2025, 11:38 AM
