Noisy component in the Dell U2410
  • wenp
    • Aug 2011
    Dell U2410 monitors (not all?) hum loudly when the brightness is reduced below about 78%. Dell claims this is not a defect, but the nearly identical U2711 does not have this problem.
    I have a Dell U2410 rev. A04 with the LG panel module LM240WU4. When I opened the monitor, I found there to be three sources of sound. The main power-supply board and the inverter board both emit a faint hiss that I could not hear when the monitor was assembled. The loud buzzing appears to be within the LG panel, on the right side, just where the middle CCFL tube terminates.
    Getting into that area would be a lot more work. Also, I wouldn't be able to run the unit to produce the noise. Any ideas on what the problem might be or how to test it?
    One thing I did consider is a bad component on the inverter board. With extra wiring, I swapped around the CCFL tubes to different transformers. The noise always stayed in the same place.
    Also, I'd appreciate any info on how the relevant parts of the U2711 differ from the U2410.
  • wenp
    • Aug 2011
    Re: Noisy component in the Dell U2410
    Silence...
    Could somebody at least describe what is typically found inside that part of the panel unit?
    Is there a service manual available for the U2410?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Seen this before on a few other monitors - it's likely the CCFLs themselves making the noise.
      Due to manufacturing tolerances one of the lamps touches the screen frame. Because the PWM dimming is done at low frequency (typically 120Hz), this may cause the lamp to vibrate, this is then transmitted to the frame and casing, resulting in an objectionable buzz noise.
      A working TV? How boring!
      • Krankshaft
        • Jan 2007
        • 2328
        Wouldn't it also be possible that the inverter transformer secondary windings are vibrating?
        • wenp
          • Aug 2011
          I understand that is sometimes the case. Here, I had carefully checked for sound and vibration from the transformers on the inverter board. They emit only a faint hiss and I can't detect any vibration.
          • alexanna
            • Mar 2010
            • 1346
            You may have to,Dissemble one Panel down to the metal frame and the CCFLs channels. Then just plug in the CCFLs to see if you can isolate the noise.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Unfortunately in my experience it's been more often the lamps than the inverters. The inverters or power supply can be quieted by brushing on a layer of clear lacquer and allowing it to dry before the thing is re-assembled.
              • wenp
                • Aug 2011
                ...it's likely the CCFLs themselves making the noise...this is then transmitted to the frame and casing, resulting in an objectionable buzz noise.
                This turned out to be approximately the case.
                Inside the panel is very simple. A thin plastic bracket along the side of the back holds in place a series of rubber sockets. The back side of each socket takes a prong from the inverter board and the front side takes a CCFL lead. I guess the main source of the noise is the bracket transferring vibration to the aluminum back.
                I doesn't look like there is room for any vibration damping material. Not sure what I'm going to try.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Asxetos21
                  Dell Latitude 5511 audible electrical noise
                  by Asxetos21
                  I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                  The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                  Any advise on how to narrow it down?
                  The schematic is available here:
                  Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                  03-03-2025, 09:53 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                  Dell Thunderbolt Firmware
                  by SMDFlea
                  Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                  Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                  The SKU is in brackets (****)
                  EDIT: NVM65...
                  01-26-2025, 06:22 AM
