Samsung 2493 HM issue
  • alexanna
    • Mar 2010
    • 1346
    #61
    Re: Samsung 2493 HM issue
    Originally posted by zulururu
    Is it a question for me ?? if yes, my DMM doesn't have a capacitor range .....sorry !
    Not exactly, I got the threads mixed up.
    I am not really sure where you are on you monitor, I guess the point I was trying to make was there have been several failures of that capacitor. It sure wouldn't hurt to check the capacitance of it, and if the equipment on hand is unable to test it, I tried to give several suggestions on how to get it tested without spending a lot of money.
    • zulururu
      • Aug 2011
      • 43
      #62
      Ah ok Thanks Alexanna !
      I ordered an SMPS controller on August 19th apparently, it's coming from Australia and I still did not receive it, so as soon as I install it, I will let you know if that worked, if not, I will try to check that capacitor !
      Thanks for the heads up though !
      Cheers,
      • zulururu
        • Aug 2011
        • 43
        #63
        After more than a month, I've finally received my SMPS controller ... but after installation, unfortunately, my monitor is still not working .... I still don't have 5.3v or 24v ....
        Do you have anymore suggestion ?
        • PlainBill
          • Feb 2009
          • 7034
          Darn!!! I had temporary access to another BN44-00195A and made some measurements with the supply operating. Here is the comparison. As you can see, they are very similar. Unfortunately, I did not make measurements on other points on the board, and no longer have access to that supply.
          Pin Yours Other one
          1: 5.05v / 5.08V
          2: 5.05v / 5.08V
          3: 2.54v / 2.55V
          4: 0.00v / 0.00V
          5: 5.08v / 5.11V
          6: 0.07v / 0.07V
          7: 0.07v / 0.07V
          8: 5.04v / 5.08V
          9: 14.60v / 11.90V
          10: 0.00v / 0.00V
          11: 0.19v / 0.19V
          12: 14.06v / 11.30V
          13: 0.00v / 0.00V
          14: 0.27v / 0.25V
          15: 15.06v /12.2V
          16: 5.04v / 5.07V
          The next thing to test is CM812. I know your DMM does not have a capacitance function, so pull CM812, set your DMM to the 20 Megohm range, and touch the probes to the cap. You should get a reading that increases, eventually going open.
          PlainBill
          • zulururu
            • Aug 2011
            • 43
            #65
            Thank you Plainbill, I will measure that, also my DMM doesn't have capacitance function, I discovered I have one at work I can use which has capacitance function, should I use that one instead ? If yes, to measure capacitance, should I desolder CM812 or there is no need for it ??
            • zulururu
              • Aug 2011
              • 43
              #66
              Hello again, I did the measurements with pin 4 as the ground and I have the same results +/-0.02v.... I will be waiting for your answer about CM812 and check it tomorrow .
              Have a good day,
              Zulururu
              • PlainBill
                • Feb 2009
                • 7034
                Have a good day,
                Zulururu
                How about this - try checking it in circuit. If it reads 12nF +- 5%, it's good. If it reads anything else, pull it and check it out of circuit.
                PlainBill
                • zulururu
                  • Aug 2011
                  • 43
                  #68
                  I had to desolder to have a correct reading and I have 11nF so I guess it's good....
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Darn!!! Well, I'm going to go out on a limb and say that everything up to the driver transformer is good. As is my habit, I've marked up a picture.
                    Six areas of interest are circled, and lettered A-F. Standard precautions apply - don't electrocute yourself. Make sure any resistance measurements are made with the power off, any voltage measurements are made with the power on. You can use either the signal card or a 3.3K resistor to turn the main supply on.
                    F is a resistor, it is the resistor standing on end; it provides power to the transformer primary drivers. With power OFF measure the resistance.
                    E is a capacitor. With power on, measure the voltage across it.
                    A is the small transformer which isolates SMPS controller from the main FETS. Each yellow circle encloses the ends of one winding. Check for continuity of each winding.
                    D is the primary of the main SMPS transformer. Check continuity.
                    C are the main drive FETs. Check for shorts.
                    B Is a number of transistors and diodes that handle level shifting. Check for shorts.
                    PlainBill
                    • alexanna
                      • Mar 2010
                      • 1346
                      #70
                      Here is another long shot! But it won't take long to check.
                      If my memory serves me correctly, on the other style Power supply the 24volt rail had to come up before the 5.3 volt would start.
                      I don't know if this has been tried, but I wonder if there is a problem with the 24V within the inverter causing the second half of the power supply to shut down.
                      Have you tried this with the inverter unplugged? See if the 24 and 5.3 Volts comes up.
                      • zulururu
                        • Aug 2011
                        • 43
                        #71
                        Thanks for you help !
                        Just to make sure, when you say "check for shorts" do I have to check for a resistance which mean with power off and in between 2 poles or between a pole and the ground ....or does it mean check for voltage between 2 poles or again between the pole and the ground ?? Excuse my ignorance !
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #72
                          Checking for shorts (i.e. resistance) is always done with power off. Any resistance reading under 30 ohms suggests the component is shorted. If it is a 3 pin component, measure pins 1-2, 1-3, 2-3 (all possible combinations).
                          --- begin sig file ---
                          --- end sig file ---
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Retiredcaps description is correct. When I say 'continuity', it means two points (in this case, the ends of a transformer winding) should be connected.
                            PlainBill
                            • zulururu
                              • Aug 2011
                              • 43
                              #74
                              Thanks again for the explanation !
                              I did the measurements, Here are the results:
                              A/ all around 0.7 ohm
                              B/ As per the picture below:
                              For the 2 upper ones
                              Between pin 1-2: 23,4 ohms
                              Between pin 1-3: 23,4 ohms
                              Between pin 2-3: 0.5 ohm
                              For the 4 lower ones:
                              Between pin 1-3: no continuity (infinite)
                              Between 1-2: no continuity (infinite)
                              Between 2-3: 0.5 ohm
                              R1: 22.5 ohms
                              R2: 22,6 ohms
                              R3:22.6 ohms
                              R4: 22.5 ohms
                              C/ As per the picture below
                              Between 1-6: 23 ohms
                              Between 2-5: 0.7 ohm
                              Between 5-4: 23 ohms
                              D/0.7 ohm
                              E/ O volt
                              F/ 6590 ohms
                              Alexanna, I tried to unplug the inverter board, with the signal card plugged in though and I don't have +24 v but around 0.05V, same results with the inverter plugged in...
                              Even if my monitor doen't work, I'm still learning a lot of stuff ;-)
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                There are 2 FETs in area C. If my weak spatial mapping skills are correct, 1, 2 and 6 is one, 3, 4, and 5 is the other (as per PlainBill's numbering).
                                So you want to measure resistance (power off) between
                                1-2, 2-6, and 1-6.
                                3-4, 3-5, and 4-5.
                                You should have 6 readings.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  That is reasonable.
                                  R1: 22.5 ohms
                                  R2: 22,6 ohms
                                  R3:22.6 ohms
                                  R4: 22.5 ohms
                                  All of these are reasonable. The three legged components are actually dual diodes and zener diodes, I believe.
                                  Please remeasure per retiredcaps suggestion.
                                  D/0.7 ohm
                                  This is reasonable; it's a transformer winding.
                                  E/ O volt
                                  F/ 6590 ohms
                                  These are mistakes on my part. Of course, the resistor is E, and I would like you to measure the resistance (power off); the capacitor is F, and I would like you to measure the voltage across it (power on).
                                  PlainBill
                                  • zulururu
                                    • Aug 2011
                                    • 43
                                    #77
                                    Oups, Sorry about the measurement of area "C":
                                    1-2, 2-6, 5-3 and 3-4 gives me all no continuity (infinite resistance)
                                    - "E" gives me 0.6 ohm
                                    - "I" gives between 3V and 9V DC constantly changing .....
                                    • zulururu
                                      • Aug 2011
                                      • 43
                                      #78
                                      Oops, here comes something else, I juste checked for voltage on the big 450V 82 uF capacitor for voltage and, power On as well as power Off I have the same voltage 163V ( I used to have 378V with power ON, 163V with power Off)..... did I do anything wrong ?
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Possibly. I have been unable to locate a schematic for this power supply, however the design is identical to the BN44-00214A in this thread.
                                        I've being called away to fix dinner; I may not be able to get back to this tonight.
                                        PlainBill
                                        • zulururu
                                          • Aug 2011
                                          • 43
                                          #80
                                          Don't worry PlainBill, take your time and Bon appetit ;-)
                                          • Kjell
                                            Samsung Series 9 - BIOS issue
                                            by Kjell
                                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                            08-01-2025, 09:15 AM
                                            09-07-2024, 05:50 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            08-24-2025, 03:47 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
