Samsung 2493 HM issue
  • zulururu
    • Aug 2011
    • 43
    #41
    Re: Samsung 2493 HM issue
    First of all, thank you very much for the explanation on the resistors, and the more I look at my 487 ohm resistor, the more I see an 4R7 ! So this one seems to be good !
    I measured the resistance between the circled components, I labelled them from the lower left corner 1, then clockwise 2 is the to pin, 3 is the right one.
    For the component circled at the top of the picture, I've found:
    between pins 1 and 2: 21300 ohms
    between pins 1 and 3: 4 ohms
    between pins 2 and 3: 21300 ohms
    For the component just under the first one
    between pins 1 and 2: no reading (1 on the left of my DMM screen)
    between pins 1 and 3: 9960 ohms
    between pins 2 and 3: no reading (1 on the left of my DMM screen)
    Unfortunately I don't see any letter on these components, however I don't have a magnifier :-(
    • PlainBill
      • Feb 2009
      • 7034
      4 Ohms would mean a base-emitter short. That would indicate a problem, unless it's deliberate. More on that later.
      I've looked at four pictures; in some of them I swear I can see letters, in others - nothing. I also cannot be sure just what the connections are; in some of them the lower transistor is the only one connected; in others both are. You know what that means, don't you.
      Yes, I've marked up the picture again. Pin 11 is marked with a crudely drawn black arrow. There are two areas of interest.
      To the right is an area circled in red. At the top of the circle I have placed a red dot on one point. Check if that point is connected (less than 5 ohms) to pin 11. If it is not, ignore that area.
      Below pin 11 I have circled an area in blue. Looking at the upper of the two transistors, it appears there might be a connection between pins 1 and 3. Is that real, or is that my imagination? If it's real, we can stop looking. If it was my imagination, we (you) have more work ahead. I've marked the collector of the lower of the two transistors with a blue dot. Is that connected to pin 11? if it is, is there any connection between the two transistors?
      Ignore the area circled in white. That was a momentary flight of fancy.
      Your profile does not indicate where you are. If you are in the USA, Harbor Freight sells a good magnifying glass for $2.00
      PlainBill
      • zulururu
        • Aug 2011
        • 43
        #43
        I did my homework, First of all, I found a magnifying glass at work !!!
        You are right (as usual ) there are letters on the 2 transistors, on the one on top, I can read "W5", on the bottom one, I think I read "P" or "1P".
        Excuse my ignorance but no, I don't know what that mean when there are connections in some pictures and not on others !
        I measured the resistance between the red point and pin 11 and it doesn't seems to be connected (1 on the left side of my DMM screen in every range mode)
        I also do not find any connections between pins 1 and 3 of the upper transistor, however between the blue dot and pin 11, I found a resistance of 4 ohms.
        Using the DMM again, I found a resistance of 4 ohms between pin 1 of the upper transistor and pin 1 of the lower transistor so somehow, there are connected together !
        • PlainBill
          • Feb 2009
          • 7034
          I suspect your DMM leads have an unusually high resistance. Try shorting the probe tips together with the meter on the lowest resistance range and see what reading you get.
          That is a peripheral issue, however. I've taken this as far as possible. I have been unable to even tentatively identify either of the transistors. Between the lack of a schematic and the inherent problems identifying semiconductors by their marking codes, I am at a dead end. I THINK the MC33067P has failed, but I can't be sure.
          I see two possible approaches. An eBay seller in Malaysia has the MC33067P available for $8 + $6 shipping. Also, several sellers in China have the complete (used) power supplies for $54 with free shipping.
          PlainBill
          • pamr4
            • Mar 2011
            • 21
            #45
            Please measure the 3 resistors placed around the big cap (i think is 82micro 400-450V?). The resistors are supose to be noted on PCB something like RM801, bla bla. Post readings.
            • zulururu
              • Aug 2011
              • 43
              #46
              I shorted my DMM probe and I read 0.4 ohm but I realised I made a mistake when I gave you some value of 4 ohms, it was a misreading and was actually 0.4 ohm ! Sorry about that !
              I measured all the resistors around the big capacitor, here are the results:
              RB801 reading 100060 OHMS vs colour code 10*10000 +/-5% OK
              RB802 reading 97600 OHMS vs colour code 10*10000 +/-5% ok
              RM801s reading 32.7 OHMS vs colour code 330 /10 ok
              RM801 reading 0.6 OHMS vs colour code 228*0.1 problem ?
              RB808 reading 2.4 OHMS vs colour code 2OHMS OK
              RB803 reading 47.4 OHMS vs colour code 47 OHMS OK
              Do you think the problem I have with RM801 is ue to my cheap DMM ?
              My goal if possible is to find the exact faulty component so I guess I will order a MP33067P, I found one here:
              http://www.futurlec.com/cgi-bin/sear...earch=MC33067P
              for 2$ + 4$ shipping, can you confirm that's the right one ??
              If yes, I will order it, the shipping will take 2 weeks !!
              Thanks you all for your help
              • PlainBill
                • Feb 2009
                • 7034
                That's the one. Congratulations on finding it at a very reasonable price.
                PlainBill
                • zulururu
                  • Aug 2011
                  • 43
                  #48
                  Excellent ! I just ordered it for 5.8USD postage include !
                  I will let you know if that fixed it !
                  Thanks you again !
                  Gilles
                  • pamr4
                    • Mar 2011
                    • 21
                    #49
                    Please confirm that the big cap is 82micro. If it is, measure the voltage across the legs of the cap (10 sec) and post reading.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Already done. Note the results in post 21.
                      PlainBill
                      • pamr4
                        • Mar 2011
                        • 21
                        #51
                        Sorry for missing that PlainBill.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          'De Nada.'
                          Now could you explain what you were referring to in your post #45? I've been going round and round these supplies, and between the lack of a schematic, obscured traces, inadequate test gear, and obtuse datasheets, it's been difficult to figure out where the actual failure lies.
                          PlainBill
                          • pamr4
                            • Mar 2011
                            • 21
                            #53
                            'De Nada.'
                            PlainBill
                            Analogy with common power supply failure like 245BW. (when you don't figure it out, excalate the problem, search document findings, etc.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              You were referring to the BN44-0173A power supply. This is a BN44-00195A supply. The standby SMPS controller in the BN44-0173A derives startup power through a series of resistors. The standby SMPS controller in the BN44-00195A is an integrated design, and is connected directly to the rectified mains voltage; it derives startup power internally. What is more, it is working, and the main SMPS controller is receiving power.
                              PlainBill
                              • zulururu
                                • Aug 2011
                                • 43
                                #55
                                Hello all,
                                Just to let you know that I still didn't receive my SMPS controller, so taht's why I didn't update that post yet ! It should arrive soon hopefully !
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Hello all,
                                  Thanks for the information. We're waiting to find out if that will fix it.
                                  On a related subject, what is printed on the cap labeled 'Long Blue Cap' in the attached picture?
                                  PlainBill
                                  • zulururu
                                    • Aug 2011
                                    • 43
                                    #57
                                    On mine it's written on the top:
                                    12 NJ 630v
                                    some kind of a reversed "C" 4 MMKP
                                    On the side of it I can read:
                                    PILKOR
                                    WK0747
                                    I hope this help !
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      12 NJ 630v
                                      PILKOR
                                      WK0747
                                      I hope this help !
                                      Yes, it does. Thank you. Pilkor is the manufacturer, it's a 12nF, 630V, 5% cap.
                                      Now, the $64 question: Does your DMM have a capacitance range? This cap has an equivalent in the BN44-0173A power supply, and is known to fail.
                                      PlainBill
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        #59
                                        The monitor I had where that capacitor failed was the BN44-0173 Board, there was no obvious bloating or burning on the outside of the cap. After removal from the board there was some very slight discoloration of one of the pins where it went into the plastic, it was very hard to see.
                                        If your meter does not have a capacitance reading ability, and buying a new meter is out of the question.
                                        There would be nothing wrong with having someone checking it for you, any heating air condition technician, or if you have small local hardware store ask them to help you out, I would suspect the cost to be minimal if any.
                                        • zulururu
                                          • Aug 2011
                                          • 43
                                          #60
                                          Is it a question for me ?? if yes, my DMM doesn't have a capacitor range .....sorry !
                                          • Kjell
                                            Samsung Series 9 - BIOS issue
                                            by Kjell
                                            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                            08-01-2025, 09:15 AM
                                            09-07-2024, 05:50 AM
                                          • Nairolf
                                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                            by Nairolf
                                            I have a Samsung DM32D display.
                                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                            Here’s what I have tried so far:
                                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                            Today, 03:47 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
