Scratches on LCD screen?
  • alexanna
    • Mar 2010
    • 1346
    This may have been discussed before, But I thought I ask again.
    I have had really good luck using an alcohol single use pad, it doesn't cure them completely but they are less noticeable.
    Anyone else have things that work, or make them less noticeable?
  • smason
    • 1652
    Re: Scratches on LCD screen?
    I read somewhere that a bit of vaseline makes them almost un-noticeable.
    Haven't tried it.
    • alexanna
      • Mar 2010
      • 1346
      The qreat majority of the monitors i get have no problems with any scracthing on the LCD.
      I almost cry when i get a 24" that has scracthes
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
