Viewsonic VX1962WM - Very pixelated, flickering, powers off at random
  • ebol4
    • Jul 2011
    First post here
    My Viewsonic VX1962WM (1680x1050 @ 60Hz, 19") has, for the last week or so, been extremely pixelated, flickering, and powering off randomly. I've owned it for three or four years
    All of these problems occur on every computer I test this monitor on, so the problem lies with the monitor, not any software.
    I've opened up the monitor and disconnected the board, but I'm not sure how to identify capacitor problems, so I took some pictures:
    http://24.21.232.193:25558/monitor
    Some things I'm concerned about:
    In picture #1, there's a lot of clear, darkish glue-like stuff around the little blue things. Is that supposed to be there? Also in picture 1, there's white glue-like stuff around the capacitors; is that supposed to be there?
    In picture #3, the black capacitor seems slightly distended at the top. Is it supposed to look like that?
    Thanks!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Viewsonic VX1962WM - Very pixelated, flickering, powers off at random
    Yes, the glue is supposed to be there. As for pic #3, i can't see anything wrong, you should have made the picture at an angle so that the top of the capacitor could be seen.
    This sounds more like a logic board issue than anything else. Do you have a multimeter?
    A working TV? How boring!
    • ebol4
      • Jul 2011
      Yep, I do.
      • reessi
        ACER BM320 Monitor - Horizonal Flickering Lines After a While
        by reessi
        The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
        They are black on the right and gradually fade to nothing on the far left.
        They start either after 5 mins or up to 2 hours after so annoying for testing.
        They flicker continuously very fast! With a slight pause milli-second every second.
        Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
        I tested each half by removing the first the left flex from...
        06-03-2025, 09:58 AM
      • domu
        Viewsonic VS16217 strange problem - white flickering screen on power up
        by domu
        As per subject, on power up display shows no image, but white
        flickering screen. Strangely, it only happen after power was lost
        when it was on. After power returns - white screen only, but if
        disconnect power for 12-24 hrs, and connect then again monitor
        works normally.
        Any clues how to go about it would be greatly appreciated.
        07-18-2023, 04:57 AM
      • DrvLikHell
        Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
        by DrvLikHell
        Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
        The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
        07-05-2024, 02:54 AM
      • Jaysean
        Acer VN7-591G-70RT Display Flickering
        by Jaysean
        Hello Badcaps coummunity hope you all are having a bless day,
        Hope I didn't post it wrong kinda new at forum site rules and tradition
        So I'm dealing with screen flickering problem on my laptop.
        I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
        so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
        [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
        [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
        10-27-2023, 10:22 AM
      • lostone
        Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
        by lostone
        Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
        First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
        When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
        05-19-2024, 11:40 AM
