Samsung Syncmaster 245B Black screen and blue Power LED
  • macready29
    • Jan 2012
    • 9
    Re: Samsung Syncmaster 245B Black screen and blue Power LED
    Hi guys.
    Sorry I am a bit late for this party but I need some help with my Samsung 245b!
    Recently the monitor suffered the same problem the OP had reported. The blue light was coming on except there was nothing on the display. Occasionally the screen might flicker for a nano second but essentially nothing was coming through.
    Any other time I would have perhaps given up and just purchased a new monitor but this is still a very good bit of kit and I frankly cannot afford a new monitor at the moment so fixing it seems worth a try.
    I hate to confess whilst I have some skill with a soldering iron by expierience with electronics is a bit lacking but I am willing to try.
    I have taken my monitor apart found my way to the same circuit board a lot of people are talking about in this thread. So my question is what now?
    Here are some pictures of my circuit board.
    If you look closely in the first few pictures something broke away from one of the caps I think. My finger lightly brushed it and something literally flaked away.
    Any help or advice here would be greatly appreciated.
    Thank you in advance
    Richard
    • jetadm123
      • 2169
      Did you try measuring the values of the 3 resistors mentioned on post #1 of this thread?
      • macready29
        • Jan 2012
        • 9
        We are now trying that. What results are we looking for exactly? We are a bit new to this...
        • macready29
          • Jan 2012
          • 9
          We have just noticed that the "stuff" (goo if you like) around those 3 resistors is slightly charred and cracked. Or at least darker than some of first pictures in this thread.
          Does that mean anything?
          • macready29
            • Jan 2012
            • 9
            Actually I just realised my pictures are a bit useless. Here some better ones of the two problem areas. I think.
            Much better.
              Oh yes, the three 68 Ohms resistors damaged by bad glue, check those 3 resistors. Remove all those brown and burnt up glue, it may have damged traces and component legs also, they are also conductive.
              You can see more pictures here:
              http://s807.photobucket.com/albums/y...msung%20245BW/
              • macready29
                • Jan 2012
                • 9
                #27
                Ok. Ill replace all 3 of those then. What about the other are that looks ropey, the second picture?
                Also do the resistors need to be re-glued? What am I looking for in terms of replacement resistors?
                Thanks again in advance.
                  No glue needed, check the other resistor with dark brown glue to see if its value nad its legs are not corroded and is still OK. You can get the MOX type resistors from DIGIKEY or Mouser. You should remove the resistors and Ohm them out first. You may have more problem beside damaged resistors.
                  • macready29
                    • Jan 2012
                    • 9
                    #29
                    We have just tested all 3 of those resistors and they read fine at .67
                    We have cleaned all the glue and gunk off.
                    The plot thickens...
                    • macready29
                      • Jan 2012
                      • 9
                      #30
                      The other resistor is reading at .47 (RP820).
                      • macready29
                        • Jan 2012
                        • 9
                        #31
                        Right. I just put it all back together hoping that maybe it would work and it didn't. Same problem as before.
                          You mean 68 Ohms, not 0.67 Ohms
                          • macready29
                            • Jan 2012
                            • 9
                            #33
                            Yes. sorry.
                            So, Should I replace those resistors anyway?
                            What else should I be testing?
                            • Toasty
                              • Jul 2007
                              • 4171
                              #34
                              Brown glue causes damage to the circuit by resistance. It effectively causing a low(er) resistance path (short) between exposed component leads. It does this (deteriorates) when it is heated over time, as would be the case with those power resistors.
                              It does -not- cause physical damage to the components.
                              If all 3 are reading ~68Ω, the resistors are fine.
                              veritas odium parit
                                It does eat away copper traces. So far I fixed this three of this model, all of them has one open 68 Ohms resistor, these 68 Ohms are in series, the bad one the glue had eaten into the body of the resistor.
                                • bathuu
                                  • Apr 2009
                                  • 12
                                  #36
                                  Originally posted by TechAMP
                                  Thank you mr. PlainBill.!
                                  I changed CM802 (18n 630V with a 22n ) and it's working now!
                                  Where did you source that special capacitor?
                                  • jetadm123
                                    • 2169
                                    #37
                                    Located by PlainBill:
                                    http://www.digikey.com/product-searc...0-ND&x=10&y=12
                                    • bathuu
                                      • Apr 2009
                                      • 12
                                      #38
                                      Just fixed mine by replacing RB805. Multimeter was not reading any value on that resistor. Other two were reading fine around 68ohms. So did not need to get to CM802 capacitor. Thanks to all who contributed to the thread.
                                      • dc42
                                        • Dec 2012
                                        • United Kingdom
                                        #39
                                        I'm glad to have found this thread! My 245B failed suddenly with the same symptoms (screen is black but power light works). I removed the power board, checked the resistors - all 3 look good and measure 68 ohms - and there are no bulging capacitors. Then I removed CM802 and checked it on my meter. It reads about 170pF instead of 18nF. New capacitor on the way!
                                          By the way, here is the SCH.
                                          • ulthi
                                            Samsung QE50Q60TAU - Flashes black/blue screen
                                            by ulthi
                                            My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                            I have tried different resets and have also replaced the main board - but nothin has changed.
                                            Any suggestions?
                                            https://youtu.be/acYQ-ImmhWA
                                            Today, 01:48 PM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • gbbradshaw
                                            Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                                            by gbbradshaw
                                            Hi.
                                            I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                                            02-22-2023, 01:31 AM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
