Dead 19" LG Flatron
  • Solder Boy
    • Nov 2006
    • 178
    Dead 19" LG Flatron
    Hi guys been awhile since I've been here. I have a dead LCD monitor here and just looking to see if my gut instinct is right in suspecting a bad bridge rectifier.
    Model L1953TQ.
    Original Symptom- No power no blinking light. Cracked it open and found a bulged cap in the output area. Tested the other caps all were fine except for one small one so I replaced that too. Applied power to unit.. still nothing.
    AC voltage at BR is 120-123. Checked DC voltage at the big capacitor.. reading was 0V. Checked the voltages to the video board.. on the 12V all I got was 3V something and the 5V rail read 0.3V
    Turning the power on and off made no difference on the AC side of the BR voltage remained the same at 120V.
    Checked the main fuse.. it was fine.
    This is for a client of mine.
    www.bcrelectronics.ca
  • Rtech
    • Jul 2010
    • 1095
    Re: Dead 19" LG Flatron
    Chances are that should there have been a short cct anywhere, then the fuse would probably have blown,so the Bridge certainly looks favourite,HOWEVER don'tunderstand how you can measure 3volts after the big cap when there is 0 volts on the cap ?????
    if no DC on the Cap then there is none anywhere else ???
    • Solder Boy
      • Nov 2006
      • 178
      I don't understand it either which is why I came here seeking input.
      I forgot to mention that for the hell of it I turned the selector on the DC section of my DVM to way below 20V and I did get a reading but it was very low. Go back to 20V and I get zero.
      • jetadm123
        • 2169
        Are measuring directly across the + and - leads of the large cap? If yes, is your meter working correctly? Try measuring a 9 volt battery to verify it's working ok.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Are you sure you don't get ANY voltage to the primary cap? If so, you have either a blown trace between the bridge rectifier and the cap, bad soldering, or an OPEN bridge rectifier (use diode test on your multimeter to confirm this). They rarely fail open but it happens sometimes.
          A working TV? How boring!
          • Solder Boy
            • Nov 2006
            • 178
            Hi.. yes my DV meter is working. Tested the 9V battery from my capacitance meter and it read 9V.
            Edit: Ok I took another look at this thing... Gawd I feel like a dum dum.... I get about 165VDC on the primary cap.. I can't tell what the capacitance is supposed to be but the primary cap says 450V.. I'm guessing something is obviously out of whack but not quite sure what? Transformer maybe?
            • PlainBill
              • Feb 2009
              • 7034
              Problem is likely on the 5V supply rail. With power off, measure the resistance from the 5V rail to ground. If it reads less than 10 ohms, remove D202 and check it.
              PlainBill
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Green caps... aren't those Samxon GF? If so, those may be your issue. If the diode PlainBill asked you to check is okay, then change out those caps on the 5v rail. Even if they look fine.
                • Solder Boy
                  • Nov 2006
                  • 178
                  Ok I changed out all those caps.. did not change a thing.. rechecked the VDC on the primary cap.. still 167VDC not 450.
                  I pulled out D202 to check it out of circuit.. Part# MBRF10100CT
                  >. reading is 210 with Diode selection on DVM (+ -)
                  >.reading is open (-+)
                  .< reading is 210 (. +)
                  .< reading is open (+ .)
                  Not sure if I did this right or if I am missing a step
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    The diode checks good.
                    As for the primary cap - that power supply does not have Active PFC. You live in a 120v area, right? The primary cap is 450v for 230v countries - and even there it only gets to see 320v or so, but it seems the demand for Active PFC in power supplies have driven down the prices of 400 and 450v caps hence why they are used even in supplies that would have did fine with a lower rating.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Something just percolated through the gray matter. In an earlier problem, one of the inverter drivers was defective, but not shorted. It overloaded the 12V supply.
                      The picture of the top is too small to really help, so I'm forced to work from the picture of the back side.
                      Referring to the 11 pin connector, the two bottom pins are 12V, the next two are Gnd, then next two are 5V. With power off, measure the resistance from Gnd to 5V and from Gnd to 12V. In each case, I would expect a resistance of over 20 ohms.
                      If you haven't already done so, reinstall D202, since that tested good.
                      I'm having a problem tracing the circuitry around U201. I can't figure out if the 12V or the 5V rail is regulated.
                      PlainBill
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        C'mon now, i wasn't expecting to hear something like that from you. The 5v always is, the 12v usually isn't.
                        • Solder Boy
                          • Nov 2006
                          • 178
                          Thanks for the info Bill I will do a follow up tomorrow..
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Not always. Samsung has regulated the 12V (15V?) supply in some of their monitors.
                            PlainBill
                            • Solder Boy
                              • Nov 2006
                              • 178
                              Just a follow up from yesterday.. haven't done that other test yet that you mentioned Bill but this morning I found something that looks like a Picofuse.. it's labeled FB101 on the board. I don't recognize the symbol.
                              I also took a better shot of that U101 IC you mentioned as well.
                              Please see attachments.
                              • jetadm123
                                • 2169
                                FB101 is not a fuse, it's a Ferrite Bead (what the "FB" stands for). Can't read the part number on U101. Can you please tell us what the part number is?
                                • Solder Boy
                                  • Nov 2006
                                  • 178
                                  Part # for U101 is: FAN7601 VG51
                                  Part # PC201: CC642 EL8
                                  Thanks for the info about FB101
                                  Update.. checked the otherl diodes and Schottkey Diodes they are fine.. just have a question about this other part. It was labeled Q101 on the board.. pulled it out tried googling the numbers on it.. no luck. FM G46 FQPF 8N60C.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    FQPF8N60C is the relevant number. Hint: Google each block of numbers and the word datasheet. The first hit when Googling 8N60C datasheet brings you to alldatasheet.com, which reports that FQPF8N60CF is a 600 Volt mosfet.
                                    PlainBill
                                    • Solder Boy
                                      • Nov 2006
                                      • 178
                                      Thanks Bill I spoke to the owner of this thing yesterday and told him I'm determined to find the culrpit which is preventing this thing from firing up lol.
                                      At this point I'm suspecting this MOSFET or the two IC chips or all 3.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Probably none of them. The fact that you do get some output voltage indicates the problem is on the secondary side, or the loads.
                                        I see two approaches. The preferred approach may take a little while. I have marked off an area of the bottom of the power supply in the attached picture. I would like a good quality picture of the area within the yellow lines. I need it sharp and clear because I am going to have to follow some circuit paths.
                                        The riskier approach is to unsolder one end of J1 (circled in black). This will disable the inverter. If the power supply now works, the problem is in the inverter.
                                        PlainBill
                                        • JoelJ
                                          Ampeg PF-350 bass amplifier head repair
                                          by JoelJ
                                          Hello everyone!
                                          I recently bought a broken Ampeg Portaflex PF-350 bass amplifier head in unknown condition. As it turns out, it's completely dead. Tried powering it on with the dim bulb tester, dead short.
                                          I have attached the schematic below.
                                          What I found:
                                          TH1 is cracked visibly but measures 6 ohms. Will replace it but should be okay for testing for now.
                                          Either Q1 or Q2 was dead shorted. Don't remember which one but one of them. Both are FQPF12N60C. I replaced both with SiHP18N50C to test as I had these on hand. They are the same package, pinout, mosfet type....
                                          09-09-2025, 08:37 AM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • Ross Kohler
                                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                          by Ross Kohler
                                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                          - There's no sign of any attempt to power on when pushing the power button.
                                          - No PSON signal is reaching the 24-pin ATX connector.
                                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                          - If I pull the Super IO S_SLPS#_R pin...
                                          04-16-2024, 09:36 AM
                                        • Larrob19
                                          Samsung TV UN75NU7100/Power Board BN44-00874C
                                          by Larrob19
                                          I have a Samsung power board BN 44–00 874C that is dead. I have looked for a schematic but no such luck. I opened it up and found two Mosfets burnt QP801CS and QP802CS, also the main fuse. I replaced them and checked the two blue capacitors in front of them. They both tested good. I checked the Diode on the same heat sink and the two capacitors in front and they checked out OK. I plugged it in again and that blew the fuse and the Mosfets the second time. I plugging it in again hooked to a 100 W watt light bulb. The light bulb starting started flashing off and on. I checked...
                                          05-08-2025, 12:49 PM
                                        • thetonywarren
                                          LG Flatron L1910S DEAD
                                          by thetonywarren
                                          I have a LG Flatron L1910S that is dead, no led's no backlight nothing.......I took off the back and took a look at the caps, all appear to be good, although I know that's not a true test......I took voltage readings at CW301, Without the main board connected, Im getting 5vdc and 14vdc, WITH the main board connected, Im getting 4.13vdc and 16vdc. Please see pictures for details, I think the attached diagram is correct for the SMPS. Any thoughts or suggestions where to look next....I can send better pictures and take measurements if needed.
                                          Thanks in advance for any help. ...
                                          01-07-2022, 11:19 AM
