Troubleshooting Viewsonic vx2235wm
  • Kostamojen
    • Jun 2011
    • 25
    #41
    Re: Troubleshooting Viewsonic vx2235wm
    It's a pigtail fuse, I'm guessing somewhere in the 2A - 4A range. You may be able to read teh current rating on the end caps. Some monitors us a picofuse in this application, others use a surface mount fuse. A fuse and fuseholder from Radio Shack would even work.
    Before replacing the fuses, check the inverter drivers to make sure they aren't shorted. If nobody jumps in with directions, I'll do it tomorrow. I can't keep my eyes open.
    PlainBill
    Hey Bill, got those directions on checking the inverter drivers? Much appreciated.
    • PlainBill
      • Feb 2009
      • 7034
      OK, here we go. These tests will be done with power off.
      The inverter drivers are two 8 pin ICs next to the inverter transformers. There is space for two more next to them. The two empty spots appear to be U200 and U201. I THINK the drivers are U202 and U203.
      If you look at the drivers you will notice a dimple next to one pin. That is pin 1. The other pins along that side are 2, 3, and 4. Pins 5-8 are on the other side. Pin 5 is opposite pin 4, pin 6 opposite pin 3, etc.
      1. Set your VOM to the X10 range and adjust the zero with the leads shorted.
      2. Put the black lead on pin 1 of the first IC. Measure the resistance to pin 2, pin 3, pin 4, and pin 5. Note any reading that is below 10 ohms.
      3. Put the black lead on pin 2 of the first IC. Measure the resistance to pin 3, pin 4, and pin 5. Note any reading that is below 10 ohms.
      4. Put the black lead on pin 3 of the first IC. Measure the resistance to pin 4, and pin 5. Note any reading that is below 10 ohm
      5. Put the black lead on pin 4 of the first IC. Measure the resistance to pin 5. Note any reading that is below 10 ohm
      Now repeat these steps for the other IC.
      PlainBill
      • Kostamojen
        • Jun 2011
        • 25
        #43
        ICs look good. No measurements under 20 ohms. Anything else I should do before trying to find a replacement for the glass fuse?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          #44
          Nothing else for now.
          A working TV? How boring!
          • Kostamojen
            • Jun 2011
            • 25
            #45
            Glass fuse is PGU manufact. and labeled F3.15A 250V. Radio Shack for replacement? Or should I look somewhere else? Anything special I should be aware of?
            • Kostamojen
              • Jun 2011
              • 25
              #46
              Radio Shack is coming up short. They have fuses with the amps and voltage. But they don't have a bracket that will work with the board. Recommendations?
              • Kostamojen
                • Jun 2011
                • 25
                #47
                Time for a little education on fuses:
                Found a fuse on Digikey that might work. http://search.digikey.com/scripts/Dk...&name=F3298-ND
                Looks like the same amp and voltage rating. Can't tell if its glass or if that even matters. Can anyone tell me if that fuse is viable for this application?
                Thanks again.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #48
                  F3.15A 250v = fast blow, 3.15 amps, 250 volts. I'm sure you can find that at Radio Shack. If you don't have a bracket for it, rip one out of an old something. What you have there on Digikey is a slow blow, which will take some time to open, giving more chance of blown transistors.
                  If you can find a fast blow then you're alright... but unless you have a bigger order to make, just a couple fuses are going to be a waste. Buy from your local shack and get creative about those leads. Hint: You CAN use a soldering iron on a fuse.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #49
                    +1
                    Or you can make your own fuse holder out of paper clips. No, I'm not kidding!
                    • jetadm123
                      • 2169
                      #50
                      3.15 A fuses are used quite often in computer power supplies. If you have an old power supply lying around, perhaps you could "liberate" the fuse from it.
                      As for a fuse holder for the fuse you already have, maybe you could use the Radio Shack one below:
                      http://www.radioshack.com/product/in...ductId=2062257
                      You could try glueing it down with silicon adhesive. Just make sure it's metal tabs don't come in contact with other components.
                      • Kostamojen
                        • Jun 2011
                        • 25
                        #51
                        Managed to find a fast blow fuse with the proper amperage and voltage at Frys. They didn't have a pigtail fuse, so I got a little creative with the soldering iron and some discarded leads from the cap replacement. I've attached a photo of the custom fuse. Installed everything and the monitor fired up like a beauty! Thank you to everyone who contributed to this thread. You were all a great help. And I got a 22" widescreen monitor for $20 in parts. I think I'm hooked!
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Well done. And your's is a common reaction. Whether it's fixing your own, or one someone else discarded, it's a good feeling.
                          PlainBill
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #53
                            Good job. Enjoy your new monitor. And please post your location in your profile, so it's easier for us to suggest a part supplier when you next need it.
                            • alexanna
                              • Mar 2010
                              • 1346
                              #54
                              Kostamojen it's fun isn't it!
                              Th3 Un1Qu3, Just a little off topic
                              But do you guys have a July 4th over there
                              Al.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Al.
                                Of course they do. It comes between Iluie (July) 3rd and Iluie (July) 5th.
                                PlainBill
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  #56
                                  PlainBill
                                  It's Iulie. Nope, we ain't got 4th of July here, only New Year. We did "import" Halloween tho.
                                  • Kostamojen
                                    • Jun 2011
                                    • 25
                                    #57
                                    Hey guys, the monitor I repaired seems to be showing a new symptom. I'll try to explain as best I can.
                                    The monitor runs consistantly good while connected via VGA (analog). However, when running on the DVI (digital) connection, the screen occassionally goes black for 2-3 seconds, and then comes back on. Sometimes when it comes back on, there are red pixels across portions of the screen, and the monitor will reset itself again after a few seconds.
                                    I've only noticed this issue while playing games on the computer, but, it might not be limited to only then. I'd really love to run this monitor off the DVI connection, cause the picture is even better. Any ideas how to resolve this issue?
                                    Thanks in advance.
                                    • jetadm123
                                      • 2169
                                      #58
                                      Thanks in advance.
                                      Have you verified that the DVI output of your computer's video card is not the problem? Also, have you checked to make sure it's not the DVI video cable connecting your monitor and computer?
                                        by momaka
                                        03-15-2023, 10:17 PM
                                      • wattage
                                        AOC AG493UCX 49-inch monitor - Firmware request
                                        by wattage
                                        Hello Badcaps Community,
                                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                        07-13-2025, 04:41 PM
                                      • Rick_1234
                                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                        by Rick_1234
                                        Good evening, gentlemen.
                                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                        Things I tried
                                        - Bought a new AC adapter thinking that was the problem but the problem...
                                        06-22-2024, 04:44 PM
                                        Wise Wing F199 19'' LCD monitor - recapped
                                        by momaka
                                        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                        When I saw the Craigslist post, I wasn't...
                                        08-24-2020, 10:58 AM
                                      • sew333
                                        Pc shutdown, monitor flickered with no signal after 10 seconds
                                        by sew333
                                        My pc:
                                        10850K stock 4800mhz stock Kraken X73 good temps
                                        2x16 GB DDR4 GSKILL 3000mhz XMP
                                        Seasonic Tx-850 Ultra Titanium
                                        Gigabyte Rtx 3090 Gaming OC
                                        Aorus Z490 Pro Gaming
                                        1 TB SSD
                                        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                        Power...
                                        02-22-2022, 10:27 AM
