DAC-19M009 dead?
+ More Options
Posts
  • PlainBill
    • Feb 2009
    • 7034
    Re: DAC-19M009 dead?
    Originally posted by retiredcaps
    It could be a false "in circuit" reading. D110 is right next to R132 which is a 15 ohm resistor.
    I would wait for PlainBill to see what he thinks. This is one area where I'm still learning and don't have hands on experience yet.
    That is in the drive circuit to the gate of the FET. Yes, a 15 ohm resistor would certainly distort the diode test reading.
    I'm at a serious disadvantage here, and am going to have to review the entire thread, but something strange is going on. OK, check that; something strange IS going on, but I'm convinced the TEA1532A is fine.
    The fact that the voltage at pin 1 rises when the signal card is attached indicates there are drive pulses to the transformer. Now, what is going wrong? Maybe after I wake up....
    PlainBill
    • papagoose
      • Jun 2011
      • 34
      #42
      Not sure if it would make a difference, but I didn't check the voltage with everything hooked up (I need to have the logic board upside down which made it difficult to connect the ribbon wires, wanted to avoid twisting them)- so of course I wasn't able to see if the LED still flashed once.
      Also, thanks everyone for all the time you guys are putting in to helping me with this problem. I'm really blown away by how helpful everyone is here!
      • PlainBill
        • Feb 2009
        • 7034
        [QUOTE=papagoose;169941<SNIP>
        Also, thanks everyone for all the time you guys are putting in to helping me with this problem. I'm really blown away by how helpful everyone is here![/QUOTE]
        It's all a matter of getting the satisfaction of accomplishing something. Some people get their satisfaction out of becoming a CEO, President, or Prime Minister. We get our jollies by doing something more important (and difficult) - helping people fix monitors and TVs.
        PlainBill
        • papagoose
          • Jun 2011
          • 34
          #44
          Bump- weekend is coming up, any ideas on what to test next?
          • PlainBill
            • Feb 2009
            • 7034
            OK, but remember, you asked!!!
            I've uploaded a picture after marking up a few points of interest.
            1. Black circle in lower left corner - use this as the ground point.
            Initial steps are with power off
            2. Yellow circle near lower left corner - what is the part number of that IC? I don't think it's the cause of the problem, I just want to know what it is.
            3. Diode circled in beige. Check it for shorts - you can do this in circuit.
            The next steps are done with the signal (logic) board unplugged from the power supply, and the power supply connected to the AC mains.
            4. Red circle. What is the voltage?
            5. Blue circle. What is the voltage?
            Disconnect the power supply from the AC mains, wait at least 10 minutes, then plug the power supply into the signal board. The signal board can be disconnected from the LCD panel and the front panel. Now connect the power supply to the AC mains.
            6. Red circle. What is the voltage?
            7. Blue circle. What is the voltage?
            There is something odd going on. Usually we see only one photo-coupler. This supply has two.
            PlainBill
            • papagoose
              • Jun 2011
              • 34
              #46
              LM393
              With the black probe on the top (same orientation as in the image) the multimeter reads 800. In the other direction, it reads about 2000
              Red = 5V
              Blue = 0V
              The same as before, Red=5V Blue = 0V
              • PlainBill
                • Feb 2009
                • 7034
                LM393
                Red = 5V
                Blue = 0V
                Well!! We are making some kind of progress.
                Once again, I'm resorting to Paint. The only good part of Paint is no clean-up is required.
                Your mission, should you decide to accept it, is to perform some rudimentary tests on the transformer. Do this with power off, please.
                Note that I have circled one point in black, and numbered the pins of the transformer from 1-6. With the DMM set to the 200 ohm range, measure the resistance between the point circled in black and each of the numbered pins. Try to measure to the tip of the pin, not to the surrounding solder or the trace itself. Then repeat this, but measuring to the traces, not the tip of the pin.
                I would expect all resistances to be under 1 ohm.
                PlainBill
                • papagoose
                  • Jun 2011
                  • 34
                  #48
                  I've measured it carefully touching the tips of the pins, all of them read <1 ohm. I'm not sure what to measure for the traces- are these the metal strips nearby?
                  The photo makes it painfully clear where I've slightly burned the board resoldering it! :p (other posts mentioned resoldering the transformer, I tried that before I started this thread)
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Oh, petals!! Well, ours is not to do or die, ours is but to reason why. The good news is that indicates the transformer is good.
                    The traces are the metal strips leading from the posts to the leads for the diodes. Lead free solder is notorious for producing joints that look good, but are faulty. So let's do the second part of the assignment. Measure the resistance from the spot circled in black to point 7 (the solder), and to points 8 and 9 (the tips of the pins.
                    Next step. Set your DMM to the 20 VAC range. Yes, I want you to try to measure AC!! With the monitor connected to AC power, measure the voltage from the point circled in black to point 7 and also to point 10. If either reads out of range, step up to the 200 VAC range.
                    PlainBill
                    • papagoose
                      • Jun 2011
                      • 34
                      #50
                      This may be a silly question, but I can't see 7-10 in the previous photo? Should I be looking near the transformer as before? Or is there a missing attachment?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Oops!!! I used invisible paint!!
                        PlainBill
                        • papagoose
                          • Jun 2011
                          • 34
                          #52
                          I've measured all the resistances, they are less than 1 ohm. My multimeter only has 750V and 250V in AC mode. When I measure the voltages from the black circle to 7 and 10, they are both essentially zero (it flucuated around 0.02 and -0.02). This is with the logic board disconnected. I checked the pins that go to the logic board, and they were showing the usual 5V etc.
                          Also, while I remember, the glass fuse F200 on the top of the board is still disconnected from testing before. Should I put it back now?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            That was somewhat of a long shot. I guess the DMM doesn't have the frequency response to read a 70 Khz signal.
                            No, leave that disconnected for now. I'm trying to establish why you don't get 12V out of the power supply. The fewer complications, the better.
                            Let's try something original here. I'm trying to run down the schematic for the power supply with very limited success, keep track of a baseball game, and keep track of the time because I have to pick up some family from the airport.
                            Test 1. Power disconnected. DMM on the 200 ohm scale. Black lead on the black circle. Measure the resistance to the lead between 8 and 9 on the latest picture. This should read open.
                            Test 2. Now switch to the diode check scale and measure with the leads on the same points. What is the reading?
                            Test 3. Reverse the leads - Red to the black circle, black to the point between 8 and 9. What is the reading?
                            PlainBill
                            • papagoose
                              • Jun 2011
                              • 34
                              #54
                              The resistance is < 1 ohm
                              The diode test read 0
                              And this read 0 as well!
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Charming. Refer to the attached picture. If you would, remove the diode circled in red. Then measure the resistance between the two points circled in black. Also test the diode by setting the meter in diode test range and checking from the center lead to each side lead. Then reverse the DMM leads and test again.
                                PlainBill
                                • papagoose
                                  • Jun 2011
                                  • 34
                                  #56
                                  Haha it would have to be one of the diodes that is screwed into one of the metal dividers on the other side of the board! Just waiting for the soldering iron to heat up now...
                                  • papagoose
                                    • Jun 2011
                                    • 34
                                    #57
                                    PlainBill
                                    OK now I am excited! With the diode out, the resistance between the two circled points is off scale (they don't seem to be connected).
                                    Am I correct in thinking this diode is actually 2 diodes put together? If I understand the drawing on the front correctly, they are connected in opposite directions. One of them reads 350 one way and off scale the other. The other reads 0 in both directions
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      If it looks like this
                                      http://en.wikipedia.org/wiki/File:Schottky.jpg
                                      then the 0 reading suggests it is a bad component.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • papagoose
                                        • Jun 2011
                                        • 34
                                        #59
                                        Yep it looks like those, same symbol drawn on them. So it sounds like we know what to replace next...?
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #60
                                          What is the part number on that diode?
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • whirlpool
                                            Imac model 2017 is complely dead No light-12v is ok-ps is changed
                                            by whirlpool
                                            Hello everyone
                                            IMac model 2017 intel i5 Completely died after updating the operating system , no lights are on the board. I changed the power supply before just to gain experience, but again the problem has not been solved .. I have done a lot of research about it ...
                                            I checked the SMC U5000 and pp3v3 pp5v. If you look at the schematic, the first light is called le0301 with the abbreviation in pp3v3 S5 circuit. before this I get 12 volts, 5 volts and 3 volts in U7600 well. but after U7600 and before reaching LED1_S5 everything is cut off . I reflowed the u5000 with a temperature...
                                            10-16-2021, 05:51 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
