Samsung SyncMaster 953BW psu fault?
+ More Options
Posts
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hi I obtained this monitor from my dad.
    This monitor started turning it's inverter off after 1 -2 seconds, I found that by using a torch I could the desktop was still been displayed.
    so i brought up the menu and adjusted the brightness from 100 to 90 pushed the power button then turned it back on it worked like that for a few weeks then done the same so turned the brightness down to 60 worked then done the same in till once set to 0 still won't stay on.
    So once they got a new monitor I got this one.
    So I have replaced all the caps on the secondary side still same issue.
    I measured the voltage on the 14.5 rail it was high once the inverter try's to start and then stops the rail jumps 18 odd volts?? then slowly lowers.
    I disconnected the diodes on the 14.5 rail and connected a 16v power supply I figured what harm can i do the rail goes up to 18 volts with that setup.
    The back lights stay on and the monitor runs as usual.
    Here is some other information the 5v rail is 5.16.
    to me it seems the psu is having trouble providing the current needed to start the inverter also the 14v rail dips down to 12 volts then overshoots to 18.
    Any help would be much appreciated.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Rtech
    • Jul 2010
    • 1095
    Re: Samsung SyncMaster 953BW psu fault?
    Have you substituted a 'test backlight',in place of the originals( does not need to be inside the Screen,) just alternatively plugged into each of the lamp sockets ?????, that would seem to be your next step.
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      I don't have any to test with.
      I think you have may miss understood i was using the inverter built into the power supply module I just fed the inverter from a power supply I had and it worked fine. just won't using the monitors psu.
      My pc
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        The inverter control ic is OZ9939 using STU309DH to drive the transformer.
        My pc
        • Rtech
          • Jul 2010
          • 1095
          Did not misunderstand.When you fed the inverter using the external Power Supply, this was a higher voltage than than the original, therefore after going through the output transistors, AND then being greatly increased by the Step up Inverter trannsformers, you actually applied a larger 'Strike' voltage to the lamps, than you were getting from the original...this would signify that one or more of the Lamps are faulty as they are not striking as they should...the only way to test is via a spare good Backlight.
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            OK thanks
            hmmm now I think should I modify the vsense to the ic to get more life from the tubes, or try and source compatible tube/tubes for testing or replace.
            Another question is why is the psu overshooting when the load is removed.
            That explains why it would not run with the psu set to 15volts.
            anyone know why they shut down the inverter is a tube didn't start?
            My pc
            • alexanna
              • Mar 2010
              • 1346
              Originally posted by joshnz
              OK thanks
              That voltage rail is not regulated, it kind of floats around until a load is applied. If it was not correct when a load is applied that would be the time to investigate why.
              In the case of a defective CCFL causing shutdown of all the CCFLs ,it's a safety feature.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                oh ok I would have thought it is meant to be due to the 5.1v and 14.5 rail are both been used in a voltage divider in the feedback circuit.
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  Good news I believe I have identified the fault.
                  I took the lcd apart and removed the CCFLs I proceeded to then attach them to the inverter/psu and the CCFLs connected to cn605 started but the ones connected to cn604 did not. So I swapped them same problem.
                  I then measured he resistance on the transformer secondary for cn605 that was 1266 Ω
                  and secondary for cn604 was 1162 Ω
                  So I guess it is safe to order a new xfmr.
                  It is a TMS92903CT
                  My pc
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Try resoldering the pins first. - Or at least look at it.
                    Not unusual for the wave soldering they use to leave cold joints on larger connections.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      Ok will resolder but there is signs of the xfmr been hot.
                      Will let you know tomorrow.
                      So I take from that the resistances seem fine.
                      My pc
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        No, but a cold joint can screw up the reading - and create heat.
                        - Dr Seuss
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          The heat mark was on the label.
                          I re-soldered the pins on the xfmr and checked the resistance after and was the same.
                          I removed the xfmr and was the same.
                          I then took the sticker off and found this look at pics to see.
                          Left pic is the side that starts the CCFLs right side is the one that doesn't.
                          1266 Ω 1162 Ω
                          Last edited by joshnz; 06-26-2011, 09:05 AM. Reason: adding resistances for respective windings
                          My pc
                          • jetadm123
                            • 2169
                            1266 Ω 1162 Ω
                            There's more than a 3% difference in the resistance readings between the two transformers. Your photo is a little blurry, but it looks like one of the windings is burnt. These transformers look to be readily available (and low cost too) on Ebay, which probably tells you something.
                            • joshnz
                              • Feb 2011
                              • 969
                              • New Zealand
                              Those were taken from my mobile phone my digital camera is worse.
                              Well in my opinion is that is the fault shorted/burnt turns.
                              So far I have located a replacement for 9 USD which is 12nzd
                              and a ebay one for 6.16NZD
                              My pc
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Definitely bad. The entire group of windings are scorched.
                                PlainBill
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  righto off I go to order/buy a new one.
                                  Thanks for everyone's help and opinions.
                                  let you guys know when the new xfmr arrives in about four weeks lol.
                                  My pc
                                  • joshnz
                                    • Feb 2011
                                    • 969
                                    • New Zealand
                                    Soldered in new xfmr all go
                                    The new Resistances are 1316Ω and 1323Ω
                                    Thank you to all of your input.
                                    My pc
                                    • joshnz
                                      • Feb 2011
                                      • 969
                                      • New Zealand
                                      Well looks like It needs a new transformer again can't run it at 100% brightness.
                                      My pc
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        Maybe the lamps this time ??? you will have to measure the transformer again.
                                          09-07-2024, 05:50 AM
                                        • soopacrucial
                                          Samsung Syncmaster 740BF repair
                                          by soopacrucial
                                          Hi folks,
                                          I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                          Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                          10-29-2024, 02:40 PM
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • theflyingsquirrel
                                          Samsung Chromebook Pro missing 1.2V power rail and no boot
                                          by theflyingsquirrel
                                          I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                                          When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                                          06-11-2025, 08:11 AM
                                          09-06-2024, 11:40 PM
