Dell 2407WFPb Monitor - Bad Cap
+ More Options
Posts
  • Fhajad
    • Aug 2012
    • 30
    Re: Dell 2407WFPb Monitor - Bad Cap
    Okay so looks like my full list is Q651, F601, R670, and D652. How do I verify if the SMPS MOSFET (Q601) is bad or not before trying to power this up? Anything else I should check before ordering those 4 pieces?
    And surface mounted resistors appear to be okay. I'm not seeing any real issue on the top of them it looks like.
      If you label the pins as 1, 2, 3 on the MOSFET and then measure the resistance like this and report back what you find.
      1 & 2
      1 & 3
      2 & 3
      By the way, there is also 0.22 Ohm in that SMPS section, check and see if that one is also blown or not.
      • Fhajad
        • Aug 2012
        • 30
        0
        591
        570
        And on the 0.22 Ohm SMPS resistor it looks fine, it's getting a 001, while the bad one is getting 980 about.
          That '0' reading on 1 & 2 does not look right. I would remove the MOSFET and test it outside the board. MOSFET should read open circuit with exception if it has Source to Drain internal Diode.
          • Fhajad
            • Aug 2012
            • 30
            Trying again now I did get a reading when I went for the ultimate top of the post, the solder on the 2 wasn't giving me anything when attached to it. I'm attaching pictures of the meter and while I was on the board to be sure I'm not screwing this up. Again close up picture is low quality but gets where I'm testing at least across I think.
              We are looking for short, so use the Ohm mode, when semiconductor shorted out it will be like measuring low value resistor, it will no longer act like a semiconductor (conduct in one direction only).
              That is the Drain and Gate checking, definetely should not show '0'.
              • Fhajad
                • Aug 2012
                • 30
                At 2000K Ohms I got a reading of about 850.
                Everything other than that was giving me a "1" the whole time.
                • Fhajad
                  • Aug 2012
                  • 30
                  Ok so I'm about to order my bits and pieces, I'm just gathering the part #'s now to order from digikey again.
                  Do I need to bother with the SMPS area at all or just the parts mentioned earlier?
                    I would get the part for SMP section for future and save on shipping charge.
                    • Fhajad
                      • Aug 2012
                      • 30
                      Just the SMPS MOSFET?
                        Not sure how easy to get the SMPS IC.
                        • Fhajad
                          • Aug 2012
                          • 30
                          I don't think I'm well equip to do an IC though is the other issue. I can order everything else and give it a try. But if an IC is causing issue, there's nothing I'm going to be able to do other than just doing a bypass.
                            But you will need to repalce that IC in the PFC section, otherwise you will end up with damaged new MOSFET like the poster had done (The MOSFET went out and damaged the IC, put in new MOSFET then it is damaged by the damaged IC, hwne MOSFE goes out it will usually take out the IC that drives the MOSFET also).
                            What happen when the drive IC went bad is that the output either stuck LO or stuck HI (always has output voltage at the drive pin all the time) which is really bad, it will turn on the MOSFET all the time (never switch off), since the transformer has low DC resistance, the MOSTFET will blow up.
                            Post258:
                            "Things I've changed / model:
                            Q651: 2SK2843
                            Q654: MM3906
                            IC651: L6561D
                            IC601: Was NCP1200AD60 (200A6) changed for NCP1200D60 (200D6) - notice the lack of the "A", this "A" means that is a newer version of the chip, both are pin to pin compatible, and seems this circuit allows both to run (Im still not sure if these chips are fully swappable 100% of the designs)
                            F601: Same kind of fuse: T4AH
                            C605: 450v 150uF snap-in capacitor -- waiting for a replacement that will FIT into it when closed :@
                            I suspect that the OLD NCP1200 had a problem between the pins 5 and 6.
                            The "PWM" part (Except for the chip itself *sigh*) of the power supply never had a problem in my case (IE, Q601 never shorted)"
                            • Fhajad
                              • Aug 2012
                              • 30
                              Would a large heat gun work for taking out IC651 then and putting a new one in? That's about the only thing I can use for that.
                              And would I have to worry about the IC601 all the way up by the SMPS if the .22ohm up there is fine?
                                More likely you do not have problem with the SMPS section since the MOSFET did not short out, and the resistor is OK.
                                When I remove surface mounted IC I add a bunch of solder to all the pin and keep moving the soldering tip around the pins (this where 40~60Watts soldering iron with wide tip comes in handy) and use a long nose plier to lift the IC off the board, if you are going to use heat gun, make sure to cover surround area not to damage other components or causes other surface mounted components to be moved.
                                • Fhajad
                                  • Aug 2012
                                  • 30
                                  All I got is my cheapo radioshack iron. It isn't exactly quality but it gets the job done. I just can't personally justify a large amount of money into a station when I have so much else to pay off before that.
                                  Heat gun will have to really be the only option, I'll try to protect everyone as much as I can but it's such a dense area that might be problematic.
                                    http://s807.photobucket.com/albums/y...t=DSC00082.jpg
                                    It is not that dense. Do you have EXACTO knife?
                                    What you can do is to heat up the pin and slide the knife under the pin to lift up the leg one by one, no need to worry about breaking the pin. One key is that your soldeing Iron should be eleast 30Watts or more and use flux on it, you may want to add small amount of regular solder (the solder on the board is Lead free and it needs higher temp for it to melt, add 64/40 solder to it will help) to the pin to help removing the IC. There mey be adhesive that holds the IC to board also.
                                    • Fhajad
                                      • Aug 2012
                                      • 30
                                      Doing an IC is making me nervous but better just give it a shot while I can that's for sure.
                                      So looks like on my order list is IC651, Q651, R670, and D652. The fuse F601 appears to be fine since I'm getting voltage at the main capacitor.
                                      • Fhajad
                                        • Aug 2012
                                        • 30
                                        What's the best source for finding all these bits? Digikey is useless on a lot, as is radioshack.
                                        I got a Fry's about an hour away. Would they for sure have all of these bits?
                                        • Fhajad
                                          • Aug 2012
                                          • 30
                                          Looks like I can't get any good parts supplier and Fry's doesn't have the right parts at all.
                                          Looks like bypass is the way to go.
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            Today, 12:14 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
