Dell 2407WFPb Monitor - Bad Cap
Re: Dell 2407WFPb Monitor - Bad Cap
So I'm trying to fix up a power board from a monitor at work.
http://i.imgur.com/QIQWh.jpg
http://i.imgur.com/J4RdP.jpg
Replaced the large cap, seems the R670 is bad as well. Anyone else notice anything? I can probably grab the R670 at radioshack on my lunch. Gonna find my multimeter as well to check anything else if people have recommendations.Comment
I recommend you post the pictures as follows
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...1&d=1290283049
https://www.badcaps.net/forum/attach...7&d=1280167246
It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
Tell me what you see here:Last edited by selldoor; 08-14-2012, 12:54 PM.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Hopefully these are a lot better.
And my skills are amateur really. I have a radioshack iron and a few things here and there (multimeter and such). Will eventually will invest on a better set of tools. Hoping this is one of the easier boards to repair but doesn't seem like good odds.Comment
Also, it wouldn't hurt if you gave a description of the symptoms your monitor is having.Last edited by jetadm123; 08-14-2012, 01:34 PM.Comment
Pictures are not a lot better - too grainy - more natural light is the key.
Anyway - you still need to tell us the problem. What happens when you plug it in. What happens when you switch it on. What does the panel (Screen) do
what does the power led do. Any noises ( Hiss squeeks etc)
As you will have read we only know of one of these being fixed by conventional methods - others have modded with an external power supply.Please upload pictures using attachment function when ask for help on the repair
When the Source resistor is damaged, it means that the MOSFET has shorted out and it will take out the IC that drives the MOSFET also, you should replace them at the same time.
2407 tear down:
http://s807.photobucket.com/albums/y...ll%202407WFPB/Never stop learning
Ok plugged in but not switched on what voltage across the Big Cap?
Meter on 600VDC red prob on positive leg of cap and black probe on negative leg.
Then do it again after you press the power switch. CARE High voltages do not touch any heatsinks or other parts.
If its been switched on switch off & leave 5 mins then
I cant see that you have checked the main fuse? or the Black round component next to it.
For both meter on ohms 200 and check resistance - post resultsLast edited by selldoor; 08-14-2012, 02:53 PM.Please upload pictures using attachment function when ask for help on the repair
00.6 on the fuse, 07.1 on round component.
My multimeter only goes up to 500VDC and it reads 158.
I am also reading through for the components required for the IC, MOSFET, and resistor. I see the resistor is a .22ohm as mentioned above.Comment
So would it be a safe bet to replace most of the items listed on the previous page from the guy that did everything successful, or just replace the 3 mentioned and call it good? Is there a chance of the 3 I replace getting shorted out again if something else down the line is bad?
I'm thinking of stopping by Fry's in the next two days to pick up pieces. Surface mounted stuff does give me the willies since I don't have a reflow station, but I do have a regular ol' huge heat gun I can use.Comment
So what do you get when you check the MOSFET, is it shorted? Does the 0.22 Ohms resistor check open?Never stop learning
I haven't checked the MOSFET but the .22ohm resistor has two cracks down the sides on the top so I'm pretty sure it's blown.
https://www.badcaps.net/forum/attach...3&d=1344971275
You can see the crack in this picture.Comment
OK, it would be safe to replace the IC's, MOSFET's, resistors, main filter cap components in the post 258. The surface mounted may not be damaged but look at them real close with magnifying glass.Never stop learning
When looking at the surface mount, am I just checking for discoloration on the solder joints primarily?
So list I have to replace is at least Q651, F601, and R670. I'll try to grab the others when I get in tomorrow and take an extra look at everything. Hopefully I can traditional repair this board no problem. I'm just feeling sketchy about using the bypass method in a work environment.Comment
The surface mounted resistor, when it burns up you will see the middle section has a small black hole, pit, bulging, the printed number on the body will be damaged also.Never stop learning
One place that you may be able to get broken electronics is the Electronics recycle in your area, I myself do volunteer works every Saturday, you get to work on all kind of stuff and get great deals on boards and parts. My local place is WWW.CRC.ORG, I have been at the place since 1995.Never stop learning
One place that you may be able to get broken electronics is the Electronics recycle in your area, I myself do volunteer works every Saturday, you get to work on all kind of stuff and get great deals on boards and parts. My local place is WWW.CRC.ORG, I have been at the place since 1995.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by Jesus CoderHello everyone,
I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...-
by tony359Good day all,
I have a question about some old monochrome Apple monitors.
Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
The new capacitor:...-
I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
Does someone have seen this before?...-
- Loading...
