Re: Elo 1525L power board ptb-1218
Hello.
I have a similar problem with this board.
I have both voltages at output 5V and 15V but with a big ripple.
I measure with my osciloscope and there is a ripple of 1V with a frequency of about 3Hz, on both outputs.
Can somebody help?
Hi, sorry to revive an old post but am also having no power on the same Elo 1525L monitor, so were you able to fix it?Leave a comment:
swaped it from the other board... not bad. Nothing charred either, i couldnt get so lucky to see something so obvious. This thing has kicked my arse.Leave a comment:
PlainBillLeave a comment:
whats the best way to test c806 with the dmm
part# is CD UF 0.01 1000V M Z5U FLeave a comment:
Negative probe on C805 neg, Positive probe ion C807 reveals 13.2,13.4,14.1 as the chart reffers to as pulse? Urmmm... did the next step after looking up the ka3842a 8pin chip I801. I was checking pin 7 as pin 6, there is no pulse.Leave a comment:
Here is a schematic for easy following maybe this will someone better than me. I've check every resistor now..all check good
wish I could fire this thing. Shorting Q803 was bad orginally
So far I've replaced Q803, R811, R814
any pointers other than dig a hole are welcome :P
Not sure how to test D806. I have a replacement thats exact if it was proven failed...I'd have to remove it from another board.Leave a comment:
replaced the R811 on this thing. value checks at 1.2ohms and replaced the R814 with 47ohm 1/4w (bit larger)
still not working. any other suggestions? top portions of this board not getting power. nothing past the I802, C828Leave a comment:
ok for replacment I have another similar board that i can rob a White, violet, silver, gold. whick calculates into .97ohm 1w for the R811. This must be better than the other suggestion of 1.8ohm 3w? any help is appreciated.Leave a comment:
what are them rules for resistor replacement?Leave a comment:
I take it that you're measuring R811 in-circuit? Since other components could be affecting your readings, you'll have to remove it from the board and retake your measurements.Leave a comment:
Start over, with the DMM on the 200 ohm scale touch the probes together what reading do you get?Leave a comment:
after replacing the mosfet Q803 I've taken some time to read all resistor values per the schematics link I supplied above.
Plainbill, that R811 is a 1.2ohm 2w colors where Brown, red, gold, gold. I can get nothing but infinite on DMM set on 200,2k,20k... but when I goto 200k I get 20.0 then while holding probes I can set the DMM back to 20k and get 19.98 .....must be bad? I dont have any laying around for subs other than 1.8ohm 3w ww 5% .... not sure them rules for this. Also testing futher indicates that the R814 set DMM on 2k reads 90.7 which should be according to the colors and schematic it should be a 47ohm Yellow, violet, black, gold.
any suggestions for replacements also rules for replacing resistors with larger values? anyone anything? thanks guys! ....BlkLeave a comment:
Got my Digikey order today
Replaced the Q803 with p4nk60zfp as a suggested relacement. still the same... pooooooop! Anyone got anymore suggestions? I'm overlooking something here. I would love to win this one. all this by shorting pins 2,3 on this Q803 originally.....Leave a comment:
Ok, I had a p4nk60zfp on another monitor. I thought the specs looks close enough to the s0220 sss4n60b. during removal with desoldering braid I think I ruined it.... The values dont seems to test on diode mode. dam it all again. Anyone got a good source so I can replace both with correct values? Also during that test plainbill had me do while in diode mode, what would the correct value or optimal would have be on the DMM?
Thanks in advance guys...........BlkSmth
the p4nk60zfp readings "Plainbill asked: Number the pins in any order and measure 1-2 1-3 2-3 2-1 3-1 3-2 (the red probe goes on the first number of each pair)" are open all except the last 3-2 which is 546 value.... They where diff before
Checking the specs, I would say the P4NK60ZPF is a good substitute for the SSS4N60B. It is available from Digi-Key for $1.40 each. Don't delay, they only have 3059 on hand.
cannot see giving up
I found what I think would be a good choice:# SSS4N60B s0220
http://www.mouser.com/Search/Product...y512-FQPF5N60C
Then the other I smoked... STP4NK60ZFP
http://www.mouser.com/Search/Product...11-STP4NK60ZFP
any peeps get a chance to verify that for me, that would be great. The oem datasheets are on links above........Leave a comment:
the p4nk60zfp readings "Plainbill asked: Number the pins in any order and measure 1-2 1-3 2-3 2-1 3-1 3-2 (the red probe goes on the first number of each pair)" are open all except the last 3-2 which is 546 value.... They where diff beforeLeave a comment:
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
