Fluorescent Lamp Inverter 12 volts
  • barry wilkins
    • Aug 2009
    • 172
    The lamp inverters failed in my caravan ,a couple of 2A transistors had died.After cleaning up the mess and replacing them with a couple of BD 139 transistors ,the inverters would not run when I connected up to my bench power supply .The current was over 3 Amps and the psu shut down . I traced the reason to the 2 bias resistors of 470 ohms ,increasing the value of these to 1K or even more made a big difference to the current drawn . The only reason I can assume for the design is to ensure the lamps would strike if the supply voltage had dropped below 12 volts .
    One inverter has bias resistors of 1K and the other has 4.7K fitted ,both seem able to work as low as 10 volts ,so I will see how they behave if the future .
    Barry Wilkins
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Fluorescent Lamp Inverter 12 volts
    I think the original transistors had lower gain hence higher bias current.
    A working TV? How boring!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      often they are house marked and hand selected.thinlite does this.i dont have too much trouble fixing them.
      • u666sa
        HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
        by u666sa
        Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
        Platform: ipa32 la-m024p rev 1b
        Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
        I found a short on the other side:
        10-04-2025, 05:03 PM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • supermattch
        HP 15dy-2021nr wont power on mystery volts
        by supermattch
        Hi everyone.
        I am diagnosing my personal laptop, because it wont power on and no leds light up.
        At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
        Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
        09-23-2025, 12:13 PM
      • Mark R
        The Overseas Only Kenwood Model KR 790
        by Mark R
        I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
        The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
        09-23-2025, 08:27 PM
