NEC 2080 Power Supply
  • TrevorBlain
    • May 2011
    I have a NEC 2080 faulty power supply, all the caps test good. Anybody have any suggestions.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: NEC 2080 Power Supply
    1) Yes. See my sig file below on how attach pics of your lcd boards (power and logic) to this forum and please do not post inline or offsite.
    2) Do you have a multimeter?
    --- begin sig file ---
    --- end sig file ---
    • jetadm123
      • 2169
      In addition to retiredcaps request, how to did you test the caps? Also, can you please give a better description of the symptoms? Saying it's "faulty" is like calling your doctor on the phone and saying "I'm sick, what's wrong with me?"
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        That is so beautiful
        In my day work I repair alarmsystems, and a typical fault description is " its not working "
        • jetadm123
          • 2169
          Anyone who has worked in the service/repair industry knows exactly what you're saying.
          • TrevorBlain
            • May 2011
            1) First off let me say that I had no idea that I was going to get chastised like this from everyone one for saying I have a "faulty" power supply.
            2) I removed all the caps from the board and tested them with a SENCORE capacitor & inductor analyzer. As a matter of fact I removed most of the componets from the board and tested them.
            3) Yes, I have a DDM.
            4) All voltage readings are good on the power supply under no load conditions. As soon as you put the load on it the voltages start to fluctuate from 390vdc to 0vdc.
            5) I have repaired many of the NEC 2080 and 2090 power supplies and it has always been faulty caps. I have never had a problem like this one.
            • smason
              • 1652
              1)4) All voltage readings are good on the power supply under no load conditions. As soon as you put the load on it the voltages start to fluctuate from 390vdc to 0vdc.
              See? That wasn't so hard was it?
              • TrevorBlain
                • May 2011
                Thanx for all the help?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Still no pictures of your boards.
                  • TrevorBlain
                    • May 2011
                    It is a NEC 2080 power supply! Why do you need a picture?
                    • Rtech
                      • Jul 2010
                      • 1095
                      The simple answer.is that like a lot of monitor manufacturers,The Model number may be the same, but internally they can be totally different !!
                      • smason
                        • 1652
                        OK, replace r201 and Q106
