viewsonic vg720 no power, blown transistor on mainboard
    Hey guys heres another one. Its a viewsonic llcd monitor.
    no power on no led, dead..
    checked 120vac in, ok, checked output of rectifier, ok, check 5 volts to mainboard, ok. no 5V TO SWITCH PANEL.
    all caps look ok, found a small smd transistor fried. Theres a 0 ohm resistor that feeds this, that checks ok.
    How the heck do i figure out what kind of transistor to replace it with? its totally smoked. Im sure i have something here i could rob it from, just want to know whats the proper thing to go in there.
    Re: viewsonic vg720 no power, blown transistor on mainboard
    Post a picture of the power board. It could be the small cap and/or SMPS controller that is bad.
    --- begin sig file ---
    --- end sig file ---
      Okay, please supply the following info:
      1) the "transistor" that's burned is silkscreened U406? If yes, the "U" designator indicates that it's not a transistor.
      2) you're getting the 5V output. What about the 12V output? Usually, there are two diode packs located on the same heatsink. Measure the voltage output on the middle leg of each device. One should be 5V and the other 12-14V.
      3) does the power led light up at all on the front panel?
        #1: i dont know. Its burned pretty badly. I can see a "N H(? looks like half an h the other half is fried too bad to read) Blank and a 4
        so basically NH*4 its location is silkscreened as "u406" on the board.
        #2 i have 5.ov and 14.4v at the diode packs so yep theres my 12v.
        #3 no the indicator led does not light under any circumstance. No backlight flash, nothing. From the outside it appears 100% dead.
        checking power to the little smd thingy( please forgive me here smd stuff is new to me)
        i have 0v on the left pin, 5.0 on the center top pin, and 4.2v at the far right pin.
        school me: f is fuse.. c is capacitor. t is transistor. d is diode. what the heck is "u" ?
          here wo go.. picture crazy. Sorry guys i thought i posted most of these the first time but apparently i did not.
            U406 is probably a MAX810 reset controller that holds the scaler chip in a reset mode until the power supply comes up to proper voltage.
            1) verify that the filter caps around the two diode packs you just checked are not bulged. If yes, replace them.
            2) If you are game, piece everything back together. Connect the monitor to AC power. With a screwdriver, short the bottom two legs together. Press the on/off button on the front panel. See if you get any activity on the power led or screen. If not, try pressing the on/off button a few more times.
            3) Some people have reported that removing this chip allows the monitor to work. However, leaving the reset pin of the scaler chip "floating" is probably not the greatest idea. Best if you replace U406, if you have success with step 2.
              ok will do..
              EDIT: you are the man!!!!!
              removed it, it powers up perfectly. powers down perfectly. Im kind of tempted to leave it the way it is.
              when i search for that part, i get this screen:
              http://search.digikey.com/scripts/Dk...X810&x=20&y=15
              too many what ifs there. Which one do you think i need?
                Whoops. Misread the 1st post. I thought there was no 5V at all. Now I see 5V is there.
                  The original recommended digkey part was: MAX810MTRGOSCT-ND, which is out of stock.
                  If you type in max810m in the search window, you get several hits including the above, but made by a different company. Most look the same with the exception of different case styles.
                    ok i will start hunting it down. If i cant find one mabye i will keep this as a personal monitor. I would hate to sell this to someone and have it set thier house on fire because i removed a part out of it.
                      digikey came up with this:
                      http://search.digikey.com/scripts/Dk...10MVNB713CT-ND
                      what do ya think?
                        Did a little research and the original viewsonic part was:
                        ASM810MEURF-T where T is a reset threshold voltage of 3.08V
                        Maybe digikey TCM810TVNB713CT-ND ?
                          honestly i think im going to leave it the way it is now.
                          Theres a good chance i could get the wrong part and make things much worse. Its working fine now, i figure if it isnt broken dont fix it right? Its been running on my pc for 2 days now and all is happy from power up/power down and even going to sleep more and waking back up.. working fine without that piece in there. so yeah i think im happy with it the way it is.
                            Another failure of those crappy reset thingies. It seems they really are designed to kill stuff rather than protect it. If it works, don't fix it.
                            A working TV? How boring!
                              I think you are mistaken. This is most likely an engineering problem. While a full datasheet is not available, in some cases the processor has an internal reset controller. The reset controller is unnecessary, and we are seeing the result of two outputs trying to drive one another. The external reset controller is being destroyed by the one in the processor!!
                              PlainBill
                                It's been enough fails already for it to simply be an "engineering problem". But, in the age where everyone copies everyone else without even bothering to take a good look at the design they are copying, it is still plausible. But i don't believe it - smells too much of planned obsolescence.
                                  Don't forget that if 'generation 3' required a reset controller, an engineer may assume that 'generation 4' of the IC would also require it. Problems that don't occur in the first weeks of design are much more likely to make it into production. Design errors that take several years to result in a failure will NEVER be caught, they are now using 'Generation 6 or 7' in their products.
                                  Heinlein's Razor. "Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
                                  PlainBill
                                    I suspect there was never any need for a reset controller at all.
                                      That's a pretty bold statement. Are you suggesting some IC designers said "Hey, let's design an IC nobody needs. We will price it at $.73 each. Since nobody will ever need one, we don't have to make sure it works properly."?
                                      In another thread, I've pointed out that a RC reset circuit has a number of problems that a reset controller solves. For example, if the power supply drops slightly, then recovers the RC circuit will not reset the processor. The RC circuit requires either a relatively large capacitor or high value resistor. By it's very nature, the RC reset circuit takes the reset input through an undefined logic state rather slowly. All of these can lead to problems.
                                      PlainBill
                                        Or it's blind luck that the cpu starts without it.
