Proview EM190
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Proview EM190
    HI just need some input to check i am correct .
    On the pics i have attached
    Red + input
    yellow - input
    I bought this monitor as the seller said it would not power up ,
    when it arrived i was confused to find no DC input jack as i have another one of these i was going to use for parts (slight difference in the main board )
    I contacted the seller and from what i can gather he was putting the power plug into the audio input
    Opened up the monitor to find no female connection on the main board either so how the hell anybody ran this as a monitor is beyond me unless its scavenged for parts and the wrong ones put back in.
    I just wanted to check that i am correct as i am going to solder wires straight to the board for now to run tests to see if it actually works before i buy in a dc jack set .
    Any input welcome
  • brethin
    • Dec 2008
    • 1907
    Re: Proview EM190
    A pic of the backside of the monitor would help (pics of the board inside dont help for your question). My guess is someone changed the board inside with a board with no jack (not unheard of to sell to look complete). That monitor clealy needs a 12v PSA.
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      Re: Proview EM190
      Hi i know it needs 12v 5a was just trying to confirm which would be positve and which negative inputs on the board as the other one i have has a different power input its a 2 pin .
      If and when i do fit a jack plug set its going to have to be mounted on the chassis and wires run to the board as it will be to far into the case to use a female jack on the board (if that makes sense)
      • alexanna
        • Mar 2010
        • 1346
        Re: Proview EM190
        Look for a power plug on the blue VGA cable where it connects to the video card on your computer
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Re: Proview EM190
          Thanks Alexanna but that was the second place i looked as i know some of the older monitors i have seen have had them attached in that way ,
          but no joy
          • Rtech
            • Jul 2010
            • 1095
            Re: Proview EM190
            All the External Power Supply models I have seen, have an Electrolytic cap very close to the input socket,so the cap -ves are very likely to be the input -ve as well..there may also be a diode very close, just in case a PSU with the wrong polarity is plugged in.
            • sabre504
              • May 2010
              • 449
              • United Kingdom
              Re: Proview EM190
              Well Alexanna you were right .
              The power input point is supposed to be in the vga cable plug .
              After you had said to look there i decided to take a closer look at the cable itself on the end that plugs into the main board sure enough there are a black and a red wire .
              Blue plug end is not a sealed unit as normal its a self fit type opened it up and bingo 2 snipped wires red and black .
              So now all i have to do is tap in at the board end for a dc jack plug to mount
              on the back plate and then see if the monitor works.
              Thanks for the input everybody .
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • penangit
                Hp v193 monitor power supply board
                by penangit
                Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                Steps taken so far:
                Checked all...
                02-21-2023, 04:00 AM
                by momaka
                03-15-2023, 10:17 PM
              • Wilykat
                LG 32GK650F-B random flicker
                by Wilykat
                I have this monitor that roughly every few minutes, the image would turn solid black for a frame or 2. It is infrequent but annoying and I'd like to stop it somehow. I have tried: swapping power supplies, different video cable, all 3 video inputs on the monitor, and 3 different computers. Since the symptoms doesn't change, the issue is likely with the monitor;
                Monitor has EAX69731901 board with video and power input, menu control joystick, LCD output and backlight output: https://i.imgur.com/OkrBoi1.jpeg
                I couldn't find any info on repairing this monitor and the only...
                12-03-2024, 02:49 AM
