Neovo F-419 no power.
  • playman
    • Jan 2011
    • 252
    I get no power on the lcd, not even on the power led.
    scematics of the PCB.
    D801 was missing when I opened it, I replaced it with RGP10D instead.
    D802 is PS104R D0-41 PANJIT wich seems identical to PS1010R DO-51 PANJIT wich I belive should be in D801.
    Any ideas what might be wrong?
  • jetadm123
    • 2169
    Re: Neovo F-419 no power.
    Nice photos! Try checking the main fuse, F801, 3.15A for continuity. If it checks good, then check the voltage across the main cap (large green one upper right). If you are in the USA, it should measure approx. 165VDC.
    • playman
      • Jan 2011
      • 252
      Originally posted by jetadm123
      Nice photos!
      Thanks it took me a while though, to get them that good lol
      I'm in Iceland, using 230v system.
      The fuse was the first thing I checked
      how should I check the Cap? plug the monitor in and test it or? sorry i'm still a newbie
      btw I have no ESR tester.
      • PlainBill
        • Feb 2009
        • 7034
        Correct, with the monitor plugged in, CAREFULLY check the voltage across the large cap. On a 230 volt system you should see about 320 volts across the large cap.
        PlainBill
        • playman
          • Jan 2011
          • 252
          Hi again, sorry for the late post.
          I finally was able to check the cap, it mesured 320v
          • jetadm123
            • 2169
            Had a quick look at the schematic. Apparently, your monitor has a reset circuit, which if faulty, can cause the problems you describe.
            1) look at the link below, it describes a acer monitor with the same problems you have and describes the function of the reset circuit:
            https://www.badcaps.net/forum/showth...ghlight=max810
            2) the chip on your board is U7, part # MCP809-300 and is located on the logic board.
            3) please post a photo of the logic board.
            • retiredcaps
              • Apr 2010
              • 9271
              Okay, now let's check cold side for secondary DC voltages at connector P803.
              Put your multimeter on 20V DC (if manual). Use a ground screw for your black probe (ground). Put your red probe on each connector pin. Report DC voltage measurement for each pin.
              --- begin sig file ---
              --- end sig file ---
              • playman
                • Jan 2011
                • 252
                Hi jetadm123
                I was not able to find the U7 chip, I must be blind
                any way here are the fotos you asked for.
                sorry for the flash on the picture.
                • pedro
                  • 199
                  • AUSTRALIA
                  Hi jetadm123
                  It's east-north-east from the NE corner of U6, half-way to the connector. It's in a SOT-23 style body, only three pins on this device.
                  Friends don't let friends buy Samsung ....
                  • playman
                    • Jan 2011
                    • 252
                    I might have done this wrong, but this is what I did.
                    I had the PCB on the table(not connected to the screen), only electrical wire connected, put the black prope
                    into the earth wire from the socket on the PCB, wich connects to the screen metal sceleton.
                    Then probed the 7 wires with the red probe, and got 0 reading on all of them.
                    was that a right way to do it(or one of them)?
                    Update:
                    I just plugged the board into the screen, with everything connected.
                    and all the wires gave 0 reading.
                    • playman
                      • Jan 2011
                      • 252
                      ah thanks for that, I'm getting blind apearently lol
                      but since the PCB did not give any volts out of it, i'm going to
                      wait until I can see what's going on there.
                      • jetadm123
                        • 2169
                        Hopefully, you read the link I provided. If U7 has failed, it prevents the power supply from starting up, which results in zero ouput from the power supply.
                        • sabre504
                          • May 2010
                          • 449
                          U7 on pic
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Okay, let me add more detail and try again.
                            1) Put multimeter to 20V DC if manual.
                            2) Disconnect all boards. We are just going to test the power board alone. Put back all screws on the power board.
                            3) Put your black probe on the ground screw. Use the ground screw next to cap C848 (upper left hand corner in your picture). This will be your secondary ground.
                            4) Put your red probe on each pin on connector P803.
                            5) Report measurements for each pin.
                            If you still get 0V DC for all the pins, then measure the DC voltage across capacitor C810 (green small one next to the largest one). Put your black probe on the negative side of the cap and red probe on the positive side.
                            Report and note if the voltage is steady or fluctuating. C810 plays an important part of the startup process for the SMPS. The SMPS generates the secondary voltages that go to P803.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Not quite correct.
                              U7 is the reset controller for the processor on the signal card. If it is bad the processor will not start, and the power LED will not come on. You WILL still have the normal voltages out of the power supply.
                              PlainBill
                              • jetadm123
                                • 2169
                                Not quite correct.
                                PlainBill
                                Ah, thanks PlainBill for sending me on the path to enlightenment.
                                • playman
                                  • Jan 2011
                                  • 252
                                  I still got 0 reading from the pins.
                                  The green one is C809 and then brown circle is C810 ( I belive)
                                  anyway I checked the C810 and got 0 reading but for a split second I got the - sign on the DMM.
                                  Some one unknown came to me, and thought it would be funny to startle me,
                                  while I was testing it, so I accedentily touched the big cap, wich created some sparks, but I checked it afterwards and it gave me 321volts.
                                  So I hope I did not do any damage to it. having a double heartattack is not funn
                                  • playman
                                    • Jan 2011
                                    • 252
                                    Not quite correct.
                                    PlainBill
                                    That was exactly what I thought.
                                    Yay +1 for the newbie
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Sorry, check the green one. I can't see C809 from the angle of the picture.
                                      Put your red probe on the positive leg of the small green cap C809 cap. Put your black probe on the negative leg of the small green cap.
                                      • playman
                                        • Jan 2011
                                        • 252
                                        No no the fault is mine, since I took the shot slightly tilted.
                                        I've allready done that.
                                        And if I'm not mistaken, the black part of the circle on the PCB means negative, right?
                                        • Caly411
                                          burned mosfet wich has written on top "I6 GUE 8v1507"
                                          by Caly411
                                          Hi, Im having a similar problem with my Acer Nitro 5 AN517 52, took it to repair and they said that the problem was a burned mosfet wich has written on top "I6 GUE 8v1507".
                                          There is written PQB12 on the motherboard right next to it.
                                          Does anyone know if there is soemthing similar I can buy to replace it with?
                                          Seems impossible to find theidentical mosfet online.
                                          08-30-2023, 10:48 AM
                                        • cacko85
                                          Asus R520U wich type od ssd ??
                                          by cacko85
                                          Hello folks
                                          Laptop Asus R520U problem with instaling ssd drive, laptop come with 2.5" hdd drive, but there is slot for ssd (M.2 I think) I put SAMSUNG 500GB SSD 980 Pro M.2 PCI-E NVMe, but can't be recognized in bios or windows
                                          I don't have any other type of ssd to try, maybe the bus is sata3 not pci-e ??
                                          Any info ?? tnx...
                                          08-13-2021, 03:07 AM
                                        • Malcolma172
                                          Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
                                          by Malcolma172
                                          I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
                                          After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
                                          After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
                                          07-23-2025, 01:20 PM
                                        • ladharimohamed2
                                          Need bios toshiba satellite pro r50-b-15j
                                          by ladharimohamed2
                                          I need bios for toshiba satellite pro r50-b-15j motherboard faebsy2
                                          i have tried this :
                                          but no power
                                          and i tried this
                                          the laptop worked but asked for a password
                                          i have tried many with same motherboard name wich is FAEBSY2 A5A003954010 A but the laptop didnt turn on (no lights, no fan spinning)
                                          i have attached my original bios wich has been corrupted after a windows update (turn on but black screen)
                                          if any have the bios for the exact model name will be great "toshiba satellite pro r50-b-15j"...
                                          04-18-2024, 07:54 AM
                                        • Larchemont
                                          HP Elitebook 840 G1 BIOS Issues
                                          by Larchemont
                                          Hello Folks,
                                          i have a HP Elitebook 840 G1 with a locked BIOS and i have bought a CH341a (black PCB). My problem is that the Bios Chip reads 25Q128A 13ECO and i cannot find a profile for this chip in any of the software recommended in the guide threat in this forum. The chip cannot be detected wich i dont find too surprising, but i can read the chip with random other profiles selected.
                                          I have found a post in this forum in wich the user stated he was able to flash this exact chip with the CH341a and the testclip, but unfortunately this user is no longer active. In...
                                          08-21-2022, 07:24 AM
