STONE capacitors... suck. Badly.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Just today a neighbor of mine came in with a monitor he got for very cheap. It was one of those 12v powered things. Likom HD17A i think it was. It did not come with a power supply so he asked me to test it. Of course, it didn't work. Power LED would blink orange continuously and there was a ticking sound along with a slight flickering of the screen (lamps didn't power up).
    2 bad NKCON caps on the inverter. Btw the inverter was using a TL494... Swapped out, still no change. All STONE caps on the combined PSU/logic board affair, in some weird short and fat form factor. All looked good... but as i started swapping them out for Rubycons, the monitor would power up, but only when the LCD ribbon wasn't connected.
    At this point i was fed up with it and knew it isn't gonna work, so i just jammed the LCD ribbon in with the thing powered on. Surprise... it lit up. But with a full white screen. All power supplies tested good at this point btw.
    The panel had an easily accessible driver board. Must be a really old panel. It had a big ACER chip on it, so i assume that's who made it. Probing around i found one of the three picofuses open. Jumpered it, and double surprise. No more white screen.
    However, there were several lines on the screen that shouldn't have been there, the picture was slightly offset, and the thing continually cycled thru service patterns. No way of getting out of there. So not only did the STONE caps fail without bloating - they went bad enough to corrupt the EEPROM. I haven't checked the chip itself but i believe it was the 3.3v rail that did the damage, as it was a bit wiggly before recapping. If it was "a bit wiggly" on the multimeter i don't want to know how it would've looked on the scope.
    This one was a lost cause.
    A working TV? How boring!
  • Curious808
    Microwave reacts badly to fat
    by Curious808
    Microwave seems to react badly to anything fatty. At the mildest, the time display starts flickering. Sometimes, it resets, the display goes black and the remaining time is gone. Sometimes it zaps and crackles. Symptoms seem to be worse depending on how fatty the food is. Goes wild, dimming from about the first second of trying to reheat a strip of precooked bacon. A precooked meatball causes occasional dimming. It works just fine with no-fat foods.
    Started a couple of weeks ago when I put in a small raw porkchop. After a few seconds, the unit started spitting and zapping, and I...
    11-15-2023, 10:09 AM
  • verniumEN
    Acer Extensa 15 EX215-23-R7NG - BIOS, badly need help :(
    by verniumEN
    My laptop model is EX215-23-R7NG
    BIOS chip XM25QU128C
    Here is my original bin file, as well as how the BIOS chip looks like
    My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
    Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...
    04-21-2025, 02:31 AM
  • ktmmotocross
    Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
    by ktmmotocross
    Acer 515-54G
    DA0ZAWMB8G0
    Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
    i dont uderstand this. Charger ic BQ24780S
    ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
    What is pulling my ACDET down when i apply power even without BQ ic...
    12-02-2022, 12:03 PM
  • jabam
    Badly need working Bios for Galaxy GTX560se
    by jabam
    Good day, anyone here have galaxy gtx560se vcard? i need working bios for it..
    i've search online in techpowerup but the bios there has red garbaged color..
    my card issue is error code43 and it has red garbaged color..
    anyone can help me?if you have back-up bios for it..thank you
    10-30-2022, 03:37 AM
  • Zilicon
    hp pavilion g6 R33 not not turning on
    by Zilicon
    Please help!!!
    The above motherboard came with the main +vin voltage shorted. I had it cleared and faulty components replaced. now, the DC led light glows but the system does not start.
    3.3v is present at the power switch, and there's also a good connection to the EC (U14) pin 19 and there is also a good connection to the resistor at the RAM slot area with voltage appearing.
    i noticed that the DC power leds flashes three times when the power button is pressed with just the battery plugged in, it won't flash when plugged in.
    everything seems...
    05-23-2021, 11:27 AM
