Monitor LG Flatron W1934S 2 seconds then turned off
  • francesco3000
    • 4
    Hello everyone sorry for the language is not perfect
    can you help me if I have a monitor that lgw1934 and turned on 2 seconds then goes off in another post as I tried to pull one at a time, CCFL connector capacitors look good
  • smason
    • 1652
    Re: Monitor LG Flatron W1934S 2 seconds then turned off
    When you say it goes off, do just the backlights go off, or the whole monitor (power led)?
    Do you have a multimeter?
    • francesco3000
      • 4
      Meanwhile, thanks for the reply, turns off the monitor but the light is on indicating that stays on then just turn off the button and turn it on again and he turns on for 2 seconds
      • retiredcaps
        • Apr 2010
        • 9271
        Possible causes of "2 seconds to black" can be
        a) bad caps
        b) bad ccfls and/or ccfl wiring
        c) bad inverter transformer
        d) bad ccfl sense circuitry
        All are discussed in more detail starting with post #13 and #14 at
        https://www.badcaps.net/forum/showthread.php?t=10419
        --- begin sig file ---
        --- end sig file ---
        • francesco3000
          • 4
          hello and thanks for the reply, the problem is that the backlight turns off the power LED stays on
          capacitors do not seem inflated.
          the primary measure all 0.5 ohm transformer, the secondary measure 618ohm.
          resistances are all ok
          and can do some measurements on this chip oz9938gn-ic I know that this takes the security chip
          I can give a hand to do some testing
          I am attaching photos
          possibbile would find a wiring diagram
          • lcdman
            TinkerTech
            • Nov 2010
            • 232
            • U.S.A.
            Heres a service manual .PDF on this monitor. Hopes this helps you!
            A Fellow 1/2 Italian
            lcdman
            • francesco3000
              • 4
              hello
              Thanks and we'll try '
              • ipman
                • Jul 2011
                • 159
                I've got one of these monitors.
                It was the clasical "2 seconds to black" simptom.
                When I opened it, somebody resoldered some connections, but according to the former owner, it was not repaired before
                Found 2 bulging caps, Ltec brand.
                Then I've found this thread, opened the service manual and these two caps cannot be found. Instead of these 1000uF/6.3V general purpose caps, the manual listed a 1000uF/10V low-esr cap marked as C812. The picture above confirmed that it was an empty space instead of the second cap. They measured an ESR value 6 times more than they should have, and they had around 300uF instead of 1000 nominal. Replaced with an Rubycon HM 1200uF/16V salvaged from a junk motherboard.
                C501 and C810 were originally 470uF/25V, but they were replaced with 1500uF/16V Rubycon HM which survived intact, to my surprise. They show the capacity and ESR in spec. Replaced with Samxon GF (I know, bad series, but cannot find something better. Luckily, they are away from heatsinks.)
                Now the monitor is working again as it should be.
                • aziiiz
                  • Sep 2009
                  • 4
                  • algeria
                  problem of 2 seconds then it goes DARK
                  I reversed the CN501 & 502 by CN503 & 504.;
                  It works fine ...
                  • ipman
                    • Jul 2011
                    • 159
                    Another one repaired.
                    Story: bought the monitor as a bargain. According to the former owner, afther heating-up, backlight flickered until went totally dark. Bought as defective.
                    Opened the monitor, replaced two 470uF/25V low-ESR Hermei caps with Samxon GF, one 1000uF/10V Jackeh lowESR with Samxon GT. Nothing wrong with them as measured with ESR meter tough.
                    Resoldered a lot, what seemed to be cold joints: inverter transformers, caps, even the HV connectors on PCB.
                    Tested on bench with back cover removed, everything fine.
                    Assembled it, 2 seconds working, then black, but image was there.
                    Dissasembled again, worked without back cover!
                    The back panel was pushing against one HV pigtail between PCB and lamps ... The monitor is working again now.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Congratulations. I shudder to think how long it would have taken me to figure that problem out.
                      PlainBill
                      • ipman
                        • Jul 2011
                        • 159
                        It took me a full day to figure out why it was working without back cover but not assembled. I cannot figure out how many times I dissasembled and reasembled the monitor tough.
                        And another day to measure all caps and find replacements locally.
                        Anyway, there was no rush.
                        • djmurati
                          • Nov 2011
                          tanks ipman......... I have like same problem LG flatron w1934s now finish......
                          You helped me a lot THANKS take care fully.....
                          • LaGGER
                            • Aug 2013
                            • 3
                            • MKD
                            I have problem with LG W1934s
                            2sec and go off is solved but not its blinding maybe problem is a DVD ans speakers with magnet ofc I go to degaus monitor and blinbing is lower
                            • LaGGER
                              • Aug 2013
                              • 3
                              • MKD
                              Sry for my bad english...
                              2 sec go dark prob is solved by manual power on-off backlight but few months later backlight flashing IDK why whats the problem maybe speakers and DVD whic is almost 2-5CM placed from the monitor speakers are with magnet
                              • palamattam
                                • Sep 2013
                                • India
                                I had the same problem with my LG flatron w1934s,display showed momentary and vanishes. I tried many online forums and learned to open the monitor. The capacitors showed in good condition.Contacted LG and one day the serviceman came to my house.He inspected the monitor and told me the lcd display is damaged and will charge apxy Rs 4000/-.There was no point spending that amount,instead I can buy a new monitor. While checking the power supply I found 600volt supply to the display is off.The power board components are surface mount and impossible to repair at home. Surveyed Lamington Road at Mumbai. One shop had separate LCD inverter board with connection details which costs just Rs.200.I connected the board and Lo the monitor worked !!
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  LaGGER
                                  1, Do not hi-jack other threads
                                  2, Do you have a W1934S or a W1932S
                                  3, The picture you posted in the other thread is useless
                                  unless you post a much better one we can not help
                                  • Jastreb
                                    • Mar 2014
                                    • Serbia
                                    Sorry for digging out the old thread but since the problem is the same Ill use this one.
                                    Problem : LCD monitor LG Flatron W1946S turns on briefly then goes off. Backlight goes off, but power light is on, so as indicated here, Ill check on caps, wiring, invertor and ccfl's.
                                    Reporting back with solution and images.
                                    Thanks to lcdman for the pdf repair guide.
                                    • borbs
                                      • Feb 2013
                                      • Portugal
                                      Hi Jastreb, i have same problem with that monitor. Did you fix yours? What was the problem?
                                      • ANIBALYMARTA
                                        • Sep 2013
                                        • SPAIN
                                        pin 3 of ic 501 (OZ...) to gnd. If timer no 3v = no lamp check.
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • matthewmcconaughey
                                          I need help with my friend Sony GDM-FW900 24” CRT
                                          by matthewmcconaughey
                                          Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                          I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                          1. It started with a bright and greenish picture upon starting a cold monitor.
                                          2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                          05-16-2023, 03:15 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
