Acer P193w - blink screen
  • Rtech
    • Jul 2010
    • 1095
    Re: Acer P193w - blink screen
    Well done,glad you are up and running again.
    • xtiansy
      • Nov 2011
      hi! i'm new here. i have the same model as this and got the same issue. two ccfls on top are busted. it's hard to get a replacement from where i am.
      is there any way i could run this lcd with only 2 bottom ccfls?
      i saw an article online about bypassing the feedback.
      http://www.bestelectronicarticles.co...ht-system.html
      can this be done so i can run it with busted ccfls? if yes, how? i can't find the datasheet of the inverter ic.
      btw, i already removed the busted ccfls, replaced the ecaps and reflowed some bad solder.
      thanks in advance!
      • forges
        • Dec 2011
        I have the same problem, but if i connect all 4lamps it blinks if i connect only 3 lamps it still image for 3 secs. then off.
        • forges
          • Dec 2011
          I have 14,85v at d803; 5,08v at d805;
          I have 14,85v at u502; 6,89v at u501 but in this case variable to 0v-6,89v continuosly.
          I have changed 5 caps; 2 of 1000uF, 2 of 470uF and 1 680uF.
          • Rtech
            • Jul 2010
            • 1095
            Well without a cct diagram,its impossible to help, as who knows what D803,D805 etc are,and where they are in the cct,have you got a schematic ?? and if so put it on here,and then hopefully you will get some guidance.
            • PlainBill
              • Feb 2009
              • 7034
              Service manual is at Elektrotanya.
              PlainBill
              • forges
                • Dec 2011
                #27
                Service manual does not see this.
                I have 6,89v at primary t501 and 6,89v at primary t502, but only for 2 secs at power on.
                Whitout power it has 485 kohm and 482 kohm between the two out of t501 and t502
                • PlainBill
                  • Feb 2009
                  • 7034
                  OK, you have got 'Two seconds to black'. You've established the transformers are likely good; that eliminates one of the probable causes.
                  Have you tried substituting known good CCFLs? Or hooking up a known good panel?
                  You stated you replaced a number of capacitors. What brand and series did you use as replacements?
                  PlainBill
                  • forges
                    • Dec 2011
                    #29
                    I have subst with DAEWOO units.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      And what was the result?
                      PlainBill
                        Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) Spin 512 Specification for Upgrade or Repair
                        This specification for the Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB boardview and 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                        09-06-2024, 04:40 PM
                      • DaniK
                        Acer Aspire E5-574-52RH - black screen
                        by DaniK
                        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                        Symptoms are:
                        - random black screen after displaying Acer logo...
                        02-21-2024, 06:27 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • rybby
                        Acer Aspire 5 A515-51 power on but black screen
                        by rybby
                        I have an acer aspire 5 a515-51 that turns on but has a black screen.
                        This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                        Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                        06-16-2023, 09:41 AM
                        09-06-2024, 05:27 AM
