Could use some help, trying to fix HP 1940 LCD
+ More Options
Posts
  • playman
    • Jan 2011
    • 252
    Re: Could use some help, trying to fix HP 1940 LCD
    You worked too hard. Pins 1 and 3 are connected internally. For anyone else doing this, simply test 2-3, 2-4, and 3-4. This test is simply to determine if there is a short.
    allright i'll try to remember that.
    So if I understood you right, #1 is broken, and therefore I should replace all 4 c5707?
    The J598 goes back into the board?
    • playman
      • Jan 2011
      • 252
      I wont be able to reply again until on monday, so just blast your thoughts at me
      P.S. I wish that the edit button didint have time out on it.
      • retiredcaps
        • Apr 2010
        • 9271
        If Q808 is bad, then Q809 is its companion. Look at your board and you will see they work in pairs. So if Q808 is bad, Q809 should be replaced as well.
        --- begin sig file ---
        --- end sig file ---
        • playman
          • Jan 2011
          • 252
          yeah ofcourse how silly of me
          allright they have all been replaced now.
          Is there anything else I should do or test before I screew it back in and power it on?
          • playman
            • Jan 2011
            • 252
            Update!
            Well I just repacked it and plugged it in for testing, with 2 fingers crossed and other
            hand ready on the socket
            So now i'm just going to fully assemble it and leave it on for awhile, and see if it will continue to work.
            Now I should be able to fix the rest of them.
            thanks every one for inputs and help
            With regards
            Johannes
            • rqbwins
              • Mar 2012
              • 8
              • romania
              #26
              Hello.Can Anybody tell me what kind of transistor is in q885.Becouse mine was so burned that I could not read the inscription on it.Thank you in advance for your help.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                It is might be fu9024 (the same one as to the right of T802 and left of the big cap).
                These Benq boards are infamous for having bad solder joints on the inverter transformers, shorted c5707 transistors, shorted fu9024 mosfets, and blown picofuse.
                See
                https://www.badcaps.net/forum/showthread.php?t=8598
                • Jasgriff
                  • Feb 2012
                  • 578
                  Already answered
                  Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                  How to resize your pictures guide click HERE
                  Retiredcaps Ideal post example click HERE
                  • rqbwins
                    • Mar 2012
                    • 8
                    • romania
                    #29
                    Thank you for this quick reply.I would like to bother you guys with one more question.Which of the following transistor should I buy?
                    1:IRFU9024 IR CI -ROHS-
                    2:IRFU9024NPBF TRANZISTOR MOSFET,P I-PAK -55V-11A
                    3:IRFU9024N IR HEXFET(R) POWER MOSFET 55V/11A38W -ROHS-
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      They will probably all work the U9024 is the important bit.
                      Where are you looking at them - digikey/mouser/elsewhere.
                      If the first two there will be data sheets which will give you an idea of the differences - it is usual package/ size/ manufacture or even just local product identification.
                      You need to check that you get one the same size as you have.
                      You need to get the correct mounting - surface or through hole
                      For example IRFU9024N is the standard the PBF means it is lead free
                      I-pak is the package style
                      If you look here you can find the package style you need
                      http://www.irf.com/package/pkhexfet.html
                      • jetadm123
                        • 2169
                        #31
                        You can purchase a repair kit from a Romanian seller on eBay:
                        http://www.ebay.com/itm/REPAIR-KIT-E...item19cebe40e0
                        • rqbwins
                          • Mar 2012
                          • 8
                          • romania
                          #32
                          Thank you for your help.I will post tomorrow how it turns out.
                          • rqbwins
                            • Mar 2012
                            • 8
                            • romania
                            #33
                            On the back of the panel I have 2 diodes of the same kind.Can someone tell me what kind of diodes are ?
                            I changed the tranzistors and ewerything else but I am having the same problem.
                            One of the diodes from the back seems to be blown.
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Can you post good clear pictures of the front and back of your boards
                              with a close up of the area with the diodes on.
                              • rqbwins
                                • Mar 2012
                                • 8
                                • romania
                                #35
                                There it is
                                • Nocta
                                  • Mar 2012
                                  • 117
                                  • Argentina
                                  #36
                                  Those seem to be caps for me. The one on the bottom of the board says C819.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Picture is poor in comparison with your earlier ones. Cant even read the board numbers
                                    for the parts. Nevertheless I think thay may be SS24 SMB 40V 2A is that what they look like?.
                                    Please take note about the resoldering of the boards - if you dont do it it could blow all you have
                                    put in.
                                    @Nocta the cap is just below the diode.
                                    • rqbwins
                                      • Mar 2012
                                      • 8
                                      • romania
                                      #38
                                      Here are the new photos.Hope that you can see better on this pictures
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        That is a much better picture - still cant read what it says on them perhaps you can and post it. Did you check them - The traces nearby would give me some concern - do they
                                        still conduct?
                                        • jetadm123
                                          • 2169
                                          #40
                                          You never did say what problems you're experiencing. Can you please give us a more detailed description of the problem? Does the power led remain on? Do you get 2 seconds to black? A complete description of the symptoms helps members point out things to check.
                                          • Topcat
                                            Topcat's Budget Telephone System- Panasonic KX-TA624 Conquest
                                            by Topcat
                                            About 10~12 years ago I was given this Panasonic KX-TA624 analog telephone system with its 'master phone' and box full of extension telephones. It's been up in the attic all this time, untouched/unused since I didn't have a land line. It has all the line expansion cards, making it able to handle up to 6 outside lines and 24 internal extensions. I was told this system was removed from a shopping center that upgraded to a VOIP system.
                                            Why am I wasting my time on this you wonder? Well, I need a phone number for a little venture I'm working on....and I sure as hell don't want my personal...
                                            10-18-2019, 02:02 PM
                                          • metinjsh
                                            HP-1940 2STB
                                            by metinjsh
                                            Monitor HP-1940. PSU - BEN 48.L1G02.A01
                                            Hallo! I carefully check all the tips. At first there were bad transistors C5707 I chaged them, but after few hours problem repeated. I changed all capacitors and resolder transformer solder. And changed transistors again, but two of them all the time "blow".
                                            Fuse is ok.
                                            Picture: http://*************/photo/my-images/10/dscf3309s.jpg/
                                            Some of capacitors are larger then original, but it's just becouse I could not get the right rated voltage so I took higher voltage caps, but the same capacitance
                                            01-21-2012, 11:33 AM
                                          • alistair
                                            HP 1940 Lamps
                                            by alistair
                                            i Need to replace the bulbs in an HP 1940 but i cant find the part number anywhere to order them. i tried ordering some standard 19" bulbs but they werent quite right. i repair monitors for a living and im stumped. anyone know the part number?
                                            03-01-2011, 03:43 PM
                                          • terminatorX
                                            Hp 1940 flicker
                                            by terminatorX
                                            I have one hp 1940 (Benq 48.L1G02.A00) that when plugged to power starts flicker rather rapidly and just keeps doing that. To mention not connected to PC. The power led is on.
                                            It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators. Is it the usual C5707 transistor problem?
                                            02-09-2012, 12:45 PM
                                          • terminatorX
                                            Bad Hp 1940 and 1955
                                            by terminatorX
                                            Hello=)
                                            I'm new here so please bear with me.
                                            I'm a newbie in this field....
                                            I have googled alot and found a couple of threads here but decided to make one thread of my own.
                                            It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators....
                                            02-08-2012, 03:47 PM
