Could use some help, trying to fix HP 1940 LCD
  • playman
    replied
    Re: Could use some help, trying to fix HP 1940 LCD
    If Q808 is bad, then Q809 is its companion. Look at your board and you will see they work in pairs. So if Q808 is bad, Q809 should be replaced as well.
    yeah ofcourse how silly of me
    allright they have all been replaced now.
    Is there anything else I should do or test before I screew it back in and power it on?
  • retiredcaps
    replied
    Originally posted by playman
    So if I understood you right, #1 is broken, and therefore I should replace all 4 c5707?
  • playman
    replied
    I wont be able to reply again until on monday, so just blast your thoughts at me
    P.S. I wish that the edit button didint have time out on it.
  • playman
    replied
    You worked too hard. Pins 1 and 3 are connected internally. For anyone else doing this, simply test 2-3, 2-4, and 3-4. This test is simply to determine if there is a short.
    allright i'll try to remember that.
    The J598 goes back into the board?
  • PlainBill
    replied
    This can be done with the transistor in circuit. It is also STRONGLY recommended that the companion transistor be replaced.
    PlainBill
  • playman
    replied
    Code:
    C5707  1
          ___
    	 |___|
    	|_____|
    	 2 3 4
    Bah the explenation ASCii is out of order, even with the CODE but you should get the general idea.
    a) black probe on pin 1, red on pin 2 - 003
    b) black probe on pin 1, red on pin 3 - 002
    c) black probe on pin 1, red on pin 4 - 002
    d) black probe on pin 2, red on pin 1 - 003
    e) black probe on pin 2, red on pin 3 - 003
    f) black probe on pin 2, red on pin 4 - 003
    g) black probe on pin 3, red on pin 1 - 002
    h) black probe on pin 3, red on pin 2 - 003
    i) black probe on pin 3, red on pin 4 - 002
    j) black probe on pin 4, red on pin 1 - 003
    k) black probe on pin 4, red on pin 2 - 003
    l) black probe on pin 4, red on pin 3 - 002
    #2-3-4
    a) black probe on pin 1, red on pin 2 - N/A
    c) black probe on pin 1, red on pin 4 - N/A
    d) black probe on pin 2, red on pin 1 - N/A
    e) black probe on pin 2, red on pin 3 - N/A
    f) black probe on pin 2, red on pin 4 - N/A
    h) black probe on pin 3, red on pin 2 - N/A
    i) black probe on pin 3, red on pin 4 - N/A
    j) black probe on pin 4, red on pin 1 - N/A
    k) black probe on pin 4, red on pin 2 - N/A
    l) black probe on pin 4, red on pin 3 - N/A
    (I just hope his was the "right" testing circle)
    The DMM was set to 2k ohm, and becouse of the bad probes I shorted them
    and got a reading of 002, just in case if needed for comparison.
    I belive my first transistor is broken and 2-3-4 are ok. (wild guess)
    I also tested the J598 (Q805 on the board) and it had the same reading as 2-3-4
    Altough I did de-solder them of the board.
    But just to be sure, can I test all components on the board or do I have to
    de-solder them and test them that way? I was told that I had to desolder them, but I dont know more then that hehe.
    Is there anything else I should check?
  • Scenic
    replied
    ^also look how thin the exposed wires are.. no wonder the reading is off
  • retiredcaps
    replied
    I decided to post a picture of my multymeter
    Your black lead is broken on both ends and the wires are both showing outside the insulation.
    This is fine for taking ohms measurements with POWER OFF and lcd unplugged. However, I would NOT use this black lead for anything that requires a power measurement. I highly suggest you get a new black test lead.
    Cheap multimeters come with cheap test leads (I know from first hand experience).
  • alexanna
    replied
    Check the transistors for shorted condition
  • playman
    replied
    Blinking screen with correct picture? Power supply or inverter in auto restart mode. More likely to be the PSU, haven't seen an inverter controller with auto restart yet.
    If the picture is correct but just blinking, that means the active components are likely okay. Look for bad caps or sloppy soldering.
    There is no picture, it's just going from black to light black,
    it's just like the screen is starting up but then fails and turns off,
    and the power light flickers with it.
  • Th3_uN1Qu3
    replied
  • playman
    replied
    Thanks for that PlainBill.
    Unfortunetly I have a sad announcement to make.
    For some reason the stickers on the panels must have beens switched,
    therefore the HP 1940 does not have the "2sec blackout"
    instead they have a blinkink screen wich follows by a high frequency sound.
    I was so certain that they had the "2sec blackout", unless the "2sec blackout" changed
    into the blinking problem, wich happens about 2sec interval repeatetly.
    (next time i'll personally check them before deciding what's wrong with them)
    For some reason I cant find the edit button for my first post...
  • PlainBill
    replied
    Something to remember is that while good probes would read lower, the resistance of a good transistor would be several orders of magnitude higher. A reading of even 100 ohms across two leads of a transistor indicates either a parallel component is distorting the reading, or the transistor is defective. For decades electronics technicians used meters that couldn't resolve even 1 ohm. Certainly your dmm is not a top of the line model - frankly, it's definitely low end, but should be adequate for troubleshooting monitors.
    PlainBill
  • alexanna
    replied
    You should get some new leads for your DMM,But for now as long as you continue to get the 1 ohm reading each time you touch the two leads together use that as your 0 ohms,I think you will be able to find the shorted transistors.
  • playman
    replied
    The reading you’re getting from your ohmmeter is most likely caused by your leads. Remove the leads from the ohmmeter and find something to fit into the holes where the leads plug in, a small machine screw may work just don’t force anything then short them together do you get closer to 0 ohms.
    Thanks for that tip, lol I cant belive I could not think of anything that easy
    you were right, I inserted ~6cm copper wire into the holes and I got a reading of 0.4
    So... anything I can about that? maybe change the leads, i'm not even sure if I can get replacement leads here :/
  • playman
    replied
    That means your probes suck (they have high internal resistance). But that doesn't matter as you won't have to measure current in a monitor. They are fine to use.
    Allright.... could you clarify that alittle more to me?
    As why they suck becouse they have high internal resistance.
    Well then, I guess I better start probing then. (that sounded horrible lol )
  • alexanna
    replied
    The reading you're getting from your ohmmeter is most likely caused by your leads. Remove the leads from the ohmmeter and find something to fit into the holes where the leads plug in, a small machine screw may work just don't force anything then short them together do you get closer to 0 ohms.
    You may also have a weak battery.
    As long as each time you short the leads together you get the same 1 ohm reading you will probably be ok for now, just use that reading as a base line.
    If when you say you're getting a flickering on and off of the backlights, pay particular attention to checking the transistors for a shorted condition. These being shorted can cause the flickering and also what is described as 2 seconds to black. This is described in post #13 step # 2 of the link that retiredcaps provided.
  • Th3_uN1Qu3
    replied
  • playman
    replied
    Dang........ I never expected to get so fast replies and "right on the spot" I LOVE IT!
    any way, I guess I'll have to stop criticizing my English lol.
    Before I start probing everything, I read the part about the multymeter test.
    If you have a manual ranging multimeter, set it to 200 (two hundred) ohms.
    Touch the black and red probe together. It should read 0.3 or 0.4 ohms. If it is higher than 1.0 ohm, there is something wrong with your multimeter.
    Mine reads 01.1-01.0 so I was wondering if it was still safe to use?
    Not that it should matter I decided to post a picture of my multymeter, it was the cheapest one I could find, that could do what I wanted at that time.
    I hope it's good enough.
  • retiredcaps
    replied
    For Benq boards, you want to check the following:
    1) transistors marked c5707 for a short (should be 4 of them)
    2) fets marked fu9204 for a short (should be 2 of them)
    3) picofuse to see if it is open (should be 1 of them)
    You must (mandatory) resolder all 4 inverter transformer pins even though the soldering may look good.
    I will leave it to you, for learning purposes, to identify each of the above. With the guide that I posted, you should be able to test items #1, #2, and #3.
  • Topcat
    Topcat's Budget Telephone System- Panasonic KX-TA624 Conquest
    by Topcat
    About 10~12 years ago I was given this Panasonic KX-TA624 analog telephone system with its 'master phone' and box full of extension telephones. It's been up in the attic all this time, untouched/unused since I didn't have a land line. It has all the line expansion cards, making it able to handle up to 6 outside lines and 24 internal extensions. I was told this system was removed from a shopping center that upgraded to a VOIP system.
    Why am I wasting my time on this you wonder? Well, I need a phone number for a little venture I'm working on....and I sure as hell don't want my personal...
    10-18-2019, 02:02 PM
  • metinjsh
    HP-1940 2STB
    by metinjsh
    Monitor HP-1940. PSU - BEN 48.L1G02.A01
    Hallo! I carefully check all the tips. At first there were bad transistors C5707 I chaged them, but after few hours problem repeated. I changed all capacitors and resolder transformer solder. And changed transistors again, but two of them all the time "blow".
    Fuse is ok.
    Picture: http://*************/photo/my-images/10/dscf3309s.jpg/
    Some of capacitors are larger then original, but it's just becouse I could not get the right rated voltage so I took higher voltage caps, but the same capacitance
    01-21-2012, 11:33 AM
  • alistair
    HP 1940 Lamps
    by alistair
    i Need to replace the bulbs in an HP 1940 but i cant find the part number anywhere to order them. i tried ordering some standard 19" bulbs but they werent quite right. i repair monitors for a living and im stumped. anyone know the part number?
    03-01-2011, 03:43 PM
  • terminatorX
    Hp 1940 flicker
    by terminatorX
    I have one hp 1940 (Benq 48.L1G02.A00) that when plugged to power starts flicker rather rapidly and just keeps doing that. To mention not connected to PC. The power led is on.
    It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators. Is it the usual C5707 transistor problem?
    02-09-2012, 12:45 PM
  • terminatorX
    Bad Hp 1940 and 1955
    by terminatorX
    Hello=)
    I'm new here so please bear with me.
    I'm a newbie in this field....
    I have googled alot and found a couple of threads here but decided to make one thread of my own.
    It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators....
    02-08-2012, 03:47 PM
