new one here!!!!
+ More Options
Posts
  • application_1208
    • Mar 2011
    new one here!!!!
    please welcome me in this forum..because i read the some of your post or thread is tested im willing to learn and share my knowledge..thanks for letting me sign in in your plesant foru,....
  • EGuevarae
    • Nov 2008
    • 1336
    Re: new one here!!!!
    You are welcome
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • justice171
      JVC LT-50N795 Stuck on Wisdom Share Logo
      by justice171
      I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
      It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
      Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
      Thanks in advance!
      11-04-2024, 02:55 AM
    • kurland
      MacBook A1707 - low batt sign displayed then shutdown - but battery voltage is ok!?
      by kurland
      Hi fellow repair gurus,
      Liquid damaged A1707 was stuck on 5V. I replaced corroded CD3215 and SMC now successfully raises voltage to 20v.
      The fans spin, the screen comes on and displays a "low battery" sign before the machine shuts down.
      After that the screen and fan stays off but PPBUS_G3H continue to toggle every 4-5 secs between
      • 11.4v (and 170mA current draw on usb-c power meter)
      • 12.6v (zero current draw)
      The toggeling occurs when battery is connected but regardless if external usb-c is connected or not. It seems...
      10-21-2022, 02:04 PM
    • Instafixx
      IPhone 11 Temperature Sign
      by Instafixx
      Hello, Namaste.
      We have an iphone 11 for which we had changed the NAND IC and upgraded from 64gb to 128gb.
      After upgrading the iPhone shows a Temperature Sign but there is no heating in the board. We did a lot of trial and error and found that whenever the Charging Flex and Power Flex are connected together the sign shows. If either one is removed there is no such sign.
      We replaced the lower board just to check if there was a problem with the connection pads maybe but the issue persists.
      I think we have messed up while replacing the NAND. Any help from anyone...
      10-18-2022, 06:23 AM
    • Per Hansson
      Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
      by Per Hansson
      I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
      The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
      The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
      As I find linear high voltage regulator designs interesting I drew up the attached schematic...
      12-23-2023, 06:20 AM
    • eliasseverholt
      Looking to learn about troubleshooting my Lenovo L14 Gen 1
      by eliasseverholt
      Hello!
      Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
      So I'd love to learn my mistakes and...
      12-19-2023, 06:13 PM
