Benq FP531 - Pink Screen
  • mike9h29
    • Mar 2011
    • 60
    Hi every one.
    Was looking for a solution to fix my monitor, and found this website. Maybe some one can help me pls?
    I have a Benq FP531 15" TFT Monitor that is faulty. The problem with the monitor is that when swiched on, it will only display a pink picture and some horizontal lines.
    Could this be faulty caps? or transistors pls?
    Thanks!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Benq FP531 - Pink Screen
    Originally posted by mike9h29
    Hi every one.
    Thanks!
    The pink picture could indicate bad CCFLs. Standard first step - open it up and attach pictures.
    PlainBill
    • sofTest
      • Aug 2008
      • 361
      Can also be a bad cable between the PC and monitor. Try another cable, and also, try connect to another PC, if not already tried.
      Be a mensch
      • mike9h29
        • Mar 2011
        • 60
        PlainBill
        ok. will take pictures later today and post them.
        • mike9h29
          • Mar 2011
          • 60
          Its not a cable issue as the pink screen come even when the monitor is not connected to the pc.
          The Benq logo will not show.
          • mike9h29
            • Mar 2011
            • 60
            Hello
            attached are the pics of the MB and Picture.
            The pink picture will go after 2 seconds, then a black screen will follow. after this, the green LED will change to orange (no input)
            There are also some horizontal lines in the pink picture.
            Any replies will be greatly appreciated.
            Mario
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              vertical lines and pink? sounds like it might be a bad panel
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
                by momaka
                03-15-2023, 10:17 PM
              • abajor
                A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                by abajor
                Having this very weird issue.
                The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                I swapped with a working screen from an A2141 waiting for parts.
                The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                04-27-2024, 01:37 PM
              • 3D Modelka
                AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                by 3D Modelka
                Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                02-09-2024, 02:42 AM
