Dell SP2008WFPt no picture
  • jetadm123
    • 2169
    Re: Dell SP2008WFPt no picture
    Originally posted by kynax
    Indeed, I misread your previous post.
    Which one is the input pin?
    Refering back to the photo in post #9, with the tab on the bottom, input pin is left, output is middle pin and ground is right pin.
    • jetadm123
      • 2169
      That's also what I though.
      I still get 0V on all pins.
      I compared with the other regulator and that one is still working.
      EDIT: Is is possible that this regulator is there for the USB hub, in which nothing is plugged right now, explaining the lack of voltage in there?
      You can try tracing the input and output pins of the reg to see where they lead. It's been my experience that these voltage regs are always powered on.
      • kynax
        • Sep 2010
        • 33
        Did some more investigating.
        See attached picture.
        Point 1 has 5.27V, point 2 has 5.07V, point 3 has 0V.
        Point 3 then goes to a fuse (blue box) and to a test point.
        It then goes into a capacitor and into the input of the big regulator.
        The output of the regulator is connected to the other side of the capacitor and to the ground.
        The small box on top (with point 1, 2 and 3) is too small for me to read the text on top, but is labelled Q308 on the board.
        • alexanna
          • Mar 2010
          • 1346
          I would like to make a suggestion.
          It would be a good idea to verify you have a ground on the regulator. What voltage reading do you get with the red lead on pin 1 and the black lead on pin 3?
          • kynax
            • Sep 2010
            • 33
            Those pins are in reference to my picture above right?
            I get 5.23V between pin 1 and pin 3 (the configuration you asked for) and 5.04V between pin 2 and pin 3.
            • alexanna
              • Mar 2010
              • 1346
              #26
              I am sorry i was referencing pins on how Jetadm 123 described them, not how you labled them
              • kynax
                • Sep 2010
                • 33
                #27
                I don't get anything (0V), which doesn't suprise me since the input pin doesn't show anything when tested with the ground.
                • alexanna
                  • Mar 2010
                  • 1346
                  #28
                  You are seeing 0 volts on pins 1 and 3?
                  • kynax
                    • Sep 2010
                    • 33
                    #29
                    Correct.
                    But isn't that the same test as in post #10?
                    • alexanna
                      • Mar 2010
                      • 1346
                      #30
                      If we are talking about the same pins [the 2 outter]
                      i don't think you have a ground,Unless it's a switched on and off ground.
                      • kynax
                        • Sep 2010
                        • 33
                        #31
                        The rightmost pin is indeed connected to ground.
                        The leftmost has 1200 ohms of resistance with pin 3, but that might be through a charged capacitor somewhere else since it starts low and goes up in about 2 seconds.
                        • jetadm123
                          • 2169
                          #32
                          FYI- the "F" and "FB" designators mean two different things: The "F" designates a fuse as mentioned earlier. "FB" designates a Ferrite Bead, which is not a fuse, but a bead of ferrite over a piece of wire.
                          As for Q308, it's some type of transistor. Since you can't read the part number, I'll take a WAG and using your numbering scheme for the legs and with power off, try measuring for shorts across legs 1-3, 2-3 and 1-2.
                          • kynax
                            • Sep 2010
                            • 33
                            #33
                            1-3 427 ohms
                            2-3 infinite ohms
                            1-2 infinite ohms
                            I'm pretty sure some of these combinations charge a capacitor since 1-3 will sometimes show infinite resistance right after testing another combination. Does that make sense?
                            • jetadm123
                              • 2169
                              #34
                              I looked at your photo a little more closely. From your drawing you stated that the the output of the regulator is connected to one side of the capacitor and to ground. How can the output be connected to ground?
                              It would make more sense if the output of the reg is connected to the "+" side of the cap and the ground leg of the reg is connected to ground, but not connected to the output leg of the reg.
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • timeless
                                Dell U2518 no picture
                                by timeless
                                I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
                                There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
                                04-14-2024, 08:30 AM
                              • YellowJacket
                                Dell P2416DB - no picture
                                by YellowJacket
                                Hi friends,
                                I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
                                01-16-2024, 07:45 AM
                              • F R 2568
                                Dell Latitude 5420 does not start (no post) need help to find the reason why
                                by F R 2568
                                Hello all,
                                this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                If the laptop is only connected to the AC adapter (battery removed):
                                When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                The power/battery...
                                01-08-2025, 05:45 AM
                              • master3112
                                by master3112
                                07-29-2025, 01:55 PM
