Sceptre X240T-1920 24"
  • drewgost
    • Mar 2011
    This monitor is new in 8/2009, has been working great until yesterday when I came home to a black screen with the power button flashing (Blue).
    I tried on different computers in case of a video card problem same issue. I cant find much information on this monitor that is helpfull.
    I tried the flashlight trick and could not see anything. If I turn it off and on I can see the computer booting up but the screen goes blank in a second at most, so I keep hitting power button off and on and can see different phases of the computer starting.
    If I just unplug then plug it back in and turn on power I can see (2) slight flashes of light but never a picture.
    So any thoughts would be very appreciated.
    Thanks,
    Drew
  • alexanna
    • Mar 2010
    • 1346
    Re: Sceptre X240T-1920 24"
    Originally posted by drewgost
    Thanks,
    Drew
    I can make some suggestions
    There a lot of reasons for your monitor behaving like you describe
    Depending on how the monitor was designed, there is a possibility you may be experiencing what we call 2 seconds to black. I have worked on some Dell monitors that have had something causing the CCFLs to turn off [ Bad capacitors, CCFL or, Inverter coil bad] this occurs rather rapidly in other words faster than 2 seconds, and goes into a standby mode. I am sure there are others that behave the same way. If you're able to follow the guide that Retiredcaps has written about 2 seconds to black it probably would be a good place to start.
    Without seeing what you're working with it's going to be hard for anyone to make suggestions.
    It really makes thing easier if the pictures are not posted inline.
    • jetadm123
      • 2169
      Any chance that it's still under warranty? If not, then you'll have to take apart and post some good focused photos, top and bottom, of the entire power supply.
      • drewgost
        • Mar 2011
        Ok will do both suggestions.
        Thanks Guys
          by momaka
          03-15-2023, 10:17 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
