Acer AL2017 no power
  • porcupine
    • Mar 2011
    • 6
    Hello everyone.
    A complete novice here when it comes to the electronics side of things. I have fixed 1 LCD so far and it worked first time, all thanks to reading messages on this fourm and now I have a question to ask.
    I have received an Acer AL2017 that has no power whatsoever. The power button does nothing and no green or amber light comes on. Apparently the monitor was on and working, the screen flickered and then it was dead.
    The power board and caps look good to me, nothing blown or bulging.
    Here is a picture of the board
    Can someone make any recommendations on where to start?
    I have a very basic digital multimeter (Radio Shack Micronta - 20 years old?) but don't know how to use it other than check AA, 9V batteries - it's ok to laugh.
    Thank you,
    Mike
  • jetadm123
    • 2169
    Re: Acer AL2017 no power
    Do the basics first: with power off and monitor unplugged, set your meter to resistance, test the round black fuse directly behind the main power connector. Fuse should read no more than 0-2 ohms. If this fuse is ok, then with power on, measure the voltage across the 150uf,400V cap. If you're in the USA the voltage should be around 165 VDC.
    • mockingbird
      • Dec 2008
      • 5484
      See these two threads here:
      https://www.badcaps.net/forum/showthread.php?t=7803
      https://www.badcaps.net/forum/showthread.php?t=12014
      In the second thread, I had the same problem with nothing happening when turning the screen on, and the guy I sold it to fixed it by replacing the small starter capacitor near the main primary capacitor.
      I still have a list of all the capacitors I used to repairt it, if you want I can give you the relevant part numbers for Digikey.
      • porcupine
        • Mar 2011
        • 6
        Hi Jetadm123.
        I'm in Canada so the same voltage.
        Hmmm...... after about 30 minutes I figured out how to test the round black fuse. It measured .012 ohms.
        Can't say I'm anywhere comfortable in testing with live power, again a noob with a multimeter. However, with no power that big cap 150uf, 400v did test out with 166 ohms. Not sure if that helps or not.
        There is a glass fuse around the middle of the board(F200) and it is not blown.
        • porcupine
          • Mar 2011
          • 6
          Appreciate the 2 links and your own struggles with the same board.
          The second link will take a bit of time to digest and will see how far I make it.
          It's a bit overwhelming trying to understand all of this but I'm trying.
          Thanks again for the info
          • jetadm123
            • 2169
            Originally posted by porcupine
            Hi Jetadm123.
            The fuse looks good, but measuring the resistance across the large cap is of little use. Eventually, you'll probably be asked to make some voltage measurements. Even if you are asked to measure a low voltage, high voltage will be present at all times. Seriously, this is not the type of board to learn electronics on, especially if you're not willing to work with high voltage.
            I highly recommend watching some YouTube videos on "how to use a DMM" before going any further.
            • PlainBill
              • Feb 2009
              • 7034
              Hi Jetadm123.
              I'm a little concerned about the reading you got for the fuse. It takes an excellent ohmmeter to read below 1 ohm accurately. I wouldn't expect to see one of them sold by Radio Shack. What range did you have the ohmmeter on?
              PlainBill
              • porcupine
                • Mar 2011
                • 6
                Yup, I hear you, don't need to get killed over a 50 cent problem and that's why I was upfront about being a total novice and not comfortable in doing a live check on the board. Replacing bad cap's is another story.
                Anyone know of someone in Ontario that do a repair or if one can buy an Acer power board for the LCD?
                Cheers
                • porcupine
                  • Mar 2011
                  • 6
                  The setting was on 2, it can support 2, 20, 200 etc.
                  Appreciate the comment, think I'm in over my head here. The Rat Shack meter was free, can't complain but sounds like it's sorely outdated too.
                  Cheers
                  PlainBill
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Cheers
                    Ordinarily the lowest resistance range on a DMM is 200 ohms. That would mean your lowest resistance reading on the typical 3 1/2 digit DMM would be .1 ohms. One way to verify this is to set the meter on the lowest ohms range and short the probe tips together. It should read slightly below 1 ohm.
                    PlainBill
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      A picture of the dmm would help.
                      --- begin sig file ---
                      --- end sig file ---
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        The absence of the green power LED doesn't necessarily mean it is a power board problem. The logic board is what controls the power LED.
                        To narrow down which is at fault, you will have to make a DC voltage measurement at the connector between the power and logic board. This is usually low DC voltage like 19V DC or less. The logic board voltages are usually 5V DC or less.
