VIEWSONIC vp201b lcd screen flickering and 2/3 of screen goes blank
  • badskribs
    • Feb 2011
    • 3
    Hello!
    i'm new on this forum and i'm french man so my english is not too high like urs but i will make effort! thank you.
    My viewsonic vp201b screen starts well with good displaying and after 10mn ( when it temperature becomes rises ) 2/3 of the screen fluickers and goes blank or black ... i've posted an image of the screen.
    But i've opened it and reached to the LG Philips LCD IC and when i pressed it whith my finger ... it stops the troublshooting and screen displays correctly ... i don't understand !
    this is the link of my service manual :
    Please help me ... i need this screen for work. Thank you.
  • smason
    • 1652
    Re: VIEWSONIC vp201b lcd screen flickering and 2/3 of screen goes blank
    What exactly are you pressing on when it works? A photo would help too.
    It soulds like either a bad solder joint or a dirty connector.
    • badskribs
      • Feb 2011
      • 3
      this is the photo like you ask me ... now pressure has no effect ... i've cleaned the LCD connector and well plug it and the screen have worked correctly around 30 mn (most time of correct working) ... and the troublshouting reappears ... the components are too small to verify solder jonctions ... an idea ? please share with me.
      thanx
      • smason
        • 1652
        Hmm the chip you pressed on is pretty close to the connectors that connect to the panel, so that makes it a bit tough. Have you tried gently pressing on the black connections at the very top of your photo?
        • Ado02
          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
          by Ado02
          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
          12-16-2024, 02:33 PM
        • domu
          Viewsonic VS16217 strange problem - white flickering screen on power up
          by domu
          As per subject, on power up display shows no image, but white
          flickering screen. Strangely, it only happen after power was lost
          when it was on. After power returns - white screen only, but if
          disconnect power for 12-24 hrs, and connect then again monitor
          works normally.
          Any clues how to go about it would be greatly appreciated.
          07-18-2023, 04:57 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
        • dicky96
          HP Elitebook Screen blank - backlights but no image
          by dicky96
          Hi guys
          I'm trying to fix this laptop screen
          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
          OK so I have the original screen which works but has lines across the bottom quarter of the screen
          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
          04-28-2021, 07:30 AM
