Viewsonic VX2035wm stays on for hours
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    all caps are good, well, they're Hermei's, which is somewhat of an oxymoron I know, what I mean is they're unbloated, but I know that can mean crap too. I've seen a bunch of pictures from this model with bloated capXon's, but ran into a wall when trying to figure out the common problems with Hermei's. there just might not be many posts on the internet with this model failing with these
    anyways, here is the problem. it says on for about 3 hours, then, the pictures goes away. Though if I look close I can see this single little line randomly flash every few seconds. the lamps are still on though. OSD will not come on. maybe cap on the video board? (which errg is also hermei). Then I can turn it right off with the power button, and back on, and it comes up no problem, but then does the same thing within much less time, so this might be heat related.
    I've never ran into this problem before with a flatscreen. could it be one cap value is slightly bad/offspec and it could be just like, locking up the video signal processor? Maybe a cap on the power board is dropping power just low enough to the video board?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic VX2035wm stays on for hours
    OK, let me explain this in simple terms.
    Hermei caps are known garbage. You have Hermei caps in the power supply. You have Hermei caps on the signal (video) board. You have a problem that could be either bad caps or a failing voltage regulator. I suggest a two step process.
    1. Let the monitor run until it loses the display, then measure the output of the voltage regulators on the signal card.
    2. Replace every Hermei cap on the power supply, every Hermei cap on the signal board, and every questionable regulator on the signal board.
    PlainBill
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      yeah I know the're garbage. but why would it work for 3 hours, the one hour? that screams a heat issue. can it be normal when its cool and bad when it heats up? I've never expirenced such a thing in my...eh few years of re-capping
      the power output from the supply to the card, or the mosfet on the video board itself?
      • smason
        • 1652
        Marginal caps can get worse with heat, or a component being fed dirty power from crap caps can handle it, until it heats up, could be a lot of things.
        Recap first, ask questions later.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          now if someone only would of said that when when the BP oil rig first blew *rimshot*
          I don't have to re-cap the 10uf 16v tiny caps on the video board, do I?
          • smason
            • 1652
            I'd wait on those, they're (generally speaking) not under the same stresses that the power supply/inverter caps are.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I have some 16v 1200 rubys to replace the 16v 1000, but, I think I have a height limitation issue. ontop of the heatsinks for these two mosfets, there is a screwed in plate, i'm guessing it would be a worse heat issue if I were to take that off. probably overheat and blow the rubys
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                well, I replaced them on the video board, and all the 16v 1000's in the power board. they were slightly too tall and this single metal plate that screws into the top of the mosfet heatsinks dosen't fully screw down, and dosen't conduct much heat, which caused the two mosfet heatsinks to heat up much more, and it caused the monitor to black out only after about half an hour
                • alexanna
                  • Mar 2010
                  • 1346
                  You may have just invented a way to stress test the monitor!
                  You probably know this but The capacitors are right at the high end of 20% tolerance on the capacitors, May or may not aggravate your problem I don't know.
                  Have you tried monitoring the output voltages of the voltage regulators as PlainBill suggested?
                  I have seen voltage regulators cause some really strange problems.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    where do I put the test leads? on the regs or the output wires from the power to the video board?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      You put the black lead on a convenient ground point. You measure the voltage at each pin of each regulator. You report the voltages and the part number of each regulator. I'll explain if each voltage is good or bad, and why.
                      PlainBill
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        so I can touch the ground lead to anywhere on the chassis?
                        soo on the subject, what are the replacement specs for regulators? tolorences? requirments? I've never much messed with mosfets, though i'm hopeing to start
                        • PlainBill
                          • Feb 2009
                          • 7034
                          You can use any point that is at ground potential. I'd point out a few possibilities, but without a picture, it's rather difficult.
                          PlainBill
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            ok. I only really got a reading on the middle pin other ones were like 0.005... one time I accidently shorted the middle one one of the sides and sparked, but did not seem to effect the screen. scared the piss out of me though. one read ~13.4 other other read ~5.1. after the video goes black, its the same
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Go back and reread post #11 and then repost the results as PlainBill requests.
                              And we are still waiting for pictures (use manage attachments and please do not post inline).
                              --- begin sig file ---
                              --- end sig file ---
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                ok here we go. well, I can't find the usb cable for my phone, and my crappy old sony cam ran out of batteries, which I have no replacements for right now, so here is a picture of the board from another website. This board looks clean, and with the exception of a few cap brand differences (mine had all hermei caps, and this picture has mostly hermei). I already replaced them around those twin mosfets
                                here is mine with the voltage readings on each mosfet. the ones on the twin caps seem stable, and also the other mosfet, except for the middle pin
                                actually, when I try to test that one, something wierd happens. not only is the voltage never the same, but every time I test it, the reading on my meter (LCD screen, meter is fluke 8010m) gets really dark and bold, and goes back to normal when I take the leads off
                                oh yeah, last time I tested it when it went blank, the twin mosfets were the same. I have been unable to really test it when it goes blank is cause it has yet today to do it
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  well this just gets more and more fascinating by the second
                                  so its been just fine...I decided to change the resolution on it up to the monitors naitive (1920x1080). the second I did, and the screen did it
                                  and now the volts are really strange, on all of them
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    ok I posted a pic and the voltages, why is no one replying?
                                    • tehtronics
                                      • Mar 2013
                                      • 3
                                      • ROMANIA
                                      Same defect has my monitor ... You have found damaged component ?
                                      • tehtronics
                                        • Mar 2013
                                        • 3
                                        • ROMANIA
                                        I repaired the monitor...
                                        I found the capacitors C106, C122 and C126 (10uF/16V) with high ESR(manufactured by HERMEI) on the signal board.
                                        I replaced with RUBYCON caps and my monitor works perfectly ...
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • StefanNg
                                          Viewsonic VX2718-PC-mhd SG2701B01-8
                                          by StefanNg
                                          Hi, Badcaps.
                                          I am troubleshooting a monitor
                                          Viewsonic VX2718-PC-mhd.
                                          Panel model SG2701BSG2701-8
                                          Symptoms is no image.
                                          This panel has 2 panel board connected by a U-ribbon.
                                          When I disconnected the ribbon, I get a perfect half screen image.
                                          I took some test point voltage, when ribbon disconnected.
                                          HVAA 8.38v
                                          FVDD12 1.21v
                                          FDD33 3.3v
                                          VIN 11.79v
                                          VAA 16.85v
                                          VGHF 30.16v
                                          VGL -8.02v
                                          CK1_I ~ CK8_I 1.403v
                                          CK1_L ~ CK8_L 8.26v
                                          When I connect both panel board
                                          HVAA, VGHF, and CKx_L...
                                          05-17-2025, 01:43 AM
                                        • kd9
                                          Panasonic working hours bios location
                                          by kd9
                                          Hello, can someone tell me where the operating hours are located in the bios (string)? I have a client with a cf-20 who wants to reset them but I don't know where that information is found in the bios I we checked 2 versions of the bios but there are multiple large arrears that are changed . Thank you.
                                          04-03-2025, 09:47 PM
                                        • howardc64
                                          blue LEDs @ ~10k hours on LG 49UJ6500-UB and 75UM8070PUA
                                          by howardc64
                                          Recently fixed a couple of LGs with blue backlight (yellow phosphor worn) by replacing LED backlight
                                          2017 49UJ6500 with 10.5k hours (all LEDs turned blue)
                                          2019 75UM8070PUA with 12k hours (>75% of LEDs turned blue)
                                          So the 2019 was averaging 8hr/+day and 2017 probably 5hr+/day
                                          Just some stats for future repairs.
                                          03-23-2023, 09:45 PM
                                        • Fagauthier
                                          Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                                          by Fagauthier
                                          I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                                          Model #EADP-64BF B
                                          The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                                          07-08-2023, 08:02 PM
