Dell e173fpb - backlight
  • yofreke
    • Feb 2011
    so our dell monitor pooped out a while ago, here's what i have done on it so far. Power light was flashing. Bought a replacement kit for 6 of the thingamabobers (black plastic front, metal plate on back, three prongs, labled: Q739, Q740, Q743, Q751, Q759, Q760). Lost interest, regained interest, plugged the monitor in to see where i was, and it started spewing a good amount of smoke. Replaced every one of the thingamabobers. Now it will turn on, and after ~1 second the backlights turn off (it is still on however). Checked all of the capacitors, none of them have bulged caps. Gave it a thorough look over, no visible smoke residue or bad looking solder connections.
    Hope that this problem hasn't already been addressed somewhere else, but i didn't see mention of a problem where it had done this. Thanks for any help.
  • seanc
    • Nov 2008
    • 1319
    Re: Dell e173fpb - backlight
    Resolder all transformer legs!
    • sabre504
      • May 2010
      • 449
      As Seanc said resolder the legs on the underside of the board
      • smason
        • 1652
        Thingamabobers? Seriously?
        • yofreke
          • Feb 2011
          Alright, so just remove current solder, take them out, read to them some, put them back in? I will do it, but why?
          Shh, i'm a visual type of person.
          • sabre504
            • May 2010
            • 449
            You dont have to take them out just clear old solder and put fresh in
            these are reknowned for poor solder joints on the transformer legs
            • smason
              • 1652
              <disclaimer> I've had a couple </disclaimer>
              I'm tempted to say "because we effing told you" but I'll be nice
              In semi-non-technical terms:
              A very common failure mode on this model is that there are bad solder joints on the inverter transformers. This causes the controller to drive the transistors harder.
              Scotty: "Kiptain, the backlights are nay gettin enough pow'r, I'll tell the trannies to kick it up a wee bit"
              Kirk: "Who the eff let trannies on my ship"
              Sulu: "Oooh, did someone say trannies??",
              Anyway, the c5707s and the Fets of which I canna rememerrrr the parrrt number die (usually shorting oot) and sometimes takes out the picofuse just for grins.
              Some folks have replaced the fuse and the bad transistors, only to have the same thing happen again, because they dinna resolder the transforrrrmers.
              That's my understanding of the situation filtered through about 3 Crown Royals, and a beer or 2.
              • retiredcaps
                • Apr 2010
                • 9271
                Possible technical explanation ...
                https://www.badcaps.net/forum/showpo...&postcount=269
                --- begin sig file ---
                --- end sig file ---
                • hoadle
                  • Jul 2010
                  • 174
                  Some time is ccfl backlight is bad that cost shut off too,
                  • yofreke
                    • Feb 2011
                    So even if the connections look fine, they could actually be bad? Just re-melting the connections won't do (cheap soldering wick is the devil)?
                    EDIT: Also, which fuses will need checking? I'm too unfamiliar with LCD repair, as this is the first one i'm tackling.
                    • smason
                      • 1652
                      Originally posted by retiredcaps
                      Yeah, that's what I meant to say...
                      • killian6pk
                        • Apr 2010
                        • 502
                        That was absolutely great. Are you available for parties.
                        Have you ever stopped to think and then forget to start thinking again?
                        As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
                        • HTR-Informatique
                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                          by HTR-Informatique
                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                          I also changed the screen because the PC fell and the screen was broken.
                          I changed the battery with a new and original battery.
                          I also had corrosion/oxidation on the...
                          02-09-2025, 06:51 AM
                        • DanPoka
                          by DanPoka
                          02-15-2025, 05:05 AM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • doctormasry
                          dell 3521 la-9104p no backlight
                          by doctormasry
                          hellolaptop dell 3521 la-9104p no light on screen
                          i can see data ok but no backlight
                          on jlvds
                          NV_PWR_SRC 18 v is ok
                          3vs is ok 3.3
                          lcdvdd is ok 3.3
                          i replacd led screen
                          and change flata ( caple between board and led )
                          any idea...
                          09-11-2025, 12:14 AM
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
