I am a first time poster. I have a Viewsonic VX724 with FSP035-1PI01. The power LED is blinking green and the transformer is ticking. I measured the output pin and it is above 12 volts....actually it is fluctuating between 12.37 and 12.44. The board was doing this before I recapped it as well with the CapXon caps that I pulled off. The diodes check out, bridge rectifier and filter caps are good to go and it is producing 12 volts.
I put the board under a scope to check to see if I has a bad solder joint, but everything looks good. I am frustrated at what this could be? Any ideas?
