Viewsonic VX724 with FSP035-1PI01
  • waitery
    • Feb 2011
    • 69
    I am a first time poster. I have a Viewsonic VX724 with FSP035-1PI01. The power LED is blinking green and the transformer is ticking. I measured the output pin and it is above 12 volts....actually it is fluctuating between 12.37 and 12.44. The board was doing this before I recapped it as well with the CapXon caps that I pulled off. The diodes check out, bridge rectifier and filter caps are good to go and it is producing 12 volts.
    I put the board under a scope to check to see if I has a bad solder joint, but everything looks good. I am frustrated at what this could be? Any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic VX724 with FSP035-1PI01
    Several.
    Did you replace ALL the electrolytic caps on the power supply / inverter board?
    What brand and series of cap did you use?
    What output pin are you talking about.
    Attaching pictures would give us something to refer to when making suggestions.
    PlainBill
    • waitery
      • Feb 2011
      • 69
      Several.
      PlainBill
      Forgive me, yes I replaced the caps with a combination of Nichicon and Rubycon ZL, low esr, 105 degree caps. The pin that I am refering to is the output pin going to the main board. I believe that the issue is on the primary side, as I am getting some erratic swings in power at the cathode side of the diode at D320. Anywhere from 67-64 volts and it swings as the ticking pulses.
      The other issue is that I took off of of the red inverter capacitors at C24, as it had blown out the side and split. I am still getting 12.40 volts off the board, it just swings eratically to 12.37 then to 12.44 volts. Here is the photo:
      • alexanna
        • Mar 2010
        • 1346
        What dose the voltage do with the logic board disconnected?
        If it Stabilizes post pitcures of the logic board.
        • jetadm123
          • 2169
          The "ticking" sound is an indication the power supply is trying to start. This is a weird problem because if the supply hasn't started, then why are you getting a 12V output? Next to D320 is C320. C320 looks like the original cap (as evident by the glue on it). This startup cap and D320 are connected to a tertiary winding off the main transformer and produce the VDD required by the PWM controller chip (surface mount chip underneath board, U320). Failure of C320 can cause U320 not to start properly. If pin 7 (VDD) voltage of U320 is fluctuating, then try replacing C320. Also check value of R326 and ZD302, C322 for shorts. I'm assuming you checked D320 for shorts?
          • PlainBill
            • Feb 2009
            • 7034
            %#@%^#@T!!! One of the reasons pictures and complete information is helpful is they avoid wasting a lot of time. You have shorted transistors in the inverter. That's overloading the power supply.
            PlainBill
            • Scenic
              o.O
              • Sep 2007
              • 2642
              PlainBill
              that, and the ugly yellow glue that becomes conductive. left of the PSU transformer.. (and in several other places)
              • waitery
                • Feb 2011
                • 69
                Bill,
                Are you talking about the sm transistors under the interter? If so, how can I test or verify this?
                Jetadm123, D320 is good to go, no leakage. Also, C320 is brand new as well. I will follow your guidelines on testing further.
                One question though...how does hardened glue become conductive?
                Thanks!
                • jetadm123
                  • 2169
                  Bill,
                  Thanks!
                  I think PlainBill may be referring to Q6-Q9?, surface mount NPN transistors, 2SC4672. Each pair located opposite the CCFL controller chip. With your meter set to resistance, measure across E-B, B-C and E-C for shorts.
                  • waitery
                    • Feb 2011
                    • 69
                    I checked out those transistors and the one side where I had removed the blown red capacitor, both had had significantly lowered values. All four were tested in circuit, with the power off. Here are my figures:
                    Good Capacitor Side (please note the Kilohms measurement.
                    E-B 6.63k ohms
                    B-C 746 ohms
                    E-C 5.74k ohms
                    No Capacitor Side
                    E-B 3.7 ohms
                    B-C 2.8 ohms
                    E-C 6.2 ohms
                    Let me know what you think and thank you!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      No Capacitor Side
                      E-B 3.7 ohms
                      B-C 2.8 ohms
                      E-C 6.2 ohms
                      The above readings suggest it is shorted. Remove and retest out of circuit to verify.
                      --- begin sig file ---
                      --- end sig file ---
                      • Rtech
                        • Jul 2010
                        • 1095
                        You also need to measure and compare the secondary resistance of the two inverter transformers,as the one next to the capacitor you have removed is notorious for failing.I would also take it out of the board and you may well see burning on the underside of it.
                        • Rtech
                          • Jul 2010
                          • 1095
                          The inverter transistors referred to,ie 2SC4672,were unobtainable when I looked for some in the UK,and the alternative advised was FCX1052ATA.These are
                          Medium Powered as opposed to the Low Power of the original, rated at 75volts as opposed to 50volts.Manufactured by Zetex,these were obtained from RS Components,in batches of Qty 10,@45pence each.They are also used on VX710 and 910,and have used about 20 to date with no failures.
                          • waitery
                            • Feb 2011
                            • 69
                            Rtech, thanks, I will pull that inverter, check for burning and ohm it to see if there is a problem. Those transistors that RetiredCaps referred to can be had here stateside for 80 cents a piece...a new pair of .15uF caps @250volts tagged onto the order drives the cost up to $6.00 delivered first class mail from Diga-Key....pretty good value.
                            • lostone
                              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                              by lostone
                              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                              05-19-2024, 11:40 AM
                            • StefanNg
                              Viewsonic VX2718-PC-mhd SG2701B01-8
                              by StefanNg
                              Hi, Badcaps.
                              I am troubleshooting a monitor
                              Viewsonic VX2718-PC-mhd.
                              Panel model SG2701BSG2701-8
                              Symptoms is no image.
                              This panel has 2 panel board connected by a U-ribbon.
                              When I disconnected the ribbon, I get a perfect half screen image.
                              I took some test point voltage, when ribbon disconnected.
                              HVAA 8.38v
                              FVDD12 1.21v
                              FDD33 3.3v
                              VIN 11.79v
                              VAA 16.85v
                              VGHF 30.16v
                              VGL -8.02v
                              CK1_I ~ CK8_I 1.403v
                              CK1_L ~ CK8_L 8.26v
                              When I connect both panel board
                              HVAA, VGHF, and CKx_L...
                              05-17-2025, 01:43 AM
                            • Fagauthier
                              Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                              by Fagauthier
                              I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                              Model #EADP-64BF B
                              The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                              07-08-2023, 08:02 PM
                            • Returning Buick
                              Viewsonic G810 vertical deflection problem
                              by Returning Buick
                              I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                              04-01-2025, 07:57 PM
                            • RetroComputingGrotto
                              Viewsonic VA2010wb (High Pitch Squeal At Power On)
                              by RetroComputingGrotto
                              I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                              On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                              The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                              What component(s)...
                              02-03-2025, 06:00 AM
