Re: Viewsonic VX2250WM - LED!
If you look at the 1st post's jpg "power supply 1", C807 is the electrolytic capacitor covered in white goop above the opto-isolator to the left of the green PWM PWB. Normal voltage across this cap's leads should be ~16V. In my photo "100-1744", I removed the coil to show C504, left of the connector. Normal resistance across the cap is ~2.5 megohms. Removing L501 helps determine whether the low resistance is upstream or downstream of the coil.
