Dell 2007FPb No Power, Power and 1 icon (VGA) blinking
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell 2007FPb No Power, Power and 1 icon (VGA) blinking
    Originally posted by tboxxx
    Here (http://www.elexp.com/t_test.htm) it's said that to test "in circuit" I will need to unsolder one end.
    Thanks.
    No you don't have to unsolder anything. Measure everything as is first. If the readings are suspicious, then unsolder one leg.
    Yes, all those circled are diodes. To test a diode in circuit,
    a) put your multimeter in diode test mode
    b) put your black lead on one side and the red lead on the other - record reading
    c) reverse the leads - recording reading
    A good diode should read 0.3V to 0.7V in one direction and 0L in the other. If you get a reading in both directions, you will have to desolder one leg and retest to verify.
    Report all your measurements.
    --- begin sig file ---
    --- end sig file ---
    • tboxxx
      • Feb 2011
      • 21
      OK, here are some results about question 3.
      I used 2 multimeters: my personal Mastercraft 52-0060-2 (cheap one, from Canadian Tire for 20$ bundled) and the office one Meterman 37XR.
      Mastercraft does not show eng units during diode test and the scale is weird. Anyway, here are the results:
      Code:
      Diode | Meterman read1 | Meterman read2 | Mastecraft read1 | Mastercraft read2
      FD1/2 |   0.145V  |   1.329V  |    122    |   Overrange
      FD3/4 |   0.143V  |   1.256V  |    120    |   Overrange
      FD5/6 |   0.142V  |   1.543V  |    119    |   Overrange
      FD7/8 |   0.141V  |   0.737V*  |    122    |   1085*
      * means that with red lead to cathode it shows 1085, than I removed one lead and put it back and the next reading is 1020. Remove a lead and put it back - it shows 780..800. That's weird.
      4. 4 transistors J598 are good, no shorts between 1-2-3.
      6. 5 fuses on USB board are good (F1-F4, F19).
      Where are voltage regulators on 4. and 5.?
      Any ideas? Also, why two different meters shows different numbers?
      I will post next readings soon.
      • tboxxx
        • Feb 2011
        • 21
        4. If J033 is voltage regulator then it's OK, no short.
        5. If J023 and J032 are voltage regulators then they are good, no shorts.
        • retiredcaps
          • Apr 2010
          • 9271
          Code:
          FD7/8 could be bad. Let's note that they could be bad and leave the soldered in for now. You may have to desolder them and test them out of circuit to verify at a later point.
          • retiredcaps
            • Apr 2010
            • 9271
            The voltage regulators (in yellow) will have to be tested to see if they output the correct voltage. Even though they are not shorted (which is good), they need to output the correct voltage.
            With power on and lcd plugged in, use a ground screw for your black proble. Put your multimeter on 20V DC. Then put your red probe on each pin of the voltage regulator. Report all voltages.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              For diode testing, some multimeters use OL or "1" to indicate out of range. As long as the diode doesn't show the same reading in both directions, it is likely to be good.
              On this board, the diodes could be in "parallel" so the multimeter diode test threshold may not be enough to trigger the "0L" on the Meterman.
              I had a Meterman 15XP, but I gave it away to a relative for business use so I'm familiar with the Meterman brand. I have used an autoranging Canadian Tire multimeter.
              • tboxxx
                • Feb 2011
                • 21
                #27
                Do you mean ground screw on the metal base of the monitor (kind of AC ground, yellow-green wire) or ground of each voltage regulator?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Example of ground screw on each board circled in light blue.
                  • tboxxx
                    • Feb 2011
                    • 21
                    #29
                    I can see these screws. Should they be connected to the monitor metal base which is connected to yellow-green ground wire? In this case I cannot reach the pins of the regulators.
                    • tboxxx
                      • Feb 2011
                      • 21
                      #30
                      OK, here are the results:
                      Code:
                      Regulator |  G  |  O  |  I  |
                      J023   |  0V  | 1.79V |  3.32V |
                      J032   |  0V  | 2.49V |  3.32V |
                      J033   |  0V  | Unstable| Unstable|
                      Unstable means the voltage changes from 1V to 3.5V all the time.
                      J033 is the one on the USB board.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        J023 and J032 look correct. 1.8V and 2.5V DC are "normal" output voltages for a voltage regulator (3.3V DC is another popular one). There is something wrong with voltage coming into J033. It should be a steady reading.
                        There is a 12 pin U shaped connector that connects the logic and USB board.
                        Number them 1-12 on the USB board anyway you like. VERY CAREFULLY, measure each pin and report the voltages. Put your multimeter on 20V DC. Do not let the red probe slip as you may cause a short. Put the black on a ground screw again.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Did some more research on this.
                          Some multimeters can read diode measurements up to 2.0V before showing 0L (out of range). My 2nd hand 20+ year old Fluke 75 is one of those multimeters.
                          For the Meterman 37XR, it looks like the threshold is 3.0V DC before it displays 0L as per
                          https://cdn.badcaps-static.com/pdfs/...dcfcdea073.pdf
                          • tboxxx
                            • Feb 2011
                            • 21
                            #33
                            12 U shape contacts to Ground:
                            Code:
                            Contact Pair    |  Voltage
                            TP31        |  18.82V
                            TP32        |  -0.01V
                            TP33...TP36     |  3.32V...0.00V
                            NoName (Ground)   |  0.00V
                            TP34...TP37     |  0.03V...1.54V
                            TP33...TP38(Ground) |  0.03V...-0.01V
                            Any ideas? What is the next step?
                            Thanks.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #34
                              Those voltages look okay on the U connector.
                              I suspect J033 is bad. The possibilities are
                              1) J033 itself is bad.
                              2) The components (possibly capacitors) feeding the voltage to J033 are bad.
                              Question. What is the full part number for the J033 chip? I know it is a voltage regulator, but I don't know what the output should be to find a replacement.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                Another idea I had is to use the Meterman 37XR to read the capacitance of the capacitors on the USB board. Set the 37XR to 4000uF
                                Let's measure everything "in circuit" first (no desoldering of things). For each cap on the USB board, report the following like the example below.
                                C123 - 470uF 25V, measures 3300uF
                                C145 - 330uF 25V, measures 333uF
                                I know some of these readings will not make sense because the capacitors could be in parallel and/or series and it is best to desolder them and measure them out of circuit, but let's start with "in circuit" first.
                                For measuring uF, put your black probe to the negative lead of the cap (the stripe) and red probe to the positive lead of the cap.
                                • tboxxx
                                  • Feb 2011
                                  • 21
                                  #36
                                  J033 is 960T63
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #37
                                    J033 is 960T63
                                    The datasheet is here
                                    http://www.alldatasheet.com/datashee.../G960T63U.html
                                    It looks like a 3.3V 1A low dropout regulator.
                                    • tboxxx
                                      • Feb 2011
                                      • 21
                                      #38
                                      I tried to measure caps "in circuit" on USB board, but every time I was getting 0L on my multimeter (tried black probe to a negative lead of the caps and vice versa).
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        I reread the Meterman 37XR datasheet and it says 400uF. I thought it was 4000uF so the 0L readings make sense.
                                        • tboxxx
                                          • Feb 2011
                                          • 21
                                          #40
                                          Oh, I see. I have another multimeter at work (not Mastercraft and Meterman). Will check with that one.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                            05-29-2024, 02:01 PM
                                          • noipi
                                            DELL INSIPRON 14 No power blinking orange/white
                                            by noipi
                                            i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                                            05-06-2025, 08:08 PM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! ๐Ÿš€
                                            I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                            Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
