Should I use flux when soldering in a new cap
  • Welchs101
    • Sep 2008
    • 979
    I have a question that i have been wanting to ask for some time. If i am putting in a new cap or IC should i first use flux and then the solder?
    If so what type of flux should i buy?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Should I use flux when soldering in a new cap
    If you use rosin core solder it's not necessary to apply flux because it is inside the solder.
    A working TV? How boring!
    • smason
      • 1652
      Your solder should already have flux.For caps and standard DIP through hole ICs you shouldn't need any more.
      The only time you really need to use additional flux (in my opinion) is when doing surface mount work with really fine-pitch components.
      • Welchs101
        • Sep 2008
        • 979
        thanks
        • severach
          • Aug 2007
          • 1055
          The flux in the solder isn't able to creep into the holes so all you get is a weak surface solder which is safe for capacitors. I drag the trimmed leads through rosin paste flux to coat the holes so the solder bonds at least part way in. For solder joints like laptop jacks I want to bond all the way through and beyond I preheat the board with hot air.
          sig files are for morons
          • mastertheknife
            • Jan 2011
            • 51
            I'm not an expert at all but heres my opinion:
            The flux in the rosin core is typically very little (2.0% or less) and using own flux might make things easier and result in a better joint.
            Flux (even the little flux inside the rosin core) should be cleaned carefully, i use 70% alcohol with q-tips and an old soft tooth brush.
            Regarding trimming the leads, the leads should be trimmed before soldering, otherwise the force\movement of cutting the leads might crack the joint.
            Just my 2 cents,
            mastertheknife
            • Toasty
              • Jul 2007
              • 4171
              I do. New work or old work. The extra cleaning doesn't hurt one bit. New or old caps, or any component for that matter, can have oxidation on the leads. Flux gets what you can't see. If you see it, then clean it from the leads first.
              I use one in a needle applicator from MG Chemicals:
              http://www.circuitspecialists.com/prod.itml/icOid/9735
              I also use one from Qualitek in a jar:
              http://www.intertexelectronics.com/Q...-oz-P3306.aspx
              I think my favorite is the clear thinner one that comes with Chip Quik in the small syringe. I save it for the most special jobs as it's so damned expensive:
              http://www.chipquikinc.com/store/prod_smd291.htm
              Don't be fooled by the pictures. That's a 10cc syringe which measures D:8mm x L:70mm or 5/16" x 2-3/4". For $15!!
              Toast
              veritas odium parit
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
                Multifix 425-01 and 450-01 Rework Flux Datasheet
                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                - No Clean Formulations
                - Low residue
                - Range of activity to deal with different component solderability
                - Halide free
                - Suitable for dispensing
                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                Both products are supplied in syringes or cartridges for application by dispensing....
                10-07-2024, 06:02 AM
              • chth96
                Is it good to use chemistronic flux off es835b for flux remover?
                by chth96
                I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                11-17-2023, 07:25 AM
              • Geeker007
                Friend messed up my laptop motherboard while working on my bench
                by Geeker007
                Hi All,
                So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                I have not tried putting...
                06-16-2025, 01:40 PM
              • corrize
                Best way to solder LVDS connector for beginner (and qfn) ?
                by corrize
                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                See the test :
                https://youtu.be/bNAzC-EvqHs?t=1767
                With hot air from bellow the board, that's...
                03-09-2023, 02:57 AM
