replacing pwm driver
  • tukidid
    • Jan 2011
    • 11
    Can you replace bad ob2269(SMPS not clicking any longer and chip has about few V on pin 3 VIN although in front of it there is 310V) with sg6841 or ld7552 or some other without modifying circuit around it(except for the sw. frequency setting resistor) as the one at http://pdf1.alldatasheet.com/datashe...TC/SG6841.html
    What should one check Zfb,Zcs first?
    (real ob2269 circuit has different component values and in addition resistor divider at MOS gate and one more diode+capacitor in front of VDD)
  • ecking767
    • Oct 2009
    • 492
    Re: replacing pwm driver
    Originally posted by tukidid
    Can you replace bad ob2269(SMPS not clicking any longer and chip has about few V on pin 3 VIN although in front of it there is 310V) with sg6841?
    https://cdn.badcaps-static.com/pdfs/...2d6a23c015.pdf
    Looking at the ob2269 is look to be the same as SG6841. I will say yes as a replacement. Maybe some other members can give there opinion. I have given a link to a datasheet for OB2269 ABOVE
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • sigmeyer
      Mosfet driver trouble replacing 6005A
      by sigmeyer
      So this is not the first time i find a mosfet driver shorted. I am talking about the mains to DC conversion circuits. In this case its a TV , I found a shorted mosfet , shorted safety capacitor and the power resistor was open. I replaced all of those but later found that two of the pins in mosfet driver were shorted aswell. Now this is a big road block for me , as people are no willing to wait for a month for a specific IC to get shipped from china to repair their TV , Is there another solution to fixing this problem? I have some other mosfet drivers laying around and what are the chances of them...
      01-20-2021, 06:18 AM
    • charif
      Audio Driver for Thomson P14C4BK128
      by charif
      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
      Here are the details:
      • Model: Thomson P14C4BK128
      • Operating System: Windows 10 64-bit
      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
      Thanks in advance for your help!
      04-30-2025, 05:41 PM
    • bohaboha
      how to install gl usb2.0 uvc camera device driver on windows 10
      by bohaboha
      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
      any help?
      01-26-2025, 08:33 PM
