Hey all, I have a FP71G which is turning off about a second or so after it is brought out of standby.
Mains power to monitor > monitor standby
Push on button > power led turns green and display turns on (Benq logo displayed)
2 seconds later > monitor returns to standby.
Interestingly, there has always been a slight high pitched whine from this monitor whenever it was on standby. Not really knowing much about the internals of a computer display I ignored it. It seems that this has come back to bite me on the ass.
Pulled the thing apart and it appears that there is nothing visually out of order (solder, connections etc all look perfect). The only thing I have to go on is the sound.
Scenario 1:
Plug mains in > high pitch to slightly lower pitch (is this the sound a bad capacitor makes as it attempts to charge?)
Unplug mains > (if video driver board is attached (the one with the input ports)) the pitch goes up and down as it appears something is discharging.
(If video driver board is detached) the pitch goes up and up over a period of about 20 seconds, then all over the place for about 3 until it “dies”
Scenario 2:
Plug mains in
Push power button (whether the boards are connected to the LCD or not does not appear to matter as far as this sound is concerned, so all this testing was carried out with only the two boards and the bezel buttons connected.
Quick (less than a second) discharge sound, followed shortly by two similar sounds, then silence for a second, then back to standby noise/condition.
This can be repeated over and over with the same outcome.
The charging/discharging noise appears to be coming from capacitor C607 or somewhere very close nearby. I wouldn't suspect the resistors (they have been tested and are fine), the diode is working, but there are two small silver cylindrical components (L605 and L604) which I cannot identify. I believe it is C607, but sound can only get you so close. Who knows, it could be coming out of the side of nearby transformer(?) L602.
Please see the attached pictures of the nearby circuitry.
Any ideas? I don't have an ESR meter, so I can't test the capacitor.
jt
Scenario 1:
Scenario 2:
Plug mains in
jt
