2 LG 17"ers
  • smason
    • 1652
    2 LG 17"ers
    Just finished 2 17" LG monitors I rescued from being recycled at the office.
    # 1 LG 1752
    Has a sticky note on it that says "Dead"
    I plug it in, works fine...
    Disassemble, find Samxon GF caps, all look really good.
    I do a full re-cap minus the big one, and re-solder some questionable joints.
    All the Samxons test fine ESR-wise, a few are a bit low in uf, but within spec.
    Put it mostly back together to test, and....
    It's dead Jim! Nice, I usually try NOT to make things worse when I repair... Hmm. What did I do? solder bridge? backwards cap?
    I examine thoroughly, can't see anything obvious.
    re-test, nothing. No 5v no 12v, 160somthing on the big cap.
    re-re-examine, no long leads shorting to ground, no solder puke from my vacuum tool. I spray with flux remover, brush clean and examine under magnification.
    I questionable solder joint I missed. re-solder, test. Still dead.
    About to put it down and get a beer, when I decide to look closely at the pile of Samxon caps on my bench. Wait a sec! that little one is .47uf@50v NOT 47uf@50v. <slaps forehead> I bet it's the startup cap too.
    I don't have any .47@50s, so I measure the Samxon, and put it back in.
    Test. WHEW! Working great.
    I re-assemble and start #2
    #2 LG 1753, same as the 1752, 'cept for a black bezel, and the LED is in a different spot. Plug it in, dead.
    Disassemble, looks just like the 1752, 'cept this one has one slightly bloated Samxon.
    Re-cap all but the big one, and the .47uf
    Partial re-assemble, and works like new.
    Odd that the older higher mileage 1752 had perfect caps, and the newer had a bloated high esr 1000 @ 16....
  • alexanna
    • Mar 2010
    • 1346
    Re: 2 LG 17"ers
    That has happened to me also, the .47, and 47 can be hard to see. Sometimes they just get thrown the wrong parts compartment, Or I have received some that were packaged wrong from the supplier.
    Boy I wish I could still drink beer [to many meds]
    Al.
    • double_DD
      How can I be sure that my EC chip is dead?
      by double_DD
      As the title suggests, how can I be sure that my EC chip is really dead?
      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
      03-12-2025, 07:47 AM
    • disorder
      ps5 edm-033 dead after hdmi/usb ports destroyed
      by disorder
      hello guys,
      i need help to repair a edm-033 ps2
      history : as always hdmi port and usb ports destroyed after unplugged
      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
      so i changed it
      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
      i don't see any projection of liquid metal on pcb.
      01-14-2025, 12:48 PM
    • zunasthegreat
      Chieftec GPS-450-AA with dead 20N60C3
      by zunasthegreat
      Hello everyone hope all doing well!
      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
      09-01-2024, 07:12 PM
    • Beton
      Finding a dead short component
      by Beton
      Hi guys!
      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
      I have a bench PSU and if I try to inject voltage the voltage...
      12-10-2021, 01:05 PM
    • FiguringITout
      MSI Raider GE75 - Not posting, probable dead CPU
      by FiguringITout
      Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
      Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
      07-25-2024, 07:27 AM
