BENQ FP91G+ no longer working - Help!!!
+ More Options
Posts
  • chockimon
    • Nov 2010
    • 12
    I have a BENQ FP91G+ 19" LCD that is no longer working. The power LED flashes and goes off and I get no picture whatsoever, not even the logo. Does anyone know what the problem might be and how can I fix it.?
    I took the monitor apart and noticed at least 5 bulging caps (Marked in Red) and where I have circled in red there is a burn mark.
    How much does it cost (£) to buy replacement components and where online can I buy them in the UK. Out of curiosity does anyone know how much a new inverter board would cost? I'm no expert in electronics, so what do I need exactly to repair this monitor. I'm ok with a soldering iron though.
    Thanks! I appreciate any help you can offer.
  • gerg
    • Nov 2010
    • 278
    Re: BENQ FP91G+ no longer working - Help!!!
    what is the rating on the caps that are bad?
    • cpp
      • 9
      replace all caps on the secondary side and the big one-(100uf 400v?, line filter, on the primary) and try power on again.Sometimes , Benq boards are easy to repair.At the moment ,no need to replace the two 47 uf 50v near the power mos-fet
      the circled in red is a "optocoupler" ,normally Benq mount types 817 or pc123,if are burned ,change it,it 's cost inexpensive
      Look this:
      http://foros.zackyfiles.com/showthread.php?p=4111852
      (sorry for my english)
      • PlainBill
        • Feb 2009
        • 7034
        There are several members here from Britain. RS and Farnell are two of the suppliers I hear mentioned.
        One correction to earlier advice. Benq has a reputation for using low quality components. Unless you enjoy pulling the monitor apart, replace all of the electrolytic capacitors on the board. Ordinarily I say "with the possible exception of the large 100uF, 450 volt one", but the symptoms you describe could be caused by a (rare) failure of that capacitor. In particular, the two 47uF, 50V ones should be replaced. They are inexpensive, and if they fail you will have a non-working power supply.
        Personally, I prefer Panasonic FM or FC series caps. Other brands also have series that are good replacements.
        Note the links in my signature. They lead to information on suitable capacitors, sources for them, and also tips on attaching pictures to your post.
        PlainBill
        • chockimon
          • Nov 2010
          • 12
          HI gerg, my monitor is in the loft at the moment, so I couldn't tell you, but I'll have a look at the weekend. I've had to send my new Acer GD245HQ monitor back due to vertical banding, so I'm going to be without a monitor for a while, so I might as well try and fix my Benq.
          • chockimon
            • Nov 2010
            • 12
            HI CPP & PlainBill. Thanks for the information. I'll see if I can buy the components you mentioned at the weekend. Thanks for the really good links. They'll no doubt be very helpful. Thanks again. I'll let you know how I get on. Hopefully I should be able to fix it now.
            • retiredcaps
              • Apr 2010
              • 9271
              You *must* resolder all the inverter transformer pins. Benq boards have weak or poor solder joints on the inverter transformer pins.
              They are also known to have possibly bad picofuses, c5707s, and fu9024s.
              --- begin sig file ---
              --- end sig file ---
              • wanyf
                • Nov 2010
                • 4
                I have the same issues, after reading badcaps forum, i replaced all secondary caps, four C5707, two FU9024N, and a 3A 125V pico fuse and it works.
                After 2 days of running, covered about 24hrs, it goes off again.
                I wonder i miss out some components? please help.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Read post #7. Did you do resolder the transformers?
                  PlainBill
                  • chockimon
                    • Nov 2010
                    • 12
                    Well I've resoldered all the inverter transformer pins like you said and it's still not working. So it's definitely probably something else. The following caps are bulging, so probably need new ones.
                    C712 608C2 (TK)P105, 1000uF/10V
                    C707, C708 (C)0551 ELM 105c,1000Uf/16V
                    C704 (C)547,470uF/35V
                    Being a layman, all these numbers are confusing. I'll need to order the same capcitors from somewhere. Any idea how much 4 or 5 capacitors will cost?
                    What's the pico fuse?
                    On mine there is what looks like a fuse beside the power socket, could this be blown?
                    • seanc
                      • Nov 2008
                      • 1319
                      So you need:
                      1 x 1000uf 10v capacitor
                      2 x 1000uf 16v capacitors
                      1 x 470uf 35v capacitor
                      You'd be wise to change out all of the capacitors, if some have failed, the rest will.
                      I'd recommend Panasonic FM capacitors, you can get them from RS Components - their shipping prices are the most reasonable I've found.
                      The pico fuse is a small axial fuse that looks a bit like a diode. It will be marked PFXXX.
                      Check it for continuity, it should read 0.3 ohms.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        You need to resolder all the inverter transformer pins *in addition* to replacing the capacitors. If your caps are bulging, there is NO WAY the LCD will work.
                        Benq boards sometimes have multiple failures on the same board. It can have bad caps, open picofuse, bad soldering, and shorted transistors.
                        If you are in the USA, you can buy the caps here at badcaps.net or follow PlainBill's instructions at
                        https://www.badcaps.net/forum/showpo...33&postcount=2
                        On the board, it is marked PFxy. Your pic is too blurry to tell, I'm guessing it is in the top right hand corner just left of the heat sink.
                        A good fuse measures less than 1.0 ohms on your multimeter.
                        • Steveo41
                          • Jul 2012
                          • England
                          Just joined to say thankyou. One of my 3 FP91G+ had this exact fault and because its part of a 3 screen wide setup I was feeling pretty gutted because I need matching screens.
                          Thanks to you guys and a few new capacitors later, its back up and running. I can't thank you enough for providing such valuable information.
                          Best wishes
                          Steve
                          • MMH3
                            Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                            by MMH3
                            i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                            Never ever i experienced problems with that.
                            Now i have one 5050sff machine, where this jumper isnt working at all.
                            I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                            The history of the machine is that i used it in my office...
                            03-23-2025, 09:28 PM
                          • DynaxSC
                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                            by DynaxSC
                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                            03-10-2025, 12:27 PM
                          • obelix24
                            Macbook Air 2020 (a2179) - touch id not working
                            by obelix24
                            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                            02-09-2025, 12:57 PM
                          • hopkok
                            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                            by hopkok
                            Hi masters, I need your help.
                            I am working on Lenovo Legion 16ITHg6
                            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                            Power LED is not working as well, power button working well.
                            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                            Motherboard...
                            05-04-2025, 09:35 AM
                          • bociub
                            laptop freezes, usb 2.0 not working, usb 3.0 working
                            by bociub
                            Hi there,
                            It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                            Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                            08-25-2024, 03:44 PM
