First of all, apologies if I am opening another very long thread on this monitor.
I have read through the thread of the same model by Capblown, which is having about 100 posts and I do not want to further add confusion to that wonderful & informative thread there. Besides, the failure I am encountering is not the same and there are some design differences of my power board (labeled as Rev3) as compared to the Rev2 & Rev3 there.
With me right now is another LCD monitor of the same model HP w20, which I am having problem troubleshooting and do not have the schematics. I am not the original owner of the monitor & when I open it up there are signs of it being meddled around with. I will elaborate this further.
Symptom/Problem
When it first arrived, the monitor works fine with signal connected. Power led on, Backlight on with a touch of the on/off switch. After around 40-50 min or when it goes to standby, it will automatically shut down. No Power led on. Once it shutdown, I cannot turn-it on even after pressing the on/off switch many times. I will need to unplug it for a XX minutes (the timing gets longer as you do it again and again) & once re-plug it will then be able to works fine as normal. If I press the on/off switch to turn it off manually, it will behave the same way as above also (i.e cannot turn on & No power led light up). If I disconnect it from the pc (i.e Without any video signal), the ‘check video signal' box will appear BUT not moving. It will stay there until it goes to sleep mode & it will automatically shut down as above. Hope I am clear in my description
What's been done :
1) Opened up the monitor and saw that the Power board, to me have been tempered with because I observed,
1.1) some screws were missing or over thread
1.2) 2 caps (470uf 25v) were ‘loose' from the glue (I believe someone have solder/re-solder them
1.3) and most crucially, there are ‘globs' of solders on the ends of smd resistors R127 and R129 and it seems to me they are unsoldered/re-soldered upon, and they are now slanted. Ok the thing is, if I follow correctly the thread by Capblown, Rev3 (same as my board) should be using smd resistor labeled 515 instead of 335 which is now soldered on this board. 335 smd resistor is used on the Rev2 version of the board.
2) With power unplugged
2.1) Replaced the electrolytic caps (except the Big cap & Rubycons ZLH 1000uf x4 & 1500uf x2 all 25v)
- 470uf 25v x2pcs with Panasonic FM,
- 47uf 50v x2pcs and 10uf 50v with Nichicon (PS) because that is what I have at hand for now.
2.2) Measured the fuse (F101) for open but it is reading 0.03 ohms
2.3) Measured for short at the 4-pin bridge rectifier (BD101) but NO shorted between them.
2.4) Measured short at D110 & D111 on both pins 1 & 3 but there are devices L106 & L107 in-between them respectively. So I guess they are fine.
3) With power plugged
3.1) Measured across the big 150uF 400V caps = 327V DC at both ‘On' or ‘Shutdown' stage.
3.2) Measured on the input to the logic card -
During ‘On'
Red(2 wires) = 13.19V
Black(2 wires) = 0V
Blue(3 wires) = 5.28V
Black(2 wires) = 0V
Brown = 1.7V
Yellow = 1.97V
Black =0.02V
During ‘Shutdown'
Red(2 wires) = 0.18V (& keep decreasing)
Black(2 wires) = 0V
Blue(3 wires) = 0.25V
Black(2 wires) = 0V
Brown = 0.09V
Yellow = 0.23V
Black =0V
3.3) Measured on the pins of IC OZ9939GN
During ‘On'
Pin 2 (VDD) = 4.74V
Pin 5 (ISEN) = 0.8V
Pin 6 (VSEN) = 0.8V
Pin 7 (OVPT) = 2.97V
Pin 10 (ENA) (ON/OFF) = 4.69V
During ‘Shutdown'
Pin 2 (VDD) = 0V
Pin 5 (ISEN) = 0V
Pin 6 (VSEN) = 0V
Pin 7 (OVPT) = 0V
Pin 10 (ENA) (ON/OFF) = 0V
3.4) Measured on the pins of Topswitch CMOS chip (TOP247YN)
During ‘On'
Pin 1 (Control) =5.36V
Pin 2 (Line sense) = 0V
Pin 3 (External current limit) =1.28V
Pin 4 (Source) = 0V (Seems to be tied to Pin 2)
Pin 5 (Frequency) =5.36V (Seems to be tied to Pin 1)
Pin 7 (Drain) = 'out of range'!!. (while putting my probe on this I got a small spark & the backlight went off. I quickly remove it. However, doing this the 2nd time KILLED my DMM)
During ‘Shutdown' (this was done before my DMM went BUST)
Pin 1 (Control) =0.76V
Pin 3 (External current limit) =0.26V
Pin 5 (Frequency) =0.76V (Seems to be tied to Pin 1)
Pin 7 (Drain) = 325V
4) Some differences that I noticed between my board & Rev3 from other thread
a) as per 1.3, R127 and R129 should be using smd resistor labeled 515 instead of 335 (Rev2)
b) R143 mine is labeled 2203 (Rev2) but the Rev3 in the thread looks to me to be labeled as 1203 or 1303
c) Q23 is mounted (Rev2) unlike Rev3. However on this board Z9 is labeled 104 same with Rev3 while Rev2 is labeled 684.. hhhmmm,,
5) Casualties (non-living things)
x) A dead DMM after measuring the Drain of the Topswitch CMOS chip (TOP247YN).
xx) A blown fuse after I stupidly shorted the BIG cap with POWER PLUGGED!! No magic smoke, just ‘live' fireworks. heh!..
Questions
Since there are no 13V or 5V to the logic card during shutdown, am I right to say that the faulty lies on the Power board?
If yes, could it be that the problem is caused by the 2 smd resistors (labeled 335), which it seems to be re-soldered upon, and can I replaced them with axial resistors in series matching them up to 5.1M ohms each?
Any other tests/measurements do I need to take to verify the source of the problem?
I can't thank you guys enough for all the support/advise/instructions you all have given me so far..
Now I need to get my DMM replaced. Sigh!..
Symptom/Problem
What's been done :
During ‘On'
Black(2 wires) = 0V
Black(2 wires) = 0V
Brown = 1.7V
Yellow = 1.97V
Black =0.02V
During ‘Shutdown'
Black(2 wires) = 0V
Black(2 wires) = 0V
Brown = 0.09V
Yellow = 0.23V
Black =0V
During ‘On'
Pin 2 (VDD) = 4.74V
Pin 5 (ISEN) = 0.8V
Pin 6 (VSEN) = 0.8V
During ‘Shutdown'
Pin 2 (VDD) = 0V
Pin 5 (ISEN) = 0V
Pin 6 (VSEN) = 0V
Pin 7 (OVPT) = 0V
During ‘On'
Questions
.. Luckily my new DMM has a max of 1000V..
