2 sec to off, 22" LG Flatron, W2252QT
  • ipman
    • Jul 2011
    • 159
    Re: 2 sec to off, 22" LG Flatron, W2252QT
    No, but you can trace the circuit and identify which one goes to which voltage easily.
    Usually the higher voltage caps are feeding the invertor, and the smaller ones the logic board.
    You can be sure that you can find another caps afther the filtering caps on the rail to the logic board.
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by 901THECAT
      I finally figured it out
      the ones circled are the ones I need to replace
      Two of them are 1000uf 16 volt and the other 2 are 47OUF 35 VOLT
      Is there anyway to know which go where by the numbers on the board?
      No. But by following the traces on the back of the board it is easy!!
      PlainBill
      • 901THECAT
        • Oct 2011
        • 7
        PlainBill
        i am not quite sure what you mean
        On the back of the board is the 8 holes for the 4 caps I removed
        I don't know what to look for
        Is there anyway to find a schematic of this lg w2252qt power supply board?
        Would there be any numbers on the original caps that show where they might have been positioned on the board
        I should have never took them off until I had the new ones to replace them or I should have took a picture
        This is my first time working with replacing caps
        I have a pic of the back of the board but I can't get that manage attachments screen to come up again
        It worked once
        I don't know anywhere else to post my questions but this thread because it deals with the same product I am trying to fix and everyone has been really helpful
        • PlainBill
          • Feb 2009
          • 7034
          It worked once
          I understand; tracing paths is difficult if you don't know what to look for. That's not unusual.
          Do this: After you read this post, click on the 'Quote' button in the lower right corner. Enter some meaningful text if you wish. Now scroll down below the text entry area and click on 'Manage Attachments'.
          PlainBill
          • 901THECAT
            • Oct 2011
            • 7
            PlainBill
            can I email you the pictures? I can't get the 'manage attachments' to come up
            • PlainBill
              • Feb 2009
              • 7034
              You could, but I can't contact you via PM. Check your settings on this forum.
              PlainBill
              • 901THECAT
                • Oct 2011
                • 7
                #27
                PlainBill
                I set up that vcard thing I think you can send me pm's mow if I did it right
                • Erick021972
                  • Nov 2011
                  • 6
                  #28
                  Hi
                  Could anyone help with my Lg Flatron W2252TQT. Could anyone provide me a closed up picture of Front Panel board of the said model because i misplace this board also the top view of every board inside the Unit. Hoping someone will provide me one
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Originally posted by Erick021972
                    Hi
                    You aren't going to get much help if you double post.
                    PlainBill
                    • Erick021972
                      • Nov 2011
                      • 6
                      #30
                      Ok sorry about that. I'm trying to look for picture of a control board and power "ON" board of a LG Flatron W2252TQT. Can anyone of you guys help me my control board and Power "ON" board are missing and I'm trying to find a way to buy or make a design by myself. All i need is a design how to make and wire it.
                      Erick
                      • narf
                        Epson EB-U42 projector / Caps with 0.7 ohms ?!
                        by narf
                        hi all,
                        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                        what i've found so far:
                        - the PSU does its job and supplies 12V to the mainboard via the connector.
                        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                        - not far away, there's the first cap with a resistance of 0.7 ohms....
                        07-02-2024, 03:53 PM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • dennis_elx33
                        3PHASE STEP-DOWN Transformer in Check
                        by dennis_elx33
                        Hello All,
                        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                        Problem statement: Power tripped Off
                        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                        Action Done:
                        1) Replaced the faulty parts with good spare.
                        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                        12-02-2024, 06:52 AM
                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 04:40 PM
