Need help with my 900G
  • oldmanjohnson
    • Oct 2010
    • 27
    I am having the same headache, many of you have had, with this monitor that was given to me about a year ago. When I first received the monitor it was DOA. So I opened it up and found several bad caps and replaced them. Put it back together and viola I had a beautiful 19 LCD monitor.
    Then after about a year of enjoyment it starts taking longer and longer amounts of time to exit out of sleep mode until eventually it wouldn't even display a power light. So for about 3 weeks now I have been hunting for info online, using my old CRT standby, and stumbled onto this site.
    Lots of great info thank you.
    I read the post about the 25x47 cap and changed it to a 25x100 and I am now getting a power light. The only problem is that it takes about 2 minutes after plugging it in for the light to come on. During that 2 minutes I can hear what sounds like the lamps quietly filling up with water. Then they go quiet as though they are full. Shortly after they go quiet the power light comes on but no lamp light.
    Just a little more history before I lost the power light, during the time it was slow coming out of sleep mode it didn't flicker at all and when it did power back on it was a bright and clear screen.
    Does anybody have any idea what I am dealing with. I'm just an electronics hobbyist and flying by the seat of my pants getting a lot of rug burn. LOLL
  • Wrog
    • Oct 2009
    • 472
    Re: Need help with my 900G
    Can't help with the rug burn, but let's see what we can do about the monitor! Post some pics of each board (top/bottom). Other information that will be helpful are the make of this monitor (Gateway?), along with which caps you've replaced and with what (brand/series). Do you have test equipment to help troubleshoot?
    • retiredcaps
      • Apr 2010
      • 9271
      If you only replaced the obviously bad ones, then original ones that were left could be crapping out due to high ESR (ohms) or out of spec capacitance.
      What brand did you use for the replacements?
      PS. Keep your posts to one thread only. Asking the same question under multiple threads is confusing to keep track off.
      Last edited by retiredcaps; 10-24-2010, 08:09 PM. Reason: edit: One thread only please
      --- begin sig file ---
      --- end sig file ---
      • oldmanjohnson
        • Oct 2010
        • 27
        It's a Gateway 900G.
        I replaced all but the 25x47 and then the 25x47 with a 25x100 today.
        2 have an M inside a square.(25x220 and 25x470)
        2 are Marcon (25x220)
        2 are CZ (25x470)
        1 is a YEC (35x470)
        2 are SAMXON (25x470 and 25x220)
        1 is an A inside a rectangle (25x100)
        Yes I have some test equipment.
        • Wrog
          • Oct 2009
          • 472
          M inside a square is a Panasonic ("M" for Matsushita, the old parent company), but a series would be helpful as well (FC or FM are commonly used in SMPS as recommended here at badcaps). The others are lesser known (outside of the Samxon of course), but without the series we won't be able to tell if they are appropriate. Once we get past identifying the caps I'm sure someone will ask for specific measurements.
          • retiredcaps
            • Apr 2010
            • 9271
            Some comments in no particular order.
            1) In the lower left hand corner, the connectors look like they are marked with GND, and voltages. I can't make out the voltages, but I'm guessing they are the standard 5V DC, ON/OFF, and possibly 12V DC.
            With a multimeter, list, measure, report, and verify that all the voltages matches the legend on the connectors.
            One of these voltages could be out of specification.
            2) It is possible that your replacement caps 1 year ago are bad even though they show no visible distress. They can have high ESR (ohms). If I understand it correctly, when the caps warm up, the ESR drops and the monitor starts working.
            The only way to test the ESR of a cap is to use an ESR meter. These are expensive, $65+, so for the hobbyist, it is cheaper to replace the caps with low ESR caps like Panasonic FM, FC or Rubycon MCZ.
            I don't recognize many of your replacement caps and have no idea if they are low ESR caps.
            3) PCBONEZ in post #7 at
            https://www.badcaps.net/forum/showthread.php?t=11656
            goes in great detail explaining ESR, uF, ripple, etc and how each affects the circuit.
            • oldmanjohnson
              • Oct 2010
              • 27
              Okay I changed the caps that I changed a year ago and something good happened. I lost the slow power on light problem I had and now I get an instant power light on and off.
              I checked the power and I'm getting a steady 12v and a steady 4.92 on the 5v line.
              I am not getting any screen though. I let it run with the power light on for about 1/2 hour and nothing.
              Regarding the series of the caps I'm not sure what you mean by that. They are all 105 degree caps if that helps. With the exception of the one 35x470 that one is an 85 degree.
              Lastly I do apologize for posting my question twice yesterday. I wasn't sure where to start a new post and thought my reply to the one at the very end would take a long time to get a response.
              • retiredcaps
                • Apr 2010
                • 9271
                What did you use for replacement caps?
                If you shine a flashlight on the LCD, can you see a display?
                Honda makes an Accord. However, there are many Accord models. It could be E, EX, SX, etc.
                Panasonic makes capacitors. They have a FM series. They have a FC series. Each series has a datasheet that lists ripple, ESR, temp, etc ratings.
                Each series is meant for different applications.
                • oldmanjohnson
                  • Oct 2010
                  • 27
                  The caps are Panasonic and the series are FC.
                  If I shine a flashlight on the screen I can't see anything.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Okay, those are good quality caps.
                    Last edited by retiredcaps; 10-25-2010, 05:58 PM. Reason: edit: Post #11 makes more sense than what I wrote.
                    • Solder Boy
                      • Nov 2006
                      • 178
                      If you can't see an image.. check all connections to make sure everything is snug.. especially the connector at the back of the LCD panel. Also check connnections at the logic board ( this is where the VGA cable is attached to)
                      After doing that and you still have no image.. well could be one of 3 things.
                      Something has gone wrong with the circuit board that is attached to the LCD panel or you could have bad capacitors on the logic board. Also the video processing chip on the logic board may have said goodnight.
                      Caps are easy to fix.. bad logic chips pretty well mean a death sentence.
                      If that is the case.. try not to fret about it.. sooner or later this happens to all of us repairing LCD's.
                      www.bcrelectronics.ca
                      • jetadm123
                        • 2169
                        Welcome to the forum! The 12V normally supplies the inverter assembly and the 5V supplies the the logic/video card and LCD panel. Since you're getting no backlighting or image, it can be caused by several possible problems:
                        1) At the 5V and 12V outputs, check to see if there are any blown fuses on the top of the board, or surface mount fuses on the bottom of of the power board.
                        2) Possible short of mosfets used to generate the sine wave used by the inverter transformer(s).
                        3) Bad inverter transformer or CCFL controller chip.
                        4) Bad voltage regulator on logic board. It looks like you have 2 regulators on your logic card. I believe they are the two square 3-legged devices above the two black caps at the top of the board.
                        5) Also check for fuses on the logic card.
                        6) With power off, reseat connectors between power and logic boards.
                        • oldmanjohnson
                          • Oct 2010
                          • 27
                          Thank you for your response I do appreciate all the input.
                          Would it be possible for you to send me pics of where these items are located since my electronic knowledge is limited?
                          You could use the pics I posted and just put arrows on them and post them back for not just me but for all those with the same limited knowledge.
                          Thanks in advance.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Voltage regulators are black, with 3 legs...
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Thanks in advance.
                              Here you are. There appear to be only two of them I've circled them in yellow. I've also circled two of the mounting holes in black. Use the metal around them for the ground lead.
                              Standard orientation on these is with the large mounting tab up, the three legs down, and the legs numbered from left to right (the tab at the top is usually connected to the 2 (middle) leg). Also, indicate the complete part number of the regulators. The voltage is usually included in the part number.
                              PlainBill
                              • oldmanjohnson
                                • Oct 2010
                                • 27
                                Not sure where to find these items.
                                Could you send me the board identifier numbers and I will track them down.
                                • jetadm123
                                  • 2169
                                  red circle-mosfets
                                  yellow circle-ccfl controller
                                  • oldmanjohnson
                                    • Oct 2010
                                    • 27
                                    Thank you for that good info.
                                    Okay this is the most recent thing I've done, several weeks back, before I found this site, I ordered a replacement main board. I put it in and the monitor was doing the same thing. So I took it back out and put it on the shelf. Then after Solder Boy mentioned it could be a bad main board, and after I did all the things you all told me, I put it back in. It did something new because now when I plug in the monitor I still get an instant power light. Can turn it off and on at will. But now when I turn it on I get a green light for about 20 seconds and then it switches to a yellow light. But still no screen.
                                    Since I don't know how to test the mosfets and ccfl chips should I just order them? If so can I get them from Digikey and do you have a part number recommendation?
                                    Thanks in advance.
                                    • oldmanjohnson
                                      • Oct 2010
                                      • 27
                                      Okay I have more new activity.
                                      I decided to hook the monitor up to my computer since it was acting more like it used to with the power light.
                                      When I connect it to my PC and turn it on the light stays blue, sorry not green, and when I put a flashlight next to the screen I can see a rectangular screen saver running with some test on it that I can't read.
                                      What is this telling me.
                                      I'm so close to getting this thing running I'm about to wet myself. LOL
                                      • Wrog
                                        • Oct 2009
                                        • 472
                                        Were you ever able to identify any fuses on the logic card as jetadm123 suggested? I can't definitively see any, but check the two circled ones in the attached photo (the reference designators should begin with F.. the one on the right is either FB11 or F811).
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:18 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:33 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • paparazzo79
                                          what's faulty monitor,cable,or graphics card on wake from sleep?
                                          by paparazzo79
                                          Hi friends.
                                          I was having this issue since I purchased the monitor,but then again it maybe works like that.
                                          Back at that time I didn't want to RMA the monitor due to covid and waiting toooo long for return.
                                          So the monitor CJG50 32 " from Samsung has 3 inputs (DP+2HDMI).
                                          I have 3 PCs hooked up to all 3 ports.
                                          But only over displayport input monitor wakes up from standby and I do get picture.
                                          Over both HDMI I had to manually select the source over monitor settings (OSD settings built into monitor).
                                          Input source was selected to automatic by default in...
                                          09-03-2021, 10:29 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
