HP 1905 No power. No led. No output voltage.
+ More Options
Posts
  • jetadm123
    • 2169
    Re: HP 1905 No power. No led. No output voltage.
    Originally posted by newbie1
    jetadm123, thanks for the inputs.. just a quick updates below,..
    p/s- i may not have all the answers to all the questions above.. but i will try my best to answer them..
    1) Glad to know & hope so it lasts, because that is my last IC.. i am not sure whether i busted the one i replaced earlier while soldering it.
    2a) Currently i have not have the chance to assembled them back as i want to prioritize the taking of the logic card photo. But as far as i can recall, i can see no image.
    2b) I tried scanning with my untrained eye but could see none also.
    2c) Pins 5, 6, 7 & 8 of Q701 are all shorted (0.08ohms) to each other. Same goes with Q705. But i guess they should be shorted, because from schematic they are tied to the common Pins 1, 3 & 5 of PT701. Same goes with PT702. Right?
    2d) Photos as attached. Note on the bottom side there is some stain which is flux.
    Ok, i hope u can confirm this.
    U301 (AIC1084-18cm)
    Pin 1-2 = 81.3 ohms, the rest of the pins are not shorted (brief flash of reading then open)
    U302 (AIC1084-33cm)
    Pin 1-2 = 4.5 ohms, the rest of the pins are not shorted (brief flash of reading then open)
    so are they shorted?. fyi, i continue measuring resistance across the electrolytic caps & all of them (except C401) are having the reading of either 81.3ohms or 4.5ohms. I tried removing one of them (C309) (that's where the flux came from) & measure on the pad. It shows the same with the caps off as well. Anyway i replace it since i have a spare. Not sure what's the logic or whether it is significant?
    2e) same answer as 2a. AFAIK none.
    3) geez!.. my bad. Probably i hook to the wrong Gnd, i guess.
    PlainBill, true. When i disassembled it i need to remove the panel switch/pcb board. But upon testing i need to fix back because the on-off switch is located over there.. I hope i am understanding what you mean & answering it correctly.. Talking about multitasking.. I am now watching a cooking program with the other half while typing this, lol.. ok, off for my showers now..
    To test the mosfets Q701 and Q705 for shorts:
    With your DMM set to resistance and referring to the schematic :
    On Q701, place one probe on S1 and the other probe on G1, record measurement, reverse probes, record measurement.
    Testing should look like this:
    S1-G1
    D1-G1
    S1-D1
    S2-G2
    D2-G2
    S2-D2
    Perform same test on Q705
    To test regulators you must reassemble everything.
    Looking at the regulator with the metal tab on top and numbering the pins from left to right as 1-3:
    pin1 = ground
    pin2 = Vout
    pin3 = Vin
    Power up system and measure output voltage for each regulator.
    • newbie1
      • Apr 2010
      • 269
      S1-G1
      D1-G1
      S1-D1
      S2-G2
      D2-G2
      S2-D2
      pin1 = ground
      pin2 = Vout
      pin3 = Vin
      With DMM set to 2000, here are the measurements:
      On Q701,
      S1-G1 No reading (same with reverse probing)
      D1-G1 No reading (same with reverse probing)
      S1-D1 Rising value until it goes to no reading (same with reverse probing)
      S2-G2 No reading (same with reverse probing)
      D2-G2 No reading (same with reverse probing)
      S2-D2 Rising value until it goes to no reading (same with reverse probing)
      The result is the same with Q705.
      I reassembled the monitor except connecting the panel signal cable & measure the output voltage of the 2 regulators. here are the measurements :
      U301 is 1.8V and U302 is 3.3V
      I manage to also detect that 3.3V is also present on the on/off switch. But still no Power Led lighting up even if i depressed the on/off switch & of course still no backlight . So anybody have any suggestion where do i go on from here?.
      • PlainBill
        • Feb 2009
        • 7034
        On Q701,
        What is the part number for U202 (right side, just above the crystal)?
        PlainBill
        • newbie1
          • Apr 2010
          • 269
          PlainBill
          Marking on it is = AL W H..
          I do not know whether this will be helpful but I measured resistance on it.
          With the marking upright facing me, Pin 1 is on the left, Pin 2 on the top & Pin 3 is on the right.
          DMM set to 20k ohms
          Pin 1-2 = 9.73k ohms; reversing the probe > 9.92k ohms
          Pin 2-3 = 16.51k ohms; reversing the probe > 16.63k ohms
          Pin 1-3 = 6.71k ohms; reversing the probe > 6.73k ohms
          • jetadm123
            • 2169
            Good catch PlainBill. I took a quick look at the schematic and U202 looks to be a reset controller. Unfortunately, no part number is listed.
            Newbie1, for your info, this could be the source of your problem. Please read the thread below starting at post #18. It affects some Viewsonic and Acer models, but it looks like it also affects you.
            https://www.badcaps.net/forum/showth...set+controller
            • newbie1
              • Apr 2010
              • 269
              #26
              Wow! thanks guys.. will follow the steps of post#20 to test the reset controller U202.. will update again once completed.. hope it will be soon, else you know where i will be heading.. *GULP!*..
              • newbie1
                • Apr 2010
                • 269
                #27
                Ok. Nothing got burnt.. lol!..
                However, all i get while shorting the 2 bottom pins was a brief flash of blue Power led lighting up.. I did pressed the on/off switch a few times while shorting the pins but the Power led never stay lighting up.. so i unplugged the monitor..
                One thing i notices after doing this, was if i were to plug the monitor again & switch ON the MAIN plug, there is a brief flash of blue Power led lighting up just like shorting the reset controller even without pressing the on/off switch. Can't remember seeing it previously.. Hope my explanation is clear to you guys..
                So is the reset controller faulty?.
                I am worried if it is.. Looking at the cramped spaces on the logic card, I am not having great confidence unsoldering/soldering it especially without the assistance of CHIP-QUIK.
                p/s: just to add, i did this with the panel facing down, hence i could not confirm whether there is a flash of light on the backlight as well.
                • jetadm123
                  • 2169
                  #28
                  Actually, I should have more specific. I wanted you to read what was on the link to familiarize yourself with what I was talking about. Since we haven't been verify it's the same chip, it would have been bad if the bottom two legs were ground and vcc when you shorted them. Whew! If your chip is similar to the MAX810, then the top leg (by itself) should be Vcc and should measure 3.3V. Bottom left leg should be Ground and right leg should be Reset. Try measuring for Vcc.
                  PlainBill, at this point do you think he should:
                  1) just replace U202?
                  2) try lifting the reset leg off it's solder pad and leave it floating and see what happens?
                  • jetadm123
                    • 2169
                    #29
                    I downloaded the spec sheet for the MAX810. If you look on page 5, it looks like the "AL" stamped on your chip corresponds to a MAX810R with a 2.63V threshold voltage.
                    • newbie1
                      • Apr 2010
                      • 269
                      #30
                      .. I measured the voltages on the legs
                      Bottom left = 0V
                      Top = 4.94V
                      Bottom right = 3.97V
                      whoa! I thought removing the U202 would be a tough-dog but option 2 would be suicidal if i am not careful.. lol!. Ok then, i will wait for what you guys think is a better option. And thanks for providing the datasheet.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        MAX801R has a totem pole output with an active high reset function. In other terms, when the system is powered up, the output stays at Vcc until 140 msec after Vcc rises above 2.63V. At that time it should drop to 0 volts. Therefor the reset controller is bad.
                        The problem now is I have no idea if the GM5321 has an internal reset controller or not. If it does, the monitor could be repaired by removing U202. If it doesn't, and the RESET input has an internal pull-up the monitor won't work, but nothing will be damaged. If there is no pull-up (or pull-down), the GM5321 could fry. So the best choice is to replace the reset controller.
                        • bonney
                          • Oct 2008
                          • 74
                          #32
                          pin 178 is the reset goes to U202
                          • jetadm123
                            • 2169
                            #33
                            Since replacing U202 seems to be the option, you can use ChipQuik, or if you have a fine sharp pair of diagonal wire cutters, you can cut through each leg of U202 and remove the chip. Then, with your soldering iron and a pair of pliers or tweezers remove each leg.
                            • newbie1
                              • Apr 2010
                              • 269
                              #34
                              PlainBill, thanks again for the explanation & guidance. I will try to source & replace MAX810R. However, if i cannot find MAX810R locally, may i know is it workable to be replaced by MAX810S (Reset Threshold=2.93V)?
                              jetadm123, thanks for the tip. As i mentioned before, i do not have ChipQuik. So i will try to follow ur method of cutting the legs first. Hope i will not damage the traces/pads as i did previously while removing the IC..
                              bonney, noted. However, would not take the risk of lifting up the fine legs as of now.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Yes, the IC senses the 5V supply, so there should be no problem.
                                PlainBill
                                • newbie1
                                  • Apr 2010
                                  • 269
                                  #36
                                  I could not find MAX810R or equivalent locally. So i am ordering them through ebay which will take about 10-20 days to arrive. I will update again once i have replaced U202, which was successfully removed as suggested on post #33.
                                  • jetadm123
                                    • 2169
                                    #37
                                    Funny, but I would have thought you would have had a lot of electronic parts to choose from because of the large amount of electronics manufacturing that goes on in that part of the world.
                                    • newbie1
                                      • Apr 2010
                                      • 269
                                      #38
                                      Sigh!.. Sad but true.. or maybe i have not search extensively enough,,
                                      From what i know, those manufacturing lots do not go to the retail outlets here.. they are mainly sent to Assembly houses.. the best way i can get my hand on them quickly (within a week) are mainly through Farnell, RS components.. If not, then the next best way would be ebay, which would take painstakingly slow (10-20 days)...
                                      So, you can imagine the mess i make in my small apartment here.. Littered with half-assembled LCDs everywhere, awaiting for parts... LOL!!..
                                      • newbie1
                                        • Apr 2010
                                        • 269
                                        #39
                                        BAD news!. Replaced U202 with MAX810REUR ALAA. STILL DEAD. No power LED. Nothing.
                                        -Measured 3.3V & 1.8V still present from regulators
                                        -Measured panel having 3.3V
                                        -Measured on Power switch, is 3.3V when not depressed but 0V when depressed
                                        -Measured on U202; Top leg - 4.97V, Bottom 2 logs both - 0V
                                        any suggestions what to do next?
                                        I guess this bird is flying away & my stone might not be able to knock it down. ..
                                        • jetadm123
                                          • 2169
                                          #40
                                          At this point the only thing I can think of is that the EEPROM, U205, got corrupted. According to the schematic, it's a M24C16-MN6T. IF there's a method to perform an EEPROM reset, then that's a possible solution. On some Samsung's you can just replace the old EEPROM with a blank one. I don't know how it works in your case.
                                          • Fernon@Repair
                                            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                            by Fernon@Repair
                                            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                            VCCIO voltage ok
                                            VCCSA Voltage OK
                                            VCCPLL Voltage OK
                                            Ram Voltage ok
                                            RamVTT OK
                                            VPP 2.5 OK
                                            But No Core Voltage
                                            and i want to this vrm ic datasheet or pinout (ISL69269)
                                            anyone have this ic pinout voltages?...
                                            06-25-2025, 07:19 AM
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                            by sam_sam_sam
                                            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                            Now...
                                            06-09-2024, 10:57 AM
                                            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                            Based on Intersil's Robust Ripple Regulator...
                                            11-05-2024, 03:24 PM
                                          • ruletero
                                            Acer a515-43 low battery charge voltage
                                            by ruletero
                                            Hi
                                            Acer A515-43
                                            LA-H801P
                                            Fail: Does not charge battery, has low voltaje on connector.
                                            Laptop didn't want to turn on, only charge led blinked.
                                            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                            10-24-2022, 02:31 PM
